Won't start with good 12V battery
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Belliott, Aug 28, 2025.
  1. ChapmanF
    18,941
    Can you post a photo? You're not talking about something in the long white fusible link assembly?
  2. JC91006
    16,929
    8,639
    Oh now you're onto something. Maybe someone jumped started this car, accidentally reverse polarity the battery connection (if you did it in the rear, it could happen because of the tight space). That will blow the fusible link and the car won't start
  3. Hayslayer
    Hayslayer Active Member
    519
    316
    If there was a reverse polarity jump performed that opened the fusible link in the white plastic housing (with clear plastic top) I saw a way to work around it on this site if the car needs to be moved. The post mentioned it should definitely only be temporary, as it basically used pennies wedged on each side of the blown link to get continuity back. A bit risky, but sometimes that's required if you need to get a car moved. If you don't know what caused it to blow, I don't think I would do that penny trick. I'll try to find that post, it's been months since I read it.
    Found it, it even has a photo.
    2008 Prius won’t start | PriusChat
    Don't forget, when a reverse polarity jump occurs, it normally blows a couple fuses in that fuse box also.
    Good luck!
    #23 Hayslayer, Aug 29, 2025
  4. Belliott
    Belliott Junior Member
    23
    Maryland
    So in conclusion, The original post that the SKS icon was blinking regardless was incorrect. The car exhibited the following symptoms:
    -on first Power button press all that was achieved is the Power button lighting green and SKS icon ceasing to flash
    -On second power button press, button turns orange, SKS icon stays off and CEL illuminates.
    -car has no brake lights at any time.
    -power locks do not operate by the fob or rocker switch button on interior door panel/armrest
    -center display never turns on
    -brake pedal pulses and generally acts as normal, which might not seem normal if you are not in tune with its normal pulses and clicking noises.
    -Gasoline engine never turns on.
    The cause was found to be a fault in the fuse box that had been fixed by a previous owner, and that fix had gone bad.
    There is a fusible link (a thin squiggly bit of metal between two plates that can burn away if there is too much current.) in one of the distribution bus bars in the under-hood fuse box. It gets juice from the positive jump point under the red cover and distributes it to the items that should Always be hot, like brake lights, the power locks, etc... A previous owner apparently diagnosed this and fixed it by crimping a glob of metal to those two plates to bridge the gap. That piece of metal slid forward, breaking the link and electrically disconnecting those "always hot" items from their supply of power.
    I slid that glob of metal back in place and the car behaved normally. I then engineered a more permanent solution by cutting a groove in a binder clip so it would sit down below the step in the forward plate, sanding the paint off the inside surfaces, removing the "legs" of the clip, slathering it in no-alox so it wouldn't oxidize, and placing that so it contacted both plates. The plastic cover keeps the clip from moving upward. This seems like a duct tape solution, but given how tight it is in that box, all my other solutions involving soldering wires to the plate that had inline fuses or terminals on that bolt by the jump point simply would not fit in there. I know the real solution is replacing that plate. Seems like opening a can of worms to try to replace just that plate or the entire box.
  5. ChapmanF
    18,941
    It isn't replacing the metal plate or the entire box, it's replacing that long white windowed assembly that has the plate in it. That's the fusible link block assembly. (That shows the MSRP; you can click dealer links to see their discounts. You can also buy from a recycler, but check any used one carefully to make sure none of its links are blown!)
    It unclips and lifts straight up out of the fuse box* and has some bolted connections and at least one plug-in connection on the bottom. The wires are long enough to lift it out and transfer the connections. Then you pop the new one right down in the slot.
    You can refer to this thread for more instructions on changing it:
    How to change Fusible link under hood | PriusChat
    Your improvised fix is to be presumed unsafe; chances are very slim it would blow at anything close to the intended current in the case of a fault somewhere. The results could be damage to much more expensive parts, destruction of a wire harness (expensive both as a part and in replacement labor), or fire with property damage or personal injury.
    * before I did my first one, I bought a fusebox from a recycler that had the part in it, and practiced pulling the part out of that. My practice run was difficult, because that fusebox had been sitting in a recycler's yard in the sun and the wire insulation got very stiff. Pulling the white assembly up out of the box was really hard because of the stiff wires. But then after I'd practiced, I went and worked on a real car with the fusebox protected under the hood, and even though the car was like a dozen years old, the part was easy to pull upward.
    VintagePrius, dolj and Brian1954 like this.
  6. rjparker
    rjparker Tu Humilde Sirviente
    10,959
    6,874
    Texas Hill Country
    Even a hack solution should include an external fusible link of the same size, generally available at auto supplies. Otherwise the original reason for failure is likely to recur with burnt and shorted wiring harnesses making you wish you had done it right the first time. On a gen2 it could total the car.
  7. ChapmanF
    18,941
    If the reason for failure was a backwards jump, at least that probably isn't going to recur on its own.
    Still best, of course, to make sure the protection is in place.
