Wiper motor bad ?
Discussion in 'Gen 3 Prius Technical Discussion' started by Ben Schneider, Feb 7, 2022.
  1. Ben Schneider
    Ben Schneider Junior Member
    central florida
    3 months ago arrived at parked prius in cold night and wipers did not work. Next morning, warmer and worked ok
    1.5 months ago, same thing.
    Yesterday, wipers stuttered, then stopped.
    This morning, very cold. Wipers did not work. Fuse brown, but not blown. Changed fuse. Wipers did not work rest of day.
    Went to gas station this evening. While cleaning Windshield, moved wipers with hands. Started car. Wipers moved half an inch.
    Still not working otherwise.
  2. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
    Your contacts where the fuse plugs in could be loose, one side of the fuse shows discoloration like arcing of current could be occurring.
    You're going to have to find a way to get the copper contacts in the fusebox to make better electrical contact with the fuse. That will help provide more current to the wiper motor or relay, whichever the case may be.
  3. ChapmanF
    18,967
  4. Ben Schneider
    central florida
    I will try, thank you
  5. Ben Schneider
    central florida
    Took dielectric grease, swabbed with qtip
    Put on oem wd40
    Inserted, pulled out about 11 times
    Works in a stuttering fashion
    What can I do to make it constant
  6. ColoradoBoo
    ColoradoBoo Senior Member
    1,342
    966
    Monument, Colorado USA
    Since it works sometimes, I'd check every ground I could find...I've seen rusty connections make electronics act like that. Do you have a multi-meter you can hook up to the terminals and ensure power is constant?
    If power is constant, replacing the wiper motor might be an option...MSRP is $230.04 but McGeorge on-line has them for $153.51 or you might check your car parts store for prices. https://toyotaparts.mcgeorgetoyota.com/oem-parts/toyota-windshield-wiper-motor-8511047240?c=Zz1lbGVjdHJpY2FsJnM9d2lwZXJzJmw9MiZuPVNlYXJjaCBSZXN1bHRzJmE9dG95b3RhJm89cHJpdXMmeT0yMDEzJnQ9Zm91ciZlPTEtOGwtbDQtZWxlY3RyaWMtZ2Fz
    Ben Schneider likes this.
  7. ChapmanF
    18,967
    Wear of the carbon brushes inside the wiper motor can also be a thing.
    Ben Schneider and ColoradoBoo like this.
  8. Ben Schneider
    central florida
    Not working...
  9. Ben Schneider
    central florida
    Seems to only work when some force is applied to move wipers ...
    Person got out to clean Windshield. While cleaning, pushed wiper and wiper started moving.
    Also, wind blew wiper and wiper moved.
  10. ChapmanF
    18,967
    What will you try next to pin down the problem?
  11. Ben Schneider
    central florida
    Was out of town, not so easily able to work on car.
    Came back to warm Florida.
    Cleaned mechanism. Took apart wiper motor assembly.
    Wires seem ok. Cleaned area.
    Wipers seem to work.
    Either the cold affected it, not sure still if I should replace motor.
    Other possibility is seating of driver wiper might have affected if motor could go.
    Seems to work now in 65 degrees, as opposed to 30s. Not sure if temperature affected it.
  12. ASRDogman
    ASRDogman Senior Member
    8,050
    4,082
    If/when you take it apart, you should clean and grease all the pivot points.
    And clean the brushes, or replace them then clean where they contact the motor.
    I can't for the life of me think of what that part is called! "commutator"??
    It should be clean and shiney, and clean the grooves also, carefully.
    #12 ASRDogman, Feb 22, 2022
  13. ChapmanF
    18,967
    Ding ding ding ding ding ding ding!
  14. Ben Schneider
    central florida
    I will do that
  15. Ben Schneider
    central florida
    What kind of grease
  16. Ben Schneider
    central florida
    Can I use dielectric grease or wd40
  17. ASRDogman
    8,050
    4,082
    Carb or brake cleaner to clean it, then light grease, like bicycle grease.
    You don't need a lot. Maybe plumbers grease?
  18. Ben Schneider
    central florida
    Opened motor.
    Was maybe 1/2 ounce of dried up seeming to be grease.
    Swabbed black dirt out.
    Sprayed wd40 and coated with dielectric grease.
    Sealed with gasket maker.
    Seems to work but now 1/16 synced in backwards direction when starting cycle. I hope it works fine enough for the cold. In the 80s in Florida.
  19. ASRDogman
    8,050
    4,082
    Why dielectric grease????
    Don't understand this sentence: "Seems to work but now 1/16 synced in backwards direction when starting cycle.".
  20. Ben Schneider
    central florida
    Dielectric is what I had from other step. Looked usable.
    The wipers move in the wrong direction for an inch or two at the beginning of every cycle. Not horrific but not prefect.
