  1. ncases
    ncases Senior Member
    609
    672
    Chicago
    Just installed my fogs and for some reason my switch is always lit even the ignition is turn off. And worse of all the fogs lit when fog switch on with the ignition off mode.
    It must be the cheap relay is broken.
    Anybody know where to buy these replacement relays?
  2. ncases
    609
    672
    Chicago
    Same thing happen to me. Wifey likes the smaller one.
  3. Accordlayingkit
    Accordlayingkit Senior Member
    1,616
    1,747
    377
    Colonial Heights, Va
    apt5020 likes this.
  4. Xterra72
    Xterra72 Senior Member
    1,431
    1,677
    Careful with that. You Definitely don't want your battery draining out.
    ncases likes this.
  5. ncases
    609
    672
    Chicago
    I'll just take the fuse out for now until i have a word from you guys. Thanks.
  6. Xterra72
    1,431
    1,677
    The light on my fog light switch is only lit when fog lights are on And when switch is engaged. Off otherwise. .
    ncases likes this.
  7. apt5020
    apt5020 Senior Member
    881
    1,294
    Prius City, CA
    If you connect directly to the 12V aux. Is it always on even if you turn switch off? If always on could be something with the switch not your wiring. I bought my fog kit from Toyota. Where did you get your fog kit?
    ncases likes this.
  8. ncases
    609
    672
    Chicago
    Hmmm. Just in ebay. Maybe I'll call toyota then and redo the wiring. thanks for your response.
  9. ncases
    609
    672
    Chicago
    I will try to install the fog light kit from toyota lets see how it does. Thanks
    For now its LIT! :confused:
    Sean Callahan likes this.
  10. Truck
    Truck New Member
    Destin, FL
    washed the girls today.
  11. Truck
    Truck New Member
    Destin, FL
    would love to black out my headlights but don't have the balls to try it lol.
  12. Xterra72
    1,431
    1,677
    You can do The rear lights. We have the same prius, so it can look something like this.
  13. Blu-ray
    Blu-ray Blizzard Brigade #215
    471
    198
    TampaBay, FL
    Did you show this to the dealer? I'd take it in and complain.
    iPhone ?
  14. ncases
    609
    672
    Chicago
    Thanks to you and @RightOnTime. I was able to figure out what's going on. The 12v that feeds the the fogs and switch was coming from the fuse box. Instead of connecting it to the 12v aux under the dash. Will be rewiring it hopefully on wednesday.
    Xterra72 likes this.
  15. RightOnTime
    RightOnTime Senior Member
    789
    1,657
    183
    Kidnapped in OC, CA
    That's what Prius Chat is all about!(y)(y)(y)(y)
    Dylan Doxey, Xterra72, ncases and 4 others like this.
  16. kenniekenken
    kenniekenken Member
    105
    60
    Alberta
    This might prove useful... Nearly all the vehicles (cars) I've worked on where I needed access I removed the plastic fender liner and from there you can poke your way through the hood release cable/grommet :)
  17. apt5020
    881
    1,294
    Prius City, CA
    Got a chance to install Morimoto fog light. Might go back to my yellow LED fog. Keep the Morimoto as spare
    Burna J and ncases like this.
  18. ncases
    609
    672
    Chicago
    Thats too complicated for me bro, but thanks for the input. There's a little rubber nozzle needs to be clip and found a small surgical scissor at work that i can use to snip that little thing and feed the wire through the hole.
  19. Farzan
    Farzan New Member
    Los Angeles
    Hey, love the seats, can i ask the name of the shop and their phone no?
    Thanks
  20. BigBear2010
    BigBear2010 Member
    156
    65
