What year are these battery modules from?
Discussion in 'Gen 2 Prius Technical Discussion' started by Mavi, Aug 24, 2018.
  1. Mavi
    Mavi Active Member
    484
    285
    San Diego,ca
    2020 Prius Prime
    #1 Mavi, Aug 24, 2018
  2. ITBland
    ITBland Active Member
    433
    278
    New Orleans, La area, US
  3. Mavi
    Mavi Active Member
    484
    285
    San Diego,ca
    2020 Prius Prime
    Thanks Im aware of that, but I have only the modules, which is why I'm trying to deduce if these modules from pack 1 are older than 2012.
  4. ITBland
    433
    278
    #4 ITBland, Aug 24, 2018
  5. Mavi
    Mavi Active Member
    484
    285
    San Diego,ca
    2020 Prius Prime
  6. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,522
    Bay Area, California
    2019 Prius Prime
    Pack 2 modules are from September 19, 2015.
    You got a better pic of pack #1?
    ITBland likes this.
  7. Mavi
    Mavi Active Member
    484
    285
    San Diego,ca
    2020 Prius Prime
    Thanks ray, any idea about the 1st pack.. it seems like the serialing is completely different.
    Raytheeagle likes this.
  8. ITBland
    433
    278
    I edited my response, looks like 11/11/2012-- @Raytheeagle would know better, tho.
    OOPS:oops:, must have looked at pics in other thread, sorry!:(
    #8 ITBland, Aug 24, 2018
  9. ITBland
    433
    278
    06/18/2013 would be my guess Day 18, Month 6, Year O=2013
  10. ITBland
    433
    278
    @ericbecky or @strawbrad might know--that PDF implies that the serial number is different if it was made before 2008.
  11. Raytheeagle
    11,267
    15,522
    2019 Prius Prime
    Need a better pic ;).
    What year is the seller saying they are?
    How many modules are you looking for and what year are the modules you have?
    If they are too far apart in age, they may not integrate well into their new environment :(.
    Something to consider (y).
    ITBland likes this.
  12. Mavi
    Mavi Active Member
    484
    285
    San Diego,ca
    2020 Prius Prime
    Seller was saying 2013, but I doubt it.. the capacity was terrible. The 2nd pack I have, not pictures is actually a 11/2012, which means 2013 pack. I have a feeling it's a pre2008 pack.
  13. Raytheeagle
    11,267
    15,522
    2019 Prius Prime
    I’d ask the seller for another pic to confirm the age of the module;).
    If he’s saying it’s a 2013, I’d consider that to be true. Does he offer any warranty or guarantee on the module?
  14. Mavi
    Mavi Active Member
    484
    285
    San Diego,ca
    2020 Prius Prime
    So I've attached another pic of the pack.. it's bizzare. I've never seen this numbering style.. even on my 2007 it has a different type.
  15. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,094
    Columbia, SC
    Don't make it more complicated than it is. First 2 digits are the day of the month (1-31). Third digit is the month (1-9, x, y, z) Fourth digit is the year. I always remember L=2010 on modules. So "O"= 2013
    Put it all together and you have 6/18/2013 for the manufacture date
    Same reason you have 9/19/2015 for the other pack modules.
    The older modules like your 2007 have the same decode sytem, but the serial numbers are just straight across near the center of the module. The new location with 2 rows started sometime in the Gen 3s. Gen 4 modules that I've seen went back to the straight version again.
    #15 TMR-JWAP, Aug 26, 2018
    Mavi and ITBland like this.
  16. TMR-JWAP
    6,404
    6,094
    Columbia, SC
    Serial number decode is the same, but they stopped using the paint marks on the terminal nuts. Prior to sep 2008, it's super easy to see if someone messed with the battery just by looking at the paint marks.
    ITBland likes this.
  17. Mavi
    Mavi Active Member
    484
    285
    San Diego,ca
    2020 Prius Prime
    You sure that those are "O" and not a "0"? If it's an O that solves my mystery of the year.
  18. dolj
    dolj Senior Member
    8,610
    4,370
    Wellington, New Zealand
    Yes the 4th digit is always a letter, never a numeral.
  19. ITBland
    433
    278
    Manufacturers should be banned from ever using 1, I , lowercase L, 0, or O in serial numbers!!!!
