Would you haul this...
Discussion in 'Gen 2 Prius Main Forum' started by THF, Apr 8, 2013.
  1. THF
    THF Junior Member
    71
    MO Ozarks
    OK, so the transmission recently went out on the Tundra, leaving us with only the Prius as our main vehicle... Which sucks. So, my question is, would you put a transmission (~200lbs, ~440kg) in the back of a Prius and haul it? We're talking about 3 ft long by maybe 16 inches... Would it put stress on the battery pack? I've noticed the back storage is just wussy plastic, as well...
  2. maestro8
    maestro8 Nouveau Member
    471
    109
    nor cal
    I've hauled 200+ lbs of porcelain tile in the prius with no problem.
    Quit worrying and get 'er done.
    THF likes this.
  3. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
    THF likes this.
  4. enviroprius
    enviroprius Junior Member
    91
    Sonoma, CA
    I've had 15+ cases of wine in mine. That's about 600 lbs of wine. Worked fine. Wouldn't do it all the time, but once or twice probably will be ok.
    THF likes this.
  5. THF
    THF Junior Member
    71
    MO Ozarks
    Other thing is it is 200 miles away...
  6. cwerdna
    12,545
    2,125
    SF Bay Area, CA
    Big deal. I've driven over 860 miles (from WA state back to the Bay Area) w/my mother + the entire hatch area and back seat area full of cargo. I'm sure my mother + cargo was well over 200 lbs. This included going up and down the hilly/mountainous areas in Oregon via I-5.
    If guess you're concerned about the weight on the plastic "shelf" area, maybe you can help even out the load by using boards or planks over it and spread it out over the plastic and the rear seats?
  7. THF
    THF Junior Member
    71
    MO Ozarks
    That's what I was thinking about. I'll probably throw some towels or old blankets back there to protect from fluid leaks from the tranny.
    I'll be getting this thing Wednesday; I'll let everyone know how it goes. Thanks for the help, just wanted to make sure I didn't kill the Prius thing!
  8. CharlesJ
    CharlesJ Member
    467
    29
    38
    Monterey
    Well, which is it, about 200 lbs or about 440 kg? as they are not even close equivalents.;)
    440 kg is 968 lbs. But, 200 kg is about 440 lbs. :)
    dhanson865 likes this.
  9. cwerdna
    12,545
    2,125
    SF Bay Area, CA
    Good catch! I only looked at the 200 lbs and my response was "big deal".
    440 kg (which Google as a calculator tells me is 970 lbs) on the other hand... I wouldn't haul that in the Prius. That's over the Prius' max cargo + occupant weight limit w/o even the driver.
  10. CharlesJ
    CharlesJ Member
    467
    29
    38
    Monterey
    Even NASA messed up the two systems and it was a costly mistake. :D
  11. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    Looks like a bass ackwards conversion because 200kg is 440lb.
    Even at 200 lb a trans-axle should have something like wood under it because it has force concentrated at edges and sharp points instead of being evenly distributed over a large area
    uart likes this.
  12. edthefox5
    edthefox5 Senior Member
    10,096
    4,835
    Clearwater, Florida
    It should be fine just be aware the brakes will really suck. Its almost like regen is removed when you put alot of weight on the car. At least thats the way mine acts with tow weight on it.
    I would have the transmission fluid changed first and the Inverter coolant replaced also. Both cheap and your diy guy so very easy. Your looking at $60 all in for fluids and 2 hours.
    Good luck...and oh put that thing in a crate first. One fast turn and hilarity will ensue.
    cwerdna likes this.
  13. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    Towing hundreds of pounds with the Prius is no problem.
    The brakes actually work really well, the regen keeps them cool. However, all that weight on the back end makes it squirly because the FWD that is used to having a nice engine over it now gets counter balanced by 600 pounds of slate tile, cement bags, paver stones, decorative gravel, and other things in my case.
    +1 on the strapping down or crating of the transmission. Metal vs. glass has a pretty clear winner.
  14. THF
    THF Junior Member
    71
    MO Ozarks
    Ack... Dumb. Got my calculation backwards. should have realized the kg would be a smaller number than lb, being denser. It is 200lb.
  15. bobeast
    bobeast Junior Member
    39
    23
    While everyone takes you to task about math, not one of them stopped to question what a 960 lb transmission would look like ;)
    Can you say forest for the trees? I think the Prius will handle your 200 lb transmission just fine.
  16. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    It could look like about 1/2 of an HMPT-500 transmission.
  17. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
    This may sound radical, but have you thought about renting a pickup to haul that tranny in? By the time you spend your money and effort to crate up the tranny which will protect your Prius from possible damage if you had to stop quickly you could have easily rented a pickup from U Haul.
    Besides that, tranny's are notorious for leaking fluids. No matter how many blankets, towels etc. you place underneath chances are the interior is going to get some sort of fluid on it. There is nothing worse than the smell of gear oil inside a vehicle IMO.
    Yeah, you can carry a lot of stuff in the Prius. But if you want to be practical about it, consider what you are wanting to carry and what could possibly be damaged if a catastrophic event took place.
    edthefox5 likes this.
