Where is the location of the 2010 Prius starter?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by GreenTea&SaltWater, May 29, 2021.
  1. GreenTea&SaltWater
    199
    58
    Los angeles
    For some reason Google doesn’t give me any results. Does it not exist in a Prius?
  2. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,423
    2,392
    Taylors, SC
    There is no starter that is separate from the traction motors. They spin the engine to start it.
  3. rjparker
    rjparker Tu Humilde Sirviente
    9,973
    6,166
    Texas Hill Country
    Its inside the transaxle. One of the two motor/generators. If your gas engine is not starting it is highly unlikely this motor generator is the problem. If it won't go to Ready mode check your 12v first.
    Raytheeagle likes this.
  4. GreenTea&SaltWater
    199
    58
    Los angeles
    The 12v is reading 11.5v and I attempted to have i jump started it went up to 13.8v.
  5. Georgina Rudkus
    3,423
    2,392
    Taylors, SC
    The 12 volt does not power any motor. It just activates the relays and switches that control the HV battery to the traction motors.
  6. Mendel Leisk
    41,123
    The engine, which is shared with Corolla, has a blanking plate where the starter would be.
  7. JC91006
    16,748
    8,553
    11.5v is low but shouldn't require a jump start to start the car. It should be sufficient. 13.8v is normal once your car is in Ready mode. And there is no starter on this car, the hv battery provides the power to start the engine.
    jerrymildred and Raytheeagle like this.
  8. rjparker
    9,973
    6,166
    Texas Hill Country
    So is it running now? It sounds like you achieved Ready mode.
  9. GreenTea&SaltWater
    199
    58
    Los angeles
    Waddup JC long time no see. Check my previous post and lemme know what you think? “Check Hybrid System” error | PriusChat
    Rebound likes this.
  10. GreenTea&SaltWater
    199
    58
    Los angeles
    Every single light is on the dashboard except the ready light
  11. rjparker
    9,973
    6,166
    Texas Hill Country
    Take the 12v battery to an auto supply and have it load tested.
  12. bisco
    51,682
    read the codes and repair the correct issues
  13. Grit
    Grit Senior Member
    6,573
    4,225
    Wilkes Land
    that doesn’t sound like prius chat, here it’s plug n pray.
