What on earth does this wire do?
Discussion in 'Gen 2 Prius Main Forum' started by Prius92, Aug 25, 2022.
  1. Prius92
    Prius92 Active Member
    595
    122
    Iowa
    This isn't my photo.
    So there is a 2 wire harness that connects to the car's wiring, then it loops around the safety plug receptacle and actually plugs into it. Where the car's wiring plugs in, is on the top of the black safety plug receptacle.
    But there is nothing connecting where it plugs into, literally just a plastic box. I shone a light inside the hole and see no wiring, sensor, etc of any kind, and the end of the connector is just that..a connector.
    Here's another shot of it.
    Only thing I can think of is maybe when a dealer is testing the battery..it plugs into something else instead of the service plug? Because it's weird it doesn't terminate into a sensor.
  2. dolj
    dolj Senior Member
    8,640
    4,391
    Wellington, New Zealand
    Doesn't the safety interlock switch bridge those pins to form a circuit (when the slide handle is pressed down vertically and clicks into place) so the battery ECU knows that the safety interlock is installed?
  3. alftoy
    alftoy Senior Member
    1,132
    519
    Saskatchewan, Canada
    #3 alftoy, Aug 25, 2022
  4. Prius92
    595
    122
    Iowa
    Well I feel like a giant dummy lol. I never looked at the orange part.
  5. Tombukt2
    Tombukt2 Senior Member
    13,853
    2,515
    Durham NC
  6. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,095
    Columbia, SC
    This wire has been discussed dozens of times. It's sometimes forgotten to be reconnected by a new DIYer after rebuilding a battery, which leads to the car not working because the car ecu never recognizes that the safety plug is inserted.
