What about installing a 12v heater for the winter?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Jimbo69ny, Sep 24, 2012.
  1. John H
    John H Senior Member
    2,208
    558
    dried air from the AC is usually applied to "defrost". melting the ice is accomplished with heat though.
  2. Jimbo69ny
    Jimbo69ny Active Member
    712
    107
    Ithaca, NY
    In a past life I was a car audio/video installer. I have a few old remote starters laying around. What Ive decided to do is to find a decent 12 volt cabin heater and connect it to the remote starter. The remote starter wont actually start the car, just provide power to the heater(s). It has a built in timer and voltage sensing.
    I was looking for remote control switches but none of them have the range needed.
  3. benalexe
    benalexe Member
    198
    30
    Commack, New York
    I wish the A/C Button on the keyfob could be used to turn on the heat in the winter. That would be like remote start and really cool. It would also warm up the ICE.
  4. Jimbo69ny
    712
    107
    Ithaca, NY
    Yeah that would be nice. The prototype pip had it but they took it out to save money and because it was a complicated system.
  5. ukr2
    ukr2 Senior Member
    1,020
    278
    31
    Victor, NY
    I usually charge my PIP from 5am-8am.
    For the winter I wanted to place an 800 watt, 12 vdc heater on the passenger floor to heat the car and melt the ice off the windows. I would have a remote control switch that would allow me to turn it on from inside the house. While the PIP was charging, I hoped it would also keep the 12 vdc battery charged.
    However, I don't think the 12 vdc outlets operate until the PIP is turned on. DAMN.
  6. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    I have a 120 volt 400 watt oil filled heater, tried it the other night, left it on all night at maximum heat settings, when I got into the car the next morning the outside temperature was 47 degrees, inside temperature was 51 degrees, 400 watts is not enough, don't know if adding a second heater would improve the temperature difference.:cry:
  7. John H
    2,208
    558
    An insulated solar blanket over the vehicle cabin would probably help quite a bit.
  8. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    why solar? it's at night
  9. John H
    2,208
    558
    for the parking lot during the day. It's also a nice piece of emergency equipment to have on hand.
  10. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    wouldn't you want as much sunlight in your cabin as possible? And during these early times of the season, the windows thaw out during the day. So you would need the heat when it's dawn.
  11. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    and, I'm way ahead of you......the solar blanket would block any heat generated inside the cabin, ice would be on the windows, defeating the purpose of the blanket
  12. John H
    2,208
    558
    I'm trying to find the blanket I had in Stockholm. It was like a sheet of bubblewrap covering the top and glass. The inside of the bubbles were coated on one side, shiny out, black in. In the winter you kept the shiny side facing the car, the bubbles were a bit of insulation but removing the blanket made quick work of getting the snow and ice off the car, the shiny surface reflected heat back into the car. The parking spaces in Stockholm had electric outlets for car heaters, and heated parking lots (steam generated at the nuclear reactor I was told).
  13. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    let me know if you find it, and maybe a part number, mfr, etc. could work. cept at night, still trying to figure that one out.
  14. John H
    2,208
    558
    I used it at night mainly. I had to park outside on the streets over night. At the office I could park in the heated garage.
    Here is the closest I can find at the moment. I emailed a friend in Sweden to see if he can get me some more info.
    Eufab 16184 Windscreen Cover Cabin Cap Universal for Cars / Vans and Minibuses: Amazon.co.uk: Car & Motorbike
  15. lensovet
    2,615
    496
    Burlington, NJ
    in fact, the manual specifically states that charging time could increase due to an undercharged 12 V battery
    however, as mentioned elsewhere in this thread, the 12V outlets don't work unless the car is in ACC/ON mode.
  16. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    I found this:
    Details For: Titan 4L Hatchback Cover TOYOTA Prius PHV Hatchback 2012 | EmpireCovers.com
  17. Jimbo69ny
    712
    107
    Ithaca, NY
    Yes they would definitely need to be connected directly to power. The tiny wires at the cig outlet aren't big enough to handle the heater anyway.
    Ive shelved this idea for now becase my time has been spent looking at another rental property at the moment. Ill dive back intothis later...
    So PK, you used 400 w heater and it didn't do much? That is very good to know. So we either need to go a lot bigger or scrap the idea.
  18. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    maybe this will help:
  19. Jimbo69ny
    712
    107
    Ithaca, NY
  20. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    True....but could add extra insulation with the heater
    LG-MS910 ? 2
