We like sheep... on the ECO Dashboard
Discussion in 'Prime Fuel Economy & EV Range' started by Old Bear, Oct 15, 2017.
  1. Mark57
    2,945
    2,740
    OK
    I was kidding about the internet speed part.
    Mine was set to Normal one time and no matter what score I got on the screen, it would not give me more than 81 on the app. I had accidentally hit the button. Are you using the heater, defroster, engine coming on, etc.
    benagi likes this.
  2. benagi
    benagi Active Member
    525
    280
    Utah
    Haha, you got me there. Hope all is well with you and your family. Thanks for the info.
  3. Mark57
    2,945
    2,740
    OK
    Thank you. And the same to you and your family.
    benagi likes this.
  4. benagi
    525
    280
    Utah
    3EA4172A-33D0-4778-B16E-A963BB1D0AE5.jpeg Hello again to those keeping record of their echo scores. For some reason, after owning my car 2 1/2 years, the last four months have been killing my echo driving score. As far as I know, I really haven’t changed my driving habits. is it possible that something has changed in the programming of the eco-driving score by Toyota? Anyone else notice their scores going down?
  5. GabrielD
    GabrielD Member
    179
    73
    Romania
    2014 Prius+ MPV
    According to this, here are some explanations...
    • The Prius reaches 51 mpg in the city and 48 mpg on the highway.
    • The Toyota Prius emits 71 percent less CO2 than a Hummer H3, and 20 percent less methane gas than an adult sheep.
    Later edit:
    I just found here on this forum TOTAL description of this...
    #865 GabrielD, Jun 10, 2020
    benagi likes this.
  6. sesullivan
    sesullivan Junior Member
    16
    Worcester, MA
    I ran into a similar situation after my 2017 Prime Advanced had a service where the 12V battery was disconnected and another time after a in dealer firmware update resetting some settings to defaults. Here's the deal:
    The "Predictive Deceleration Support" got enabled. It tracks driving patterns and uses GPS when it (automagically) recognizes a location where you would decelerate. For example coming up to the turn before the street where I live. When you get there the ECOCoach display drops to zero instantly. Not so bad to encourage efficient driving but the ECO ranking considers any lag time getting off the accelerator like punching the accelerator for a second or two which really messes up a drive's score.
    Good news is this is easy to turn off (see the Naviagation manual on page 259 (in the 2019 manual) for how to disable) Search for "Predictive Deceleration Support" in the manual for information on how it works (same for the main owner's manual).
    Figuring this out and turning it off restored my ECO scoring potential. During other services I have had my Prime left in "Normal" driving mode which I didn't notice right away. Might be worth a check, but that's a lot more obvious than the predictive deceleration support setting.
    Hope this is helpful!
    Paul.Ivancie and benagi like this.
  7. benagi
    525
    280
    Utah
    Thanks Sesullivan, that’s exactly the type of information I was looking for.
  8. benagi
    525
    280
    Utah
    Went to page 259 in the manual. Evidently my car does not have that option to turn on or turn off. I have a 2017 Prius prime advanced. That area is blank on my screen. See attachment.
  9. benagi
    525
    280
    Utah
    Found out how to turn off predictive deceleration today. On the 11 inch screen when the map is displayed, in the upper left-hand corner push options, then map information and you will see predictive deceleration. I had to turn that back on, then go to page 259 of the navigation manual, follow those steps, then the option showed up and there I unchecked it.
  10. jerrymildred
    jerrymildred Senior Member
    11,517
    14,171
    Tampa, FL
    As Red Green said, "And it's just that easy!" :D
    benagi and huskers like this.
  11. prius12306
    prius12306 2018 prime advanced - Stella
    116
    rotterdam ny
    2018 Prius Prime
    My eco dashboard is not updating. It shows last update on June 18 drive. And when it charged that night I did not receive an email. Today's drive is also not showing up. I've submitted a tech question, My car is a 2018 prime advanced model and it's always worked. Seems like some kind of communication issue. Perhaps server side at toyota?
  12. benagi
    525
    280
    Utah
    My eco dashboard is still updating properly as of this Saturday, June 20.
  13. benagi
    525
    280
    Utah
    Since I have been able to turn off the predictive deceleration, the problem with the dark blue line disappearing is finally gone. I have only been fighting this for a year now. Thanks again for the info.
    Paul.Ivancie likes this.
  14. Paul.Ivancie
    Paul.Ivancie Member
    60
    Upstate NY
    Thank you. It's never too late to learn... Your suggestion prompted me to immediately go to the garage and check my setting. Sure enough, it was enabled! I have wondered why my ECO prompt zipped to zero as I approached within about a tenth of a mile to my street. I have been getting around this by turning the cruise on just before I reach this point. Now I know why. There are other points on my frequently-traveled routes where this happens. I can't wait to see how this will affect my ECO scores now. Thanks again.
  15. sesullivan
    16
    Worcester, MA
    Have you checked to see if your "Safety Connect" contract is expired? I think most of the fancier entune features are tied to an active Safety Connect contract. I renewed mine a few months ago. Check this at https://www.myentune.com/features/ev/evSettings.
  16. morgan.cl
    morgan.cl Junior Member
    Something I haven't seen commented on here before. Since the shutdown of everything in March my daily commute is gone, so driving miles have gone way down and I rarely run out of EV range. So almost every month since March I've been able to check off all the top boxes -- two sheep, oranges, rainbow, top 20% in mpg and ECO (usually top 5%), etc. But twice now, at the end of June and again the end of Oct, after what looks like it should have made all the marks, beginning of the next month it reported for "ECO challenge": 0/5. Is there a minimum number of miles traveled before it will count anything (it was about 450 miles last month)? Is there a blacklist?
  17. Old Bear
    Old Bear Senior Member
    712
    1,050
    Boston, Massachusetts USA
    I think it's time to bring the sheep back from their pasture.
    I renewed by Safety Connect subscription last year and immediately lost my hard-earned "gold" status with all the sheep and fruit and flowers and rainbows, etc. Even though the Bear-mobile ran 100% EV for all but two of the last 12 months, it was not until this month when I got beyond bronze status to silver status (complete with tulips beneath my fruit tree.)
    I suspect that something happened to Toyota's "Eco Dashboard" back-end (which is now fixed) and that I'm one of the few people who still enjoy checking on the sheep from time to time. (Is this even available to owners in the current model year?)
    Now this will probably all go for naught because we're invited to a friends Labor Day cook-out about 40 miles away. And, although we will recharge the Bear-mobile once we get there, we're still going to use a couple of pints of gasoline and drop off of the Eco dashboard top-100 list.
    Then next month, we have a day-trip planned to Cape Cod to attend a one day music event which, at about 100 miles each way, will mess up the all-EV miles for October.
    And, there are plans for Thanksgiving week which will add additional non-EV miles.
    So, it looks like the sheep will be gone until New Year's Day, assuming an all-EV December. Baaaah. Baaaah. Baaaah. I now know how Little Bo Peep must have felt.
  18. DavidA
    2,349
    1,825
    Chicago western burbs
    I wonder how the app will change with the 2022/2023 hydrogen powered plug-in Prius? Will the sheep bulge larger and float higher towards the clouds the more hydrogen you convert to EV mode? Can the fruit on the trees even handle hydrogen, or will they rot and drop to the ground? Will the blue sky turn a yellow-ish brown hue? So many questions and no answers as yet.
    #878 DavidA, Sep 5, 2021
    Old Bear likes this.
  19. sesullivan
    16
    Worcester, MA
    After spending 4 years and 4 months enjoying the joy and self torture of driving my Prius Prime advanced as efficiently as possible I've decided it's time to revert to (more) normal driving patters. For the last 9 months (at least) My PriusPrimeSES has been the top ranked with an eco driving score of 99 most months and one at 100. Now maybe my good long term competitors like Buzzhead will continue on to keep eco-driving obsession going.
    During these last 4+ years I've typically spent about $40/year on gas; running the tank empty by using it to charge the battery twice a year. What the manual recommends to keep the gas from getting "stale". I'd be surprised if in 4 years I'd run the gas engine for more than 50 or 60 hours.
    During my first year with my Prime when I was figuring out the whole eco driving thing I'm sure I sent at least one or two people stuck behind me into therapy, but I did get 46 miles out of a single charge that summer! In the following years summer range usually topped out around 39 or 40 miles on a charge.
    If I was going to drive electric all the time why wouldn't I have just gotten pure EV? Range anxiety and I was so happy with my 2007 Prius II I'd developed an affection for the Prius line. With the big screen the Prius Prime was like an affordable "poor person's Tesla". I am pretty sure my next car will be a pure EV and with at least a 300 mile range. Not sure when that will happen. I want battery tech to improve. You know solid state batteries, LiFePO, vertical carbon nanotube cathodes and various technologies that look promising including Lithium-Sulphur. And full charge times under an hour if you can get enough AMP's from a high power DC charger.
    After all this time why stop now and go back to more normal driving? I have had a lot of satisfaction from driving very efficiently, but I'd like to feel free to really accelerate into highway traffic and travel at the same speed as other traffic. It time to change from the satisfaction of getting the most out of my little car and move to more of enjoying the experience of driving again. And maybe using the heat, seat heaters and even the steering wheel heater (I did try it once).
    So that's my report on 4 years of being an eco driving fanatic. I expect I'll still tend to drive efficiently but not to the extent of denying myself the thrill of the drive itself. Here are my last screen grabs from the Entune app.
    Happy Driving!
  20. Old Bear
    712
    1,050
    One of the reasons for buying a PHEV was because of the flexibility it offers. We've been pretty much all-electric for the 4 years and 3 months we've owned our Prime -- but have made several longer trips including one to Montreal for the (pre-Covid) Jazz Festival. Unfortunately, the math means that a single trip using gas will drive away the sheep and cause the oranges to drop from the tree.
    Even so, we've really come to enjoy checking on our sheep. (Mrs. Bear is a seriously into knittng and feels very positively toward sheep in general.)
    I think Toyota was very clever in designing the ECO-dashboard as a pleasantly challenging game. It certainly helped us become conscious of our driving patterns both in terms of fuel efficiency and in planning ahead to consolidate trips and select local routes rather than Interstate highway driving.
    We're still going to check on the sheep just for the fun of it. But we're also more likely to take slightly longer trips to see friends or to attend events beyond EV range.
    We just put new tires in our Prime. They are Michelins and seem to be much quieter than the Toyota OEM tires. I suspect they will reduce fuel efficiency somewhat, so we'll just have to see.
    Anyway, we still are enjoying the Prime and all EV driving on most days.
    And we still like sheep -- and I'm pleased to have been the original poster who started this thread which has garnered 880 responses!
    pghyndman and sesullivan like this.
