Lighting - Historical
Applied By ChapmanF: Sep 26, 2012 at 10:57 PM
(History)
Lighting
Column 1 | |
0 | [tr][th]Function[/th][th]Toyota #[/th][th]Common #[/th][th]Best Don'sBulbs match[/th][th]Consumption (watts)[/th][th]Output (lumens)[/th][th]Notes[/th] |
1 | [/tr][tr][td]Headlight[/td][td]90981-13055[/td][td]HB2 60/55[/td][td]hb2[/td][td]60/55[/td][td]1650/905[/td][td][/td][/tr] |
2 | [tr][td]Parking lt[/td][td]99132-12050[/td][td]947?[/td][td]w5w-5w-12v-w2.1x9.5d[/td][td]5[/td][td]50[/td][td][/td][/tr] |
3 | [tr][td]Front turn[/td][td]90981-15011[/td][td][/td][td]7440a[/td][td]21[/td][td]460[/td][td][/td][/tr] |
4 | [tr][td]Side marker[/td][td]90981-11020[/td][td]194[/td][td]194[/td][td]3.8[/td][td]25[/td][td][/td][/tr] |
5 | [tr][td]Rear turn[/td][td]90981-15014 or -15011[/td][td]7440 or 7440A[/td][td]7440[/td][td]21[/td][td]460[/td][td]1[/td][/tr] |
6 | [tr][td]Stop/Tail[/td][td]90981-11048[/td][td]7443[/td][td]7443[/td][td]21/5[/td][td]440/35[/td][td][/td][/tr] |
7 | [tr][td]Reverse[/td][td]90981-11059[/td][td]921[/td][td]921[/td][td]18[/td][td]264[/td][td][/td][/tr] |
8 | [tr][td]License[/td][td]99132-12050[/td][td][/td][td]w5w-5w-12v-w2.1x9.5d[/td][td]5[/td][td]50[/td][td][/td][/tr] |
9 | [tr][td]Center high stop[/td][td]99132-12050[/td][td][/td][td]w5w-5w-12v-w2.1x9.5d[/td][td]5[/td][td]50[/td][td][/td][/tr] |
10 | [tr][td]Dome[/td][td]90981-14011[/td][td][/td][td]FESTOON/12V/8W/31MM/11MM[/td][td]8[/td][td]~ 96[/td][td][/td][/tr] |
11 | [tr][td]Map[/td][td]90981-12005[/td][td][/td][td]SR12V8WMB[/td][td]8[/td][td]~ 96 ?[/td][td][/td][/tr] |
12 | [tr][td]Coin tray[/td][td]90981-11018[/td][td][/td][td]74[/td][td]1.2[/td][td]6 ?[/td][td][/td][/tr] |
13 | [tr][td]Trunk[/td][td]90981-11020[/td][td]194[/td][td]194[/td][td]3.8[/td][td]25[/td][td][/td][/tr] |
General notes:
Lumens = MSCP × 4π (or about 12.57). As of this writing, Don's database has a lot of errors where a bulb's MSCP rating got entered as lumens, and then the CP figure is shown as 1/12.57 of that. When that happens you can get the correct figures just by multiplying Don's figures by 12.57.
Numbered notes:
1. 7440A for amber signal if lens color is clear
XenCarta
