Weird ticking sound, please help *video*
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by si12j12, Nov 28, 2013.
  1. kobear18
    kobear18 Junior Member
    92
    23
    san francisco
  2. telmo744
    telmo744 HSD fanatic
    2,181
    769
    Portugal
    My 3Gen Prius is 117k and 8 years old, has been ticking on braking&steering since 40k and for 5 years. I decided to do nothing.
    If it were about the CV, it would have collapsed by now. I'm pretty sure there is a slack in the connection to the hub that makes this sound.
  3. macmaster05
    macmaster05 Senor Member
    4,050
    730
    I have an appointment for tomorrow at Toyota for this exact problem. My car is lowered on Tein springs and after reading through 13 pages of this thread for an hour, I'm wondering if I should even bother showing up. I'm at 90k miles and have a 100k mile MaxCare warranty from Carmax which has a $50 deductible when doing repairs outside of Carmax. I wouldn't mind paying the deductible for a brand new CV axle drive assembly shaft(s) thingy, but I'd hate to pay anything for them not to find or fix anything.
    What do you guys think?
    #243 macmaster05, Sep 14, 2018
  4. Xterra72
    Xterra72 Senior Member
    1,437
    1,684
    I’m lowered on TRD springs. I currently have 125k miles. I still have the same ticking sound. The car is running fine. I wouldn’t bother.
  5. macmaster05
    4,050
    730
    I appreciate that a lot. Now dumb question, if I skip out on the Toyota appointment tmrw (it’s at 730am) will they charge me for the missed showing? They called me tonight at 6 to confirm and I said yes.
  6. Xterra72
    1,437
    1,684
    I wouldn’t think so. Things come up all the time. Give them a call in the am and just explain to them. Hope it all works out.
    Raytheeagle likes this.
  7. iskoos
    iskoos Active Member
    415
    254
    Orlando, FL
    My car is at 148k (2010 Prius III). Bought it used at 142k past November. I realized this noise shortly after I purchased it. It is exactly what's described here numerous time: High frequency ticking at low speed.
    I hear mine mostly when I make the right turn and braking. I didn't try whether it happens at "N" but I am 99% sure it will not.
    I have been thinking about how to bring this up and find more info. When I saw this thread the other day, I knew it was it...
    It never bothered me seriously. It is a noise that I hear when not listening to something and when windows down. This noise never gets worse in my case. It is always the same (at least for now). No idea how long it has been going. No warranty left on my car what so ever. I don't plan on taking any action. I personally do not believe it will pose any danger or gets worse in time. I read all 13 pages of this thread in 2 days and didn't find a single example where the owner had a serious issue not taking care of this problem.
    Sure I would have tried something if my car were under warranty. But spending hundreds to quiet a noise temporarily (because many reported it came back later) doesn't seem logical to me.
    I will keep driving mine and save on gas(y)
    telmo744 likes this.
  8. JC91006
    16,933
    8,643
    Well reviving this old thread, my 2010 with 113000 miles has developed this ticking noise. Time for a new axle......damn
    $99 at Napa or $350 from Toyota online
    #248 JC91006, Nov 27, 2018
  9. prius14
    prius14 New Member
    2014 Prius here with the same exact "clicking" while braking and turning problem. Since most of the 3rd gens are out of warranty, did anyone replace their CV axles with aftermarket ones? Been reading that Cardones and Raxles have reliable parts for CV axles. Anyone replace it with those and did it go away? What part# and did these noise ever come back? Non sense replacing the axles if the noise comes back. The car is great except for this one irritating issue.
  10. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Wait til you read up on clogged egr circuit, clicking sound would be the least of your worries.
    2004priusgal and Montgomery like this.
  11. prius14
    prius14 New Member
    Thank you for that tidbit.
  12. telmo744
    2,181
    769
    Portugal
    140k and counting, been hearing it since 30k (more or less). No measures taken... "If it works don't touch it."
  13. bluhawk
    bluhawk Junior Member
    25
    Torrance, CA
    eviving this thread. 2015 with 96K miles. Had been hearing this since 30K, only when braking on turns at slow speed, then i changed my suspension to Tein flex A and now i can hear it without turning the wheels. Contemplating if I should get the OEM axle since the oems fail on a certain point, also got bad experiences with aftermarket ones with the previous car so I really dont know what to do.
    Jacked up the car and tried to look for the issue, is this normal for an axle?
    How is the Napa axle?
  14. 2004priusgal
    2004priusgal Junior Member
    76
    new jersey
    Upgrade
    04, 185k, 2021 slight clicking when under 5 mph turning left and braking. no noise turning going backwards ect. havent tried the putting it in neutral yet.
    2022 192k right turn just started too. Clicking no where near as loud as video. Boots ok. All oem. No changes. owned since 2014.
    Read entire thread, whew! thanks all.
  15. CR94
    CR94 Senior Member
    2,819
    1,238
    Northwestern S.C.
    I've been hearing clicking while coasting slowly through turns nearly as long as I've had the car. It doesn't seem to be a big problem, considering the boots are ok, and the joints are quiet otherwise. The time to worry is when they start snapping loudly under power.
    My Mazda made a similar sound coasting at low speed even when not turning. That may have started when the original shafts were replaced with rebuilts from NAPA.
  16. Michael Wood
    Michael Wood Active Member
    181
    118
    Boston, MA
    2020 Prius Prime
    I just noticed this ticking on my 2015 with 163k miles. Only happens when rolling to a stop, with brakes applied, and turning right.
    After reading thru the posts, I'm thinking it's the axles. They have a tiny bit of normal play that increases over time. When you move the axles by hand you can hear the click There's probably something in the regen braking system vs. Issac Newton, and a right turn, that causes that movement repeatedly in quick succession.
    It doesn't bother me at this point. I'm not going to take any action.
  17. telmo744
    2,181
    769
    Portugal
    Ok, so this issue comes from 2gen also. Thank you for the input!
  18. PriusYin
    PriusYin Junior Member
    San Diego
    2013 Prius II w/66k miles:
    First starting hearing the clicking about 3 or 4 years ago.. only on simultaneous braking and turning to the right.
    In my case, there is no noise when braking and going straight.
    If you've ever been to High Performance Driver Education (HPDE), one lesson is to do all braking (and down shifting) before executing the turn. I've applied this technique to driving my Prius in an effort to mitigate/reduce the issue and the anxiety created from the noise.
    It's worked well for me..
    Its not looking like I'm going to do anything to "fix it".
    Michael Wood and telmo744 like this.
  19. mguzman
    mguzman Junior Member
    Oregon
    2012 Prius II w/94k miles:
    Have been hearing this for... Maybe a year? Finally got annoyed enough to take it to a shop. They struggled to replicate it, so I went out for a drive with them. Took a bit, but managed to find another business' driveway that could replicate it (slight downhill, and turning to the right with a wall nearby so the sound could be heard more easily).
    The post from Adamace in 2015 has me a bit spooked, as I guess the CV joint could just break eventually.
    Torn between going ahead and replacing now, or just living with it.
    I think I probably just live with it, unless it starts sounding worse during normal operation (i.e. turning while not braking).
  20. CR94
    CR94 Senior Member
    2,819
    1,238
    Northwestern S.C.
    As indicated in my previous post, clicking during turns isn't necessarily a problem, as long as it isn't getting worse, and goes away if you accelerate during the turn.
