  1. scrappy
    scrappy Active Member
    125
    308
    Orange County, CA
    2014 Prius Plug-in
    No. I think that was a change in the 2007/10 timeframe and these junkyard modules are from late 90's to early 2000's cars. I recall seeing in Homelink's FAQ that even some 2011 model year cars didn't yet support that new security codes profile.
    I haven't yet tried rolling codes with my junkyard modules, as my opener is pretty old. I may test it this weekend with my GF's garage door opener. But, that might get me suckered into modding her PIP this weekend :censored:
    #7121 scrappy, Apr 29, 2015
  2. ncases
    ncases Senior Member
    609
    672
    Chicago
    Got this one couple of weeks ago. The grip isn't that good so i'll be looking for something different.
  3. Justdidit
    Justdidit LVNPZEV
    1,880
    710
    75
    Carrollton, Texas
    Four Touring
    Do you have some non-B/W photos? It looks awesome! what mm size of LEDs did you use? Do you have pictures or write up of the retrofit install?
  4. prius blk
    prius blk New Member
    los angeles
    The picture actually is non BW but i took it inside my garage. i will repost the picture again when i park my car outside
    For the LED i got it from Ebay
    10 20 100 x Pre Wired 5mm LED Light Bulb Lamp 12V 12 Volt 20cm DIY Prewired LEDs | eBay
    The process to retrofit is first bake the headlight
    DIY HEADLIGHT REMOVAL AND HEADLIGHT BLACKOUT GUIDE AKA Baked Headlight | PriusChat
    Then install LED by drill a small hole behind it and use epoxy to set the location of the led.
    I only put the expoxy only in the back where is the wiring not on the LED part
  5. Justdidit
    Justdidit LVNPZEV
    1,880
    710
    75
    Carrollton, Texas
    Four Touring
    Cool. Looks similar to the LED setup I did last year. The issue I had was the LEDs burnt out due to heat. Was curious as to if you had made a heatsink for the LEDs or had another method for heat reduction.
  6. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    @Bobby313
    Can u make it??????
    Even if it just 2 hang out
    VS980 4G ?
  7. xcuter
    xcuter Active Member
    303
    182
    Installed 8" Chinese android head unit. So far I'm loving it.
    K[​IMG]
    Jayare, Dylan Doxey, Johnsk93 and 8 others like this.
  8. jamessicat408
    jamessicat408 Active Member
    110
    175
    San Jose, CA
    What brand/model is that?
  9. xliderider
    xliderider Senior Member
    8,122
    3,265
    Honolulu, HI
    Does it have the vehicle speed lockout like the oem head unit? Or can all functions be used regardless of vehicle speed?
  10. kenniekenken
    kenniekenken Member
    105
    60
    Alberta
    If this retains OEM functions then I want one! :)
  11. ncases
    609
    672
    Chicago
    if this is plug and play then I'm on it. I can't tackle it if its not my mind is just preoccupied with mods. o_O
    Accordlayingkit likes this.
  12. AKWSF
    AKWSF Junior Member
    SF
    does your 3 have the backup cam like the '14 model? changing the existing cam would be a pain. also, hows the steering controls? all working?
  13. electrode
    electrode Junior Member
    42
    United States
    I would like to know about where to get the part for $8.99 too!
  14. xcuter
    303
    182
    Bought on eBay think the brand is Pumpkin.
  15. xcuter
    303
    182
    All functions work while driving.
    xliderider likes this.
  16. xcuter
    303
    182
    My 3 didnt have a camera installed my own and it works with this head unit. Steering wheel controls all work. You are able to program the buttons to any function you want which is really cool.
  17. Xterra72
    Xterra72 Senior Member
    1,432
    1,678
    I noticed this part inside my car. It came off of something. Anybody know where this part came off of? ?
  18. xliderider
    8,122
    3,265
    Honolulu, HI
    If it is a large plastic nut, it came from your kick panel cover next to your dead pedal (by parking brake).
    Did you find it in the driver's side footwell? ;)
  19. Xterra72
    1,432
    1,678
    Thanks. honestly I don't remember. will try to look there and see If it's missing.
  20. scrappy
    125
    308
    Orange County, CA
    2014 Prius Plug-in
    Yup, looks like the plastic nut from either the driver or pass side kick panels.
