Water pump replacement
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by ZipZap, May 10, 2024.
  1. ZipZap
    ZipZap New Member
    Oregon
    Hi all,
    Does anyone have information on how to replace the water pump on a 2017 Prius Prime?
    Thanks!
    -ZZ
  2. ChapmanF
    15,435
    #2 ChapmanF, May 10, 2024
  3. Mendel Leisk
    38,646
    Info attached. Note, it's a cobbled "edition", sorted alphabetically, so "install" proceeds "removal".
  4. ChapmanF
    15,435
    I will here offer just a mild gentle hint that if you just look at the PDF file Mendel attached, and you don't read through the thread linked to in post #2, you may end up wishing you had read the linked thread.
    At the risk of over-hinting, the step numbered "1." on page 18 of that PDF is where you might end up wishing that.
  5. Mendel Leisk
    38,646
  6. Leadfoot J. McCoalroller
    7,135
    6,682
    Pennsylvania
    2018 Prius c
    That's a bit of a revision... looks like a good reason to delete that PDF and break all links to it.
  7. ZipZap
    ZipZap New Member
    Oregon
  8. ZipZap
    ZipZap New Member
    Oregon
