Your Fully Charged EV Miles Range
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by SF Prius PI, Sep 13, 2014.
  1. GregP507
    GregP507 Senior Member
    3,002
    481
    I'd love to see some real numbers which support the idea that you can improve the mileage n the Prius by using pulse-and-glide. Until then, I remain skeptical.
  2. GregP507
    3,002
    481
    "Better safe than sorry" is a good policy in lieu of actual knowledge, but actual knowledge is always better. 18 ga wire is rated for 16 amps over short distances, but longer distances are a different matter. Heavier gauges are required. For something as important as charging the Prius, heavier gauges are always the safer bet.
    Potorap likes this.
    52,848
    dc requires larger gauge than ac, but i've no idea why.
  4. rxlawdude
    rxlawdude Active Member
    701
    220
    So Calif
    2015 Tesla Model S
    Probably because the current is flowing on average around 70% of stated draw (if I recall my math for AC). There are instantaneous periods where voltage and current are zero (as each cycle goes positive to negative and back again).
    At least, that's my guess. :)
  5. rxlawdude
    701
    220
    So Calif
    2015 Tesla Model S
    I know I seem to be alone in this request, but when posting estimated EV range, could everyone PLEASE specify whether the Climate Control (even just a fan running with no AC!) is on or off? That already introduces a 10%+ confounder.
  6. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    That's because this topic has been beaten to death already over the past 2.5 years and other influencing factors like temperature are not included either.
    ESTIMATE will vary. ACTUAL will too.
    It's the overall outcome that matters, since blending should be taken into consideration.
  7. bisco
    52,848
    ev estimate should only be posted with fan OFF.
  8. SF Prius PI
    SF Prius PI New Member
    San Francisco, CA
    2014 Prius Plug-in
    Thank you for all the replies. I will document my average mpg and see if the EV range will increase.
  9. bisco
    52,848
    documenting it won't help, you have to slow down.:cool:
  10. john1701a
    12,840
    5,312
    58
    Keep in mind that EV range really doesn't mean much. For example, today was one of those started away from home. I only had 1.2 miles of estimate EV range leftover from yesterday. Despite that, the end result was 6 miles of EV travel.
    I see it vary rather significantly depending on how I drive. Slower typically equates to more. That's true for warmer weather too.
    The reason it doesn't mean much is due to the fact that the same electricity is being used whether it gets logged as EV or not. You'd have to carefully document kWh instead to even stand a chance at confirming a difference over time. 2 months is no where near enough either.
    Another Battery Degradation Thread | PriusChat
    ...is the thread we created to share long-term observations of the battery-pack for the plug-in model.
  11. bisco
    52,848
    it means more when you drive all ev.
  12. GregP507
    3,002
    481
    An EV charge is a quart of fuel in my scenario.
