Whistling noise on drivers side
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Tomek310, Oct 4, 2016.
  1. Tomek310
    Tomek310 Junior Member
    89
    Riverside
    Hi guys. Ever since I bought my 06 prius I am hearing an annoying whistling noise on the drivers side while driving. Has anyone else experienced that? If so, has anyone been able to fix that? Any feedback appreciated.
  2. JC91006
    16,833
    8,603
    Your door is probably not flushed with the rubber seal.
  3. exstudent
    exstudent Senior Member
    2,214
    905
    Torrance, CA
    It could be the door seals. But I say it is less likely compared to the outter door mirror seal. Replace the outer door mirror seals first. The part is cheap and the repair is easy. If noise persists, then it may be time to replace door seal.
    Read post # 14.
    air leaking from upper side speker next to driver seat | PriusChat
    Tomek310 likes this.
  4. Tomek310
    89
    Riverside
    I think you are right about the side mirror. The noise seems to come from the mirror area. I will look into that. Thank you very much!
  5. Frontporch
    Frontporch Active Member
    536
    122
    Nj
    For me it was the plastic tape that covers the bolt holes under the mirror. One was half gone and what was left was vibrating making a LOUD whistling noise at 30-40 mph. Noticed it was not the window glass because it got much louder when the window was open. I was going to go to the dealer to see if they had a replacement "cover" but I just tore off the rest of what was left and all is good. No more noise.
