Weird Noise Behind Dashboard?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Chodronish, Mar 7, 2017.
  1. Chodronish
    Chodronish Member
    171
    40
    Illinois
    Four Touring
    I initially thought of it as mice chewing, so I understand. What were the suggestions? Did you figure it out? Is your 2005 still on original hybrid battery?
    'LectroFuel likes this.
  2. JC91006
    16,936
    8,647
    I heard a noise yesterday on my 2005, but that was when the AC was on. I think that's probably the only other noise in the dash area
  3. 'LectroFuel
    'LectroFuel Senior Member
    880
    673
    San Juan Capistrano, CA
    I had my A/C system replaced in January. Here's what they did:
    Definitely not worth stopping the noise. I had the work done to fix the A/C. I don't know how they stopped the noise, but it hasn't happened since. I would usually here it when the temp is in the 80s outside. They probably moved something around. The sound sounded like it came from the steering column and they tore out the steering wheel as in the picture lol.
    The car has the original battery.
  4. Chodronish
    Chodronish Member
    171
    40
    Illinois
    Four Touring
    OMG! I'd say that would stop ANY noise! My mouth dropped open! Cool on original battery.
  5. Chodronish
    Chodronish Member
    171
    40
    Illinois
    Four Touring
    I did a search for the sound of a bad 3 way coolant valve on Prius Chat and found this:
    That is definitely not the sound I have. I might try to record what I have and post it.
  6. 'LectroFuel
    880
    673
    I couldn't hear mine from outside
  7. Chodronish
    Chodronish Member
    171
    40
    Illinois
    Four Touring
    Well now when I filled up the gas tank, my fuel gauge did not respond and is just sitting at one bar. :-/
  8. PriusBarber
    PriusBarber New Member
    16
    North Carolina
    Does anyone know what the noise is? Mine seems louder than it first did. I can’t hear it from the outside and it doesn’t matter if I’m in park or have my foot on the brake in drive. It still sounds like coffee brewing. I changed the coolant inverter pump a couple months ago. I want to figure it out so it can be fixed before it becomes an issue. Any ideas????
  9. ChapmanF
    19,033
  10. Chodronish
    Chodronish Member
    171
    40
    Illinois
    Four Touring
    Well, for what it's worth, my noise still comes and goes, but is mostly not there. I have done nothing since I'm not handy to say the least, and no problems from it now for two years so far.
  11. PriusBarber
    16
    North Carolina
    Is it down near the drivers floorboard area that sounds like coffee brewing? My car is an 07 Prius.
    Is it the
  12. PriusBarber
    16
    North Carolina
    Can you post some pics of where to find it and how to clean it or refer me to any YouTube videos on this? Will it hurt my car if I keep driving it? My AC and heat work fine.
  13. Chodronish
    Chodronish Member
    171
    40
    Illinois
    Four Touring
    @PriusBarber - No, mine sounds more like it's from the behind the dashboard.
  14. ChapmanF
    19,033
    It will probably get worse over time, slowly. Whether it first reaches the point where you notice the heat or ac not working, or first just the point where it annoys you enough to fix it, I can't say. It might eventually reach a point where the servo can't just be cleaned but has to be replaced, but I think the part's not much over $100 anyway.
    My earlier post linked to more info with photos and a video. You might also search for a recent-ish post (in the last year maybe) from somebody else who had just cleaned one up in a gen 2. Seems like gen 1 and gen 2 are very similar in that design, but in gen 2 there's an extra ecu mounted down next to the heater that makes one of the servo mounting screws harder to get to. He had a picture of a very low-profile offset screwdriver he bought to save time reaching that screw.
    SFO likes this.
