Where is the VVT Oil Control Valve Located?
Discussion in 'Gen 2 Prius Technical Discussion' started by jimolson, Feb 11, 2018.
  1. jimolson
    jimolson Member
    162
    63
    Indianapolis, USA
    I've just spent a hour searching on Google and YouTube for how-to instructions on replacing the VVT oil control valve and filter. No luck.
    I have the new valve in my hand but I find nothing on the motor that looks like it. Could someone post instructions or a picture showing where the valve is located?
    The problem I'm trying to fix is diagnostic code P0011 and terrible gas mileage (32mpg) on an interstate highway at constant 70mph. Passing power at cruising speed appears to be mostly normal.
    I've replaced the traction battery in my other Gen 2 Prius so I have a good feel for what an aging battery feels like. This vehicle is not showing any aging traction battery problems.
    The vehicle's odometer is 156k. It's a 2006.
    Thanks in advance for your help.
  2. SFO
    SFO Senior Member
    5,302
    4,252
    Northern California
    Raytheeagle likes this.
  3. edthefox5
    edthefox5 Senior Member
    10,096
    4,840
    Clearwater, Florida
    It’s right under intake manifold #1 about 2 inches down. The valve has a connector on it and right next to it is a female hex head head bolt the filter is behind that hex head. That hex head is really on there tight btw. Had to breaker bar it and it made a really loud crack when it came loose.
    Toyota likes to tighten the shite out of bolts.
    Cano, Raytheeagle and SFO like this.
  4. jjmerp
    jjmerp Junior Member
    51
    22
    Ohio
    This is where the VVT filter is Located
    Hayderusa84, DLC82SV and Raytheeagle like this.
  5. edthefox5
    10,096
    4,840
    Clearwater, Florida
    I seem to remember being under the intake but yes it’s behind that hex head bolt.
    Use a high quality hex socket as it is really on there. A harbor freight pos won’t cut it.
  6. Cano
    Cano New Member
    Perfect discription of location. Replacement went easy as pie. Thanks
    DLC82SV and edthefox5 like this.
  7. SFO
    SFO Senior Member
    5,302
    4,252
    Northern California
    Welcome to Priuschat!!
    How many miles on your 05 ?
    Curious about the need for replacement, did you throw a code or was there another reason?
    Upon removal, was the old VVT filter gummed up or dirty?
    Now that you've replaced, have you noticed any difference?
  8. Jmack111
    Jmack111 Member
    371
    78
    Tacoma wa
    Replace the actuator just above the filter will restore MPG $21 bucks or less
  9. Brandonius13
    Brandonius13 New Member
    Forest Falls, CA
    I made a quick video showing the location :
    It's to the left. If you take off the air cleaning compartment (the thing that houses you air filter) then it's pretty easy to see. I was surprised that I did not find any videos about replacing this part on a 2nd generation Prius. Looks like it is even easier to get to on a 3rd generation Prius. I watched those videos to give me an idea.
    SFO likes this.
  10. SFO
    SFO Senior Member
    5,302
    4,252
    Northern California
    Welcome to PriusChat!!
    Curious if you might have any pictures of the gen3 location?
    FYI : you're moderated until you've posted 5 times.
  11. ChapmanF
    19,063
    The Gen 3 solenoid valve is located right in plain sight on top of the valve cover. If you're not seeing it, you're looking at somebody else's car.
    The Gen 3 filter, however, is under one of the camshaft bearing caps. That makes it nowhere near as easy to access as the 1NZ one with its little hex plug on the side of the engine.
  12. Brandonius13
    Forest Falls, CA
    Thank you for the welcome. This is the video I was refering to for 3rd generation Prius. Very convenient. I watched it for ideas before replacing on my 2nd generation, I figured it would be similar just less convenient.
  13. edthefox5
    10,096
    4,840
    Clearwater, Florida
