Why is my engine revving while idling and getting a P0011 code?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by wbs887700, Oct 26, 2021.
  1. wbs887700
    wbs887700 Junior Member
    74
    Does anyone have any idea why I keep getting the p0011 code, and when I get it something under the hood sounds like the engine is revving or pulsating up and down? Is it something that I can fix myself? What can I do about this?
    I've been getting p0011 for the past 6 months occasionally, and now it's coming on much more often.... basically, when my Prius is idling in park, sometimes it will sound like the engine is revving up and down and then the check engine light will come on.
    P0011 means "intake camshaft in Bank 1 is more advanced" and I don't really know what that means exactly.
  2. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
    wbs887700 likes this.
  3. JC91006
    16,845
    8,613
  4. mr_guy_mann
    mr_guy_mann Senior Member
    4,098
    2,001
    NJ-USA
    A camshaft controls when the valves at the top of the engine open and close. The intake cam controls when air (& fuel) go into each cylinder while the exhaust cam controls hot gases (the results of combustion) out. Each cam spins (in a clockwise direction), driven by a chain and sprockets from the crankshaft.
    The exhaust cam is bolted directly to its sprocket- the rotational position relationship between them is fixed. If you have a mark on the sprocket, everytime it comes to the straight up position (12:00), the cam will be in the exact same position every time.
    Now for the intake cam, having a fixed positional relation isn't the most efficient for every RPM condition. If there is a mark on the intake sprocket and that comes up to 12:00 position, maybe the intake cam IS best at "12:00" when the engine is idling (known as the fully "retarded" position). But at higher RPM, maybe having the cam at 12:45 or 1:00 position is better. Since the cam rotates clockwise, it reaches any given position "sooner" than the sprocket- this called advancing the cam. That is what Variable Valve Timing does- alters the rotational position of the cam to its sprocket (from 0 to 40° on the prius ).
    The engine computer (ECM) monitors the cam position, and if it's not where it should be, then the ECM sets a code. P0011 indicates that the intake cam is more advanced than what the ECM wants it to be. Something in the VVT system isn't working correctly. The system uses pressurized engine oil - directed by a solenoid valve that is controlled by the ECM- to act on a mechanism inside the intake sprocket to move the cam. A common cause for this code is that some carbon grit or varnish causes the solenoid valve to stick in the "advance the cam" direction. (I assume that the warning light goes out when the ECM actually wants the cam to be advanced).
  5. wbs887700
    74
    Thank you for that.
    I'm still getting the p0011 code with the engine revving.... Can you please tell me how I can clean the solenoid your talking about to remove any possible sludge or build up? It's getting worse and worse
  6. alftoy
    alftoy Senior Member
    1,132
    518
    Saskatchewan, Canada
    #6 alftoy, May 3, 2022
    SFO likes this.
