What kind of engine work should I do?
Discussion in 'Gen 3 Prius Technical Discussion' started by BiaoH, Apr 25, 2022.
  1. BiaoH
    BiaoH Junior Member
    46
    Haverford, PA
    So as some folks might know I just obtained a 2010 Prius with 237k miles on the clock (quite cheap lol!) which was not running and I diagnosed it with a failed clutch damper. I'm in the process of pulling the engine out but since I don't have a crane on my hand I'm attempting a cheap man's route (basically removing all parts down to the short block and lift it out with 1-2 helpers). I removed all outside parts, valve cover and timing chain yesterday as well as all the head bolts. I'm going to lift off the head and try to remove the block in the next 1-2 days.
    My question is how much work should I invest into the engine? Should I do a complete rebuild with updated pistons and rings, or just a head work is going to be good? As of now what I can tell is that the oil in the crankcase I drained out is a little milky at its due service time, indicating a slightly leaking head gasket. The timing chain is pretty tight at the time I opened the valve cover. The car was low on coolant when I got it, with P0300/P0302/P0303 stored as permanent DTCs (those echo the head gasket problem).
    I guess I'm likely going to find a local machine shop to do the work regardless so want to hear folks opinion about it. It's a 4th car in our family so I'm not into the idea of making it like new, but definitely don't want it to break in a short time after I invest so much time and money into the engine work.
    52,817
    i would replace everything, or look for a low mile engine to swap
    1prius and Mendel Leisk like this.
  3. BiaoH
    BiaoH Junior Member
    46
    Haverford, PA
    Darn...I just separated the engine and transmission and found the transmission input shaft is shot...
    Wondering if replacing this shaft is easy? I know Toyota does not like us to service the transaxle so there's probably not too much information I can find out there, but it looks like the input shaft is available as a part that can be sourced from dealer or bought used off ebay. Is it as simple as removing the plate in the photo and put it in, or I have to completely disassemble the transmission?
    #3 BiaoH, Apr 25, 2022
  4. Mendel Leisk
    42,314
    The failed clutch damper could be the "canary in the coal mine", a symptom of coolant in combustion chambers, due to failing head gasket, due to carbon-clogged Exhaust Gas Recirculation components (including intake manifold).
    See how the piston tops look when the head comes off. If one and/or two looks exceptionally clean that's likely evidence of coolant leaking past the head gasket. Inspect the head gasket for failure, which often happens between cylinder one and two.
    Foxglove likes this.
  5. BiaoH
    BiaoH Junior Member
    46
    Haverford, PA
    Noted. I just removed the head and separated the engine from transmission last night (broke 2 bolts that hold the engine to the trans...) and found the transmission input shaft snapped (see my last reply). I'm not sure if the clutch damper is OK -- that I have to take a look after I lift the short block out of the car (need a helper). By looking at the top of the pistons, I found that the cyl 3 and 4 pistons are exceptionally clean and definitely have traces of coolant on top. Cyl 2 piston has the heaviest carbon deposit while cyl 1 piston looks somewhere in between.
    I'm struggling a little as of how to proceed. It looks like replacing the input shaft of the transmission is not too difficult -- only need to drain the oil and remove the input shaft cover. I can even do this without removing the trans. However when I try to source the parts it does not seem like something easy to find and dealer charges $400+ for the input shaft, while a used tranny can be bought for $200-300.
  6. ChapmanF
    18,998
    No, I think you're mistaken about there being an "input shaft cover". The input shaft is also the PSD planet carrier, and inserted from within the disassembled transmission. Watch at around 5:50 here:
    I hope you read this before doing anything rash like removing any "input shaft cover". The only removable "plate" I can think of in that area is what closes off the cooling water jacket for MG1 ... and that "plate" seals with a very large O ring that (a) you can't get, and (b) are highly unlikely to successfully reassemble.
  7. Mendel Leisk
    42,314
    First link in my signature, while primarily EGR cleaning info, is in a thread premised on a failed damper; might be something relevant.
  8. BiaoH
    BiaoH Junior Member
    46
    Haverford, PA
    OK.. then I guess a used transmission would probably be my best option. Thanks a lot for the really helpful input!
  9. BiaoH
    BiaoH Junior Member
    46
    Haverford, PA
    Yeah I read that. I'm cleaning all parts before assembly for sure. Honestly the amount of EGR gunk on this model seems to be much smaller than the OM642 I have worked on before lol! Not a big deal to me.
  10. Tombukt2
    Tombukt2 Senior Member
    13,845
    2,515
    Durham NC
    I think I paid $199 for my used JDM spec transmission from JDM engines and new jersey this just happened like 90 days ago maybe 120 it's in the car running fine I wouldn't do much of any engine work to the 2z at all it's not worth the parts you're buying to put in it not in my world not when I can get a low mileage take out for almost under $1,000 you notice most of these free that have all these problems they're up and around 200,000 miles a few have not been I do understand that but most are over or well over certainly can't blame Toyota for that
  11. BiaoH
    BiaoH Junior Member
    46
    Haverford, PA
    I just got a used transmission today from a local junkyard for $250+tax. This one has 64k miles on it. JDM engine has one for $99 but shipping is $250 to me. I'm around Philadelphia, not too close to north Jersey.
    I sort of agree with you on the engine. Upon initial inspection the pistons are in pretty good shape. Connecting rods are not bent at all. I guess I'm probably not going to disassemble the short block but still I'll do some measurement on the cylinder diameters to make sure it's still within spec. Then I'll just do a resurface of both head and block and install new gaskets and timing chain. If it burns oil I'll just keep adding oil that's not a big deal to me.
  12. douglasjre
    douglasjre Senior Member
    2,249
    751
    Null, NL
    These are high mileage units. Why aren't you just replacing the engine and transmission together?
  13. rjparker
    rjparker Tu Humilde Sirviente
    11,063
    6,933
    Texas Hill Country
    Proceed cautiously! We have seen people jump in and just do the minimum and end up doing it three times. One guy eventually replaced the engine with a gen4 version, but not without continuing problems. Burning oil is not good. These engines had bad pistons and rings from 2010-2014 which correlates with the rash of head gasket problems. The fact the egr gets clogged occasionally is a side effect. Wait until the catalytic converter clogs up as well after all your efforts if you don't address the oil issues. There is no oven cleaner solution for the cats.
    douglasjre likes this.
  14. BiaoH
    BiaoH Junior Member
    46
    Haverford, PA
    I would love to but a used engine costs $1500-2000 based on my search, and I might still run into the HG issue...
  15. BiaoH
    BiaoH Junior Member
    46
    Haverford, PA
    I'm willing to solve this issue honestly and am seeking possibilities. I called local engine shops and none of them do rebuild on this thing so I guess my choices are either find a used gen4 engine to put in, or replace the piston and rings by myself. I have never done any internal engine work before other than replacing head gaskets, but I'm willing to try...
  16. bisco
    52,817
    237k, how do you handle the cylinder walls? do they sell liners, or oversized rings?
  17. alftoy
    alftoy Senior Member
    1,132
    519
    Saskatchewan, Canada
  18. rjparker
    11,063
    6,933
    Texas Hill Country
    If the walls are damaged the block is done
  19. BiaoH
    BiaoH Junior Member
    46
    Haverford, PA
    The cylinder walls look pretty good with no visible scratch. I don't have a bore gauge on my hand, but I guess I can use my calipers to do a rough measurement see if the bore size is still within spec. I'll post results.
  20. BiaoH
    BiaoH Junior Member
    46
    Haverford, PA
    I see that post but that's back in 2019... You know how crazy the used car market has been in the past year. See those used engines cost $1500-2000, plus with 60-80k miles on those engines I would expect the HG problem to develop soon. My current plan is to do some measurements on my current engine (namingly the conditions of the cylinders). If they are still in spec I might just go with replacing the pistons and rings (this does not seem too complicated according to the TSB), and then put a new gasket set and timing chain. Otherwise if the cylinders are not good I'll need to go for a used engine regardless.
