  1. apt5020
    apt5020 Senior Member
    881
    1,294
    Prius City, CA
    No, I just flip the adapter. It's because of LED bulb. I wanted to project the line across instead of putting half a circle on top. From Cheizy picture he did the same.
  2. apt5020
    881
    1,294
    Prius City, CA
    Yes, I pointed it upward but below the low beam height.. Car is too low to level it. Going to test it at night and find out if I point it too high or not. Don't want t blind people. Might lower just a little
  3. apt5020
    881
    1,294
    Prius City, CA
    Damn, part broken during shipment. Hopefully they sent me another one.
  4. Starbrand
    Starbrand Senior Member
    493
    1,503
    Westmont, IL
    not really a mod, but ordered this cute lil find on Amazon.
    will probably try and find a close winter gray metallic at Michaels and redo his paint. Then will be a desk ornament at work :rolleyes:
    link if interested
  5. Rhinoruns
    Rhinoruns Member
    61
    38
    Madison, WI
    Don't know if the picture loaded, but I'm testing out the Torque app on my Nexus 7. Loaded in the custom Gen III pids and its reading everything. Just gotta figure out what to monitor and how to mount up near the windshield...until I replace the HU with an android unit. Happy times.
    iPhone ?
    Xterra72, ncases, apt5020 and 2 others like this.
  6. xliderider
    xliderider Senior Member
    8,140
    3,274
    Honolulu, HI
    Sounds like a normal setup, LED vs HID or halogen, doesn't matter. The cutoff stays the same. If there is a semi circle with flat line cutoff on the bottom, then the light housing is upside down. There is a marking on the mount (UP) on one of the 4 tabs, and an ^ arrow on the back of the light that indicates which side should be oriented up.
    They're also marked L and R.
  7. Accordlayingkit
    Accordlayingkit Senior Member
    1,616
    1,747
    377
    Colonial Heights, Va
    I feel Ya on the boot.... It sucks! I ended up going through the right boot as I took my rear washer line out and used that boot for my rear hatch led light wires
  8. Xterra72
    Xterra72 Senior Member
    1,432
    1,679
    I thought I went to dark. ... but it's all about lighting. ...... With the sun out, you can still see the orange...Glad I went with the darkest. ...... 2015-05-25 16.53.51.jpg
    :D
  9. ncases
    ncases Senior Member
    609
    672
    Chicago
    You are too close on that gutter. It seems you perfected it. Nice rims are those gun metal or silver.
  10. Xterra72
    1,432
    1,679
    Gun metal for persona series. Silver for the higher prius model.
  11. ncases
    609
    672
    Chicago
    Love that wheels. Its really rear to find those kind of wheels.
    #7431 ncases, May 25, 2015
    Xterra72 likes this.
  12. bonchang
    bonchang Active Member
    144
    349
    NEWHALL, CA
    Can you share where you got this small piece please? Thanks.
  13. jalynn2
    jalynn2 Junior Member
    Downingtown, PA
    Installed the self-dimming mirror with Homelink in my 2015 Prius Three with solar roof. Instructions provided by Priuschat shop were spot on. I'm happy to have saved over $300 from the dealer's quote.
  14. qdllc
    qdllc Senior Member
    1,375
    400
    Sorry to be late to the party, but I did a whole DIY thread on my install.
    2013 Prius Two Rear Camera Upgrade - DIY | PriusChat
    I'd suggest being patient and disconnect the boot on both ends...it can be done, and it helps a lot. Also, I used an old wire hanger, electrical tape and a healthy application of silicone lube. Push gently, and if it doesn't go through, back up a bit and try again because you might be catching a stray wire not fully taped down on the existing wire harness.
  15. Accordlayingkit
    1,616
    1,747
    377
    Which piece is that?
  16. MeetGeorgeJetson
    MeetGeorgeJetson Junior Member
    48
    33
    Woodstock NY, USA
    How did your car feel with the spacers? Any noticeable improvement?
  17. Collinator
    Collinator Junior Member
    Houston, TX
    Hi All!
    New to the forums...having trouble trying to locate a "How To Library." Is there a sticky somewhere with all of the DIY stuff?
  18. qdllc
    qdllc Senior Member
    1,375
    400
    The site probably needs a child/sub-forum under "maintenance" and maybe one for "modifications" which holds DIY threads that the mods feel are the most informative so searching takes less time.
  19. Collinator
    Houston, TX
    I agree. It seems to be the norm on forums for most other cars. There are a ton of DIYers on this site, it would make sense to have a locked sticky with links to all of the helpful How To write ups.
    Dylan Doxey likes this.
  20. xliderider
    8,140
    3,274
    Honolulu, HI
    The site does have this subforum with some really good how-to type threads, but it is not easily found for members not familiar to the site:
    Knowledge Base Articles Discussion | PriusChat
