What happens if I hit the power button while in motion?
Discussion in 'Gen 3 Prius Main Forum' started by Strangelove, Dec 21, 2009.
  1. DLC82SV
    DLC82SV Member
    241
    119
    I'm so glad that isn't the case in a gen 2!
  2. fuzzy1
    10,724
    At highway speed, Park and Reverse should do the same thing, go to Neutral with the double beep warning. Though I speak only for Gen3, with the hope the Gen2 did the same.
    But you should also be able to (mostly) power the car off at speed too, by holding the Power button down long enough (3 seconds ???). This is an essential safety item to shut down the propulsion system in case of another outbreak of runaway engine incidents. This may change steering and brake feel by loss of power assist, but will not disable their basic manually operated fail-safe functionality.
    After a certain model year (2012???), repeated stabbing of the Power button should also shut off the car. But this was implemented only after the Runaway Toyota Fiasco, so won't apply to Gen2 or the first half of Gen3s.
    DLC82SV likes this.
  3. DLC82SV
    DLC82SV Member
    241
    119
    No issues to report. However, my Gen 2 wouldn't even power down holding it. It just beeped at me. Probably to protect the hybrid drive and the motor generators? Idk
  4. DLC82SV
    DLC82SV Member
    241
    119
    Run away Toyota? Plz do tell!
  5. fuzzy1
    10,724
    It was a general Toyota hysteria that struck about 2010, and was similar to the runaway Audi 5000 scare of 1988-89. Statistics very strongly suggest that the bulk of incidents are pilot error, but there is no hard proof that all of them are such.
    Here are just the first few PriusChat threads that pop up when I use the Search feature:
    Runaway Prius ... | PriusChat
    Runaway acceleration possible cause? | PriusChat
    Another runaway reported in New York | PriusChat
    Runaway hysteria reminds me of Y2K | PriusChat
    Toyota's runaway-car worries may not stop at floor mats-LA TIMES | PriusChat
    LA Times: Runaway ride kills Toyota love affair | PriusChat
    ABCNews: New Evidence of Runaway Toyotas May Help Imprisoned Camry Owner | PriusChat
    What happened to James A Sikes - the Runaway Prius? | PriusChat
    #25 fuzzy1, Sep 12, 2018
    DLC82SV likes this.
  6. Quattro
    Quattro Member
    60
    28
    Silicon Valley, CA
    As many have said, hitting the start button accidentally won't do anything, you have to hold it for more than 3 sec.
    I remember there were many videos on how to stop a car in case the throttle got stuck during the Toyota floormat recall. Check youtube.
  7. iskoos
    iskoos Active Member
    415
    254
    Orlando, FL
    I have never heard of this before anywhere. Hitting the park button puts the car in neutral when travelling above certain speed.
    DLC82SV likes this.
  8. DLC82SV
    DLC82SV Member
    241
    119
    The car definitely goes into neutral. It does not power down and I have even pressed power while driving and the car doesn't just turn off. I put my muck boots on so I don't get any on me.
