What 12V battery would you recommend? Additionally, is there anywhere else I can hookup the leads?
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by Joe Wall, May 12, 2024.
  1. BiomedO1
    BiomedO1 Senior Member
    3,573
    1,853
    SacTown, Ca
    Don't ever do this with the battery connected to the car - Good way to fry some of your ECU's..... Ditto with those battery desulfater / chargers; those high energy / frequency pulses can damage your electronics, if the electronics are not shielded properly.
  2. Paul Gregory
    Paul Gregory Senior Member
    2,152
    563
    Alberta
    2024 Prius Prime
    XSE
    Of course it's not something to do intentionally. I was offering an explanation for what may have happened.
  3. Paul Gregory
    2,152
    563
    Alberta
    2024 Prius Prime
    XSE
    I was looking at the info under his profile.
  4. Joe Wall
    Joe Wall Member
    237
    51
    Wisconsin
    No I purchased a newer Prius
  5. Joe Wall
    Joe Wall Member
    237
    51
    Wisconsin
    I've been charging my phone a lot and thinks that what the issue was
  6. BiomedO1
    3,573
    1,853
    SacTown, Ca
    Don't leave the car in accessory mode, always keep it in ready mode - while using power. In ready mode; you've got the traction battery keeping everything alive. If any of your batteries gets low, the engine will start to recharge everything. That won't happen in accessory mode, you'll just kill your starting battery.
    On my car, the ECU barely keeps my starting battery just above 12 VDC - all other electricity goes back into the traction battery. On my regular gas cars, the starting battery is always closer 13 VDC, 13.5 - 14 VDC when the engine is running.
    Check the electrolyte levels in your battery, top off with distilled water if necessary - hopefully you got your problem solved.
    Good Luck...
  7. Paul Gregory
    2,152
    563
    Alberta
    2024 Prius Prime
    XSE
    You could update your info. It might fool less people (like me).
  8. cthorsman
    cthorsman Member
    75
    27
    Maryland
    2004-2009 is gen 2
    2010 is gen 3
  9. ChapmanF
    18,149
    In some parts of the world, a 2009 is gen 3.
    I don't think Wisconsin is one of those parts though.
