How to tell which wheel bearing?
Discussion in 'Generation 1 Prius Discussion' started by ChapmanF, Aug 31, 2013.
Which bearing do these clues point to?
Poll closed Sep 7, 2013.
  1. Left front
    0 vote(s)
    0.0%
  2. Right front
    33.3%
  3. Left rear
    66.7%
  4. Right rear again (just don't make 'em like they used to)
    0 vote(s)
    0.0%
  5. Need more clues
    0 vote(s)
    0.0%
  1. scotman27
    scotman27 Active Member
    735
    82
    PA
    2001 Prius
    breaking glass noises while an engine is running. eeeesh i dont like the sound of that one bit. i hope its nothing major and just something loose like an exhaust shield or whatnot. you know, something dumb like that lol. the kind of simple fixes we like
  2. ChapmanF
    18,536
    Not as small as you might hope, and that limited how many directions I could choose for clipping them onto those bolt heads and not interfering with the wheels. They really look a lot like the standard-issue stamped spring clamps on cheapo 12V battery chargers, right down to the red ribbed plastic handles. I've got no doubt that's exactly what they are, and JS Products just buys them from Acme Cheapo Battery Clamp Company and jams audio pickups (very thin, probably piezo) under the springs.
    I was sort of wishing they had used the next smaller size of cheapo clamp, but then I'm sure you'd run into something chunkier you wanted to listen to and the jaws wouldn't open enough.
    -Chap
  3. Patrick Wong
    18,210
    6,513
    I agree.
    Chap, can you pls take a photo or two showing a sensor and the wireless transmitter positioned next to a ruler? Thanks!
  4. ChapmanF
    18,536
    Ok, I'll see if I can get to that in the next couple days.
    Once this bearing's replaced, I wonder if I'll need to add a Vehicle Proximity Warning tone....
    -Chap
  5. ChapmanF
    18,536
    pickup.jpg Ok, here's what a pickup and transmitter look like.
    newfh.jpg Here's a new bearing fresh out of the box. Everything's nice and quiet now, so the left front was definitely the one. That means the temperature test really wasn't effective for tracking down this problem: the hub on the bad side actually showed up a couple K cooler than the one on the other side. I was aiming an IR thermometer at the hubs through the wheel center holes. Maybe it would have been better to crank the steering and try to get behind the wheel and aim at the knuckle near the speed sensor, I don't know. There always seems to be a little drag with disc brakes, and that might just heat the rotors enough to mask any bearing effect unless it's really bad.
    By comparison, the multichannel sound pickup was dramatically effective in identifying the bad bearing.
    By the way, what do the rest of y'all do to stake a new hub nut to the shaft? Any better idea than a hammer and drift? It seems odd when the bearing makers all write so much about handling the bearing carefully, not subjecting it to any avoidable pressure or shock so as not to brinell the races, so you press it ever-so-carefully into the knuckle (only by the outer race!), and likewise the hub into the new bearing (only by the inner race!), and gingerly set the whole thing back on the car ... then crank down the hub nut and bang a hammer on it. o_O Seems like there ought to be a better way....
    I was curious about the inner details of the bearing, wondering whether the sound I heard in the cabin (at a frequency around 12.8× the wheel revs per second) might be a reliable characteristic. Conveniently, when the machinist pressed the hub out, one side of the split inner ring stayed with the hub, leaving the bearing open to view:
    He didn't save me all the balls that got away when it came apart, but it's easy to count the empty spaces in (what's left of) the plastic cage, and see this is definitely a 15-ball proposition. (Per side - this is an assembly of two matched bearings back to back, in a one-piece outer race.)
    My quickie measurements are 5.55 mm for the ball radius, 34.65 mm radius of the outer race, giving 23.55 mm for the radius of the inner race (which I didn't get back from the shop to measure directly).
    In this application the outer race is fixed, the inner race goes around at wheel speed, and the ball cage goes around in the same direction as the inner race, but more slowly. In an earlier post I was half-convinced that the cage speed would be ½(wheel speed)(inner race radius)/(inner race radius + ball radius). Now I'm more than half convinced. Think of spinning the inner race clockwise by some amount, for convenience let's say one radian:
    The ball cage rotates less far, so there's a difference (shown in red), the distance the inner race got ahead of the cage (by rolling under the balls). The green distance is how far the cage advanced along the (nonmoving) outer race, again by the balls rolling. In a good world the balls don't slide on either race, so the red and green distances are equal.
    We spun the inner race by one radian, so the cage went along through some angle θ < 1. The green distance is just θ(outer race radius) and the red distance is (inner race radius)(1 - θ). For outer race radius substitute (inner race radius + 2 × ball radius), set the distances equal, and find θ = ½(inner race radius)/(inner race radius + ball radius).
    Plugging in the dimensions of this bearing, the cage goes around at ½(23.55)/(23.55+5.55) ≃ 0.405 × wheel speed. There are 15 balls, so if there's some defect on the outer race, it's going to get whacked at (15)(0.405) or 6.075 × wheel speed. That's not very close to the 12.8 I was hearing.
    But what if I was hearing the second harmonic of it? 12.15 is sort of in the ballpark. And there's some room for slop, seeing as I got my 12.8 by ear matching pitches with a tuner, going by the speedometer display and the nominal revs per mile of my tires. But I'd prefer not to have to handwave away more than 5% of slop....
    But there's one thing about this bearing I've left out. It's an angular-contact ball bearing. The races are shaped with higher shoulders on one side so the bearing handles thrust along the shaft axis, and not just radial loads. That means the balls actually don't roll in the same plane as the bearing, but at an angle to it:
    And that means, effectively, the outer race radius is a little smaller, and the inner race a little bigger, than what I physically measured. The radii that matter are where the races meet the green line.
    What that angle is, I can't easily measure. A Koyo document gives standard contact angles for their bearings as 15, 30, or 40 degrees. If I had to guess, I'd guess 40 - the shiny path on the race goes pretty far down the shoulder. So what does that do for the dimensions?
    I'd better start by taking the cage radius to be my originally measured outer race radius minus the original ball radius (no correction yet): 34.65 - 5.55 = 29.1 mm. But from here out, my 'effective' ball radius is going to be (5.55)(cos 40), or 4.252 mm, and 'effective' inner race radius 29.1 - 4.252 = 24.85.
    Now the cage speed will look like wheel speed × ½(24.85)/(24.85+4.252), or 0.427. There are still 15 balls, now making whacks at 6.405 × wheel speed. I still think I could have been hearing the second harmonic, which is now, hmm ... 12.81. Now that, I don't feel a need to handwave away.
    So for those keeping track, if you find yourself with a speed-dependent growly tone around 12.8 times wheel speed (or g, c, and d, slightly flat, at 30, 40, and 45 MPH on stock tires), I'll vote for a front wheel bearing. I never got to take my old rear apart to see if the 10.8 I heard there was also characteristic of its dimensions, but I'm thinking probably yes. That'll be e, a, and b at 30, 40, and 45, again slightly flat.
    -Chap
  6. bwilson4web
    16,362
    Could you give a quick summary of the costs and labor associated with this?
    Have you read Good Prius Friend Hobbit's write up on his bearing repair?
    Wheel bearing
  7. ChapmanF
    18,536
    Thanks! I didn't happen to remember where I'd seen that or re-read it for this job, but I definitely remember reading it a while back. All Hobbit's write-ups are great. I notice he needed a right front and it was louder turning left; mine was left front and louder turning right. If that pattern holds for more than two anecdotes, it could be another early hint for which bearing is going.
    His write-up is for an NHW20, and from it we see that the NHW20 has got "generation 3 hub bearings" at all four corners. The NHW11 has those at the rear, but "generation 1 hub bearings" at the front. (Those terms seem standard across the bearing biz; the Toyota-supplied bearings are from Koyo but I gave links to SKF's pages instead just because they've got much more informative pages on their site. Honestly, Koyo seems to have the least informative site of all the bearing players.)
    Having now done one rear and one front on my NHW11, I'll offer a generalization:
    • Generation 3 hub: replacement labor ⬇, parts cost ⬆(just one part, but it's ~ $250)
    • Generation 1 hub: parts cost ⬇, labor ⬆(bearing is ~$40, other misc. parts, multi-step teardown, press work)
    The rear job is really nothing more than (0) wheel off, (1) drum off, (2) four bolts out, (3) swap new hub for old, (4) torque four bolts, (5) drum on, (6) wheel on, (7) confirm ABS signal. Step 3 is the one that's just as easy at it sounds if you're not in the rust belt, and otherwise consumes 90% of the time and cussing for the whole job.
    Front job: (0) unstake and crack axle nut loose (1) wheel off (2) caliper off (3) disc off (4) axle nut off (5) ABS sensor out (6) tie rod end out (7) ball joint from lower arm (8) axle out of hub (9) knuckle from strut (10) hub pressed from bearing (11) snap ring out of knuckle (12) bearing pressed from knuckle (13) new bearing pressed in (14) new snap ring (15) hub pressed in (16) knuckle to strut (17) axle to hub (18) ball joint to lower arm (19) tie rod to knuckle w/ new cotter pin (20) ABS sensor (21) new axle nut on firmly (22) disc (23) caliper (24) wheel (25) axle nut to 159 ft lbs and staked in place.
    For step 10 I carried the knuckle, new bearing and new snap ring into the neighborhood Carquest shop and came back after step 15. The cussed-rust-belt steps are 10, 11, and 12, which I didn't have to deal with. I think I can guess the number of pieces the old snap ring came out in from the number of pry-tool gouges in the old bearing's inboard seal when I picked the stuff up. Too bad I missed out on that part.;)
    All the steps I did myself went smoothly and nothing was difficult from corrosion. All the nuts and bolts took a touch of persuasion with a breaker bar and then came out smoothly with really clean threads. I don't know what Toyota makes their nuts and bolts out of or plates them with, but whenever I get around to building my underground world-domination lair, I'm using their bolts.
    I tightened my puller moderately on the tie rod end and walked off to find my safety glasses and a hammer, and when I got back it had popped itself out. (y)I never had to disturb the ball joint from the bottom of the knuckle and neither did the machinist; it's stubby enough to not get in the way of the press work. Where it attaches to the lower arm it's just two nuts and a bolt and nothing tricky to separate. I did confirm that it didn't feel loose and moved smoothly while I had the chance.
    • Bearing 90080-36136 $38
    • No-reuse snap ring 90521-79002 $2
    • No-reuse axle nut 90080-17238 $5
    • No-reuse tie rod end cotter pin 95381-03020 62¢
    • Shop work $35
    • Knowing which bearing to replace: PRICELESS
    While I didn't end up needing the ball joint out, in case you ever do its slightly larger cotter pin 95381-03025 is 66¢.
    At those prices I went ahead and bought parts for both sides. Like Hobbit, I'm not planning to actually do the other side until needed--after all, this bearing didn't go until 50,000 miles after the first one--but the parts are cheap and why pay twice for shipping? By contrast, at the price of the rear hub assembly, I'll leave buying that till I know I need it.
    There are two tool sets made, the OTC Hub Tamer and the Ken Tool Hub Shark, to eliminate the work at a press and do steps 10-15 right on the car (also saving you steps 6, 9, 16, and 19), but they're expensive for DIY and none of the parts stores in town had them listed among their loaner tools. The OTC is also sold in the KD brand for a less premium price, but I could still take ten of these to the shop for that money and my car hasn't got that many wheels. Anyway you still have to get the old snap ring out and, seeing what a fight it gave the machinist, I'm glad I wasn't trying to do the same thing in close quarters with the knuckle on the car. These tools are specific to the generation 1 hub style so if my next car's likely to have the generation 3 style all around, I can go without.
    I did buy a Schley Products 65420 axle nut unlocking tool ($17) for dealing with the staked axle nut. There's a 65400 kit providing that and a nice heavy 12 pt 30 mm socket if you don't have one (12 pt is required for the nut). The socket is impact-ready but all I needed was a breaker bar and a 1.5 m persuasion enhancer to get it loose.
    I ended up doing some brake and suspension work while I was at it, for more than I spent on the bearing job itself.
    -Chap
    mroberds, rogerdpack and aswresm like this.
  8. robert mencl
    robert mencl Member
    173
    49
    hartland me
    2002 Prius
    I
    Chap, I liked your description of the relationships of velocity inner, outer race and ball bearings.
    Here is a little related quiz for you...a bulldozer is travelling over the field at 10 mph. What is the speed of the tracks at the bottom, where they are on the ground.
    And at the same moment, what is the speed of the track at the top, where they are not on the ground? Robert
  9. ChapmanF
    18,536
    Is this a trick question? Maybe it's an icy field and the bulldozer is skidding? Or it's in an airplane? After all, it's only traveling "over" the field. :)
    Umm, start with the answer to the first part. Subtract the vector velocity of the possibly skidding or flying bulldozer. Take the dot product of this with the unit vector in the direction the dozer happens to be pointing. Negate. Now add the dozer's overall velocity back in.
    Veterans of this quiz get a certificate allowing them to think about the ICE, MG1, and MG2 in the Prius transaxle. :)
    -Chap
    Edit: on second thought, the dot product shouldn't be necessary. Or put another way, if it ends up making any difference in the calculation, there are bigger problems than a skidding bulldozer.
    #29 ChapmanF, Jul 12, 2014
  10. robert mencl
    robert mencl Member
    173
    49
    hartland me
    2002 Prius
    I
    um, you're onto it, Chap...(I was inspired to this by your bearing assembly diagrams)...the speed of the dozer track relative to the ground on the bottom of the track is always zero, whether the dozer is moving or sitting still. (Same thing with the bottom of your Prius tires, unless you're peeling out) and the speed of the upper part of the track is 2x the speed of the tractor. (same thing with the top of your Prius tire)....track links have to accelerate from zero to 2x machine speed in an instant when the drive sprocket picks them up, which is why they wear out.
    On your bearing thing these forces are radial and constant and things wear much better.
    I guess I hijacked your thread on bearings. But I'll take you up on the MG1/MG2 thought certificate, especially if Carolyn Coquillette is lecturing. R.
  11. ChapmanF
    18,536
    Hmm, I'd have thought their velocity component in machine direction goes from zero to twice machine speed over half a sprocket revolution (machine speed + (sin θ)(machine speed) for θ from -π/2 where the sprocket catches up with it on the ground to π/2 where it leaves the sprocket on top), and back down to zero the same way where the other sprocket lays it down. Of course there's more going on, like going abruptly from having no centripetal acceleration to having some. My head hurts, I need to relax and think about bearings.
    Two of three falls for who sits in front.
    -Chap
  12. yankkesrule
    yankkesrule Junior Member
    Masshole
    2001 Prius
    For future reference. 90% of the time I can tell which bearing is faulty by (wheels off the ground) spinning the wheel and grabbing the spring(suspension). Vibration from the bearing transmits through the knuckle/etc and can be felt in the spring. Rarely I can't tell and the. I'll use my wired chassis ears set. For those of us who aren't engineers.
  13. MarcSmith
    MarcSmith Active Member
    471
    150
    Northern VA
    when you take a turn to the right, you load up the left side of the car...if the noise increases when you turn right then the failing bearing is on the left side.
  14. robert mencl
    robert mencl Member
    173
    49
    hartland me
    2002 Prius
    I
    I jack one front wheel up, leave 3 wheels on the ground. Run engine and spin tire at 25 mph, then do the same on the other side. You will easily hear the offender.
  15. ChapmanF
    18,536
    I have to admit I didn't try that (though I did spin the unloaded wheels by hand). Still need another method for the non-driven wheels though.
    Honestly, now that I have the wireless stethoscope, I think I'm a convert, and will probably break it out first thing next time, skipping other methods. It gave me an unmistakable answer pretty much instantly, with everything else fuzzier or more equivocal (I've even seen posts reporting exceptions to the 'opposite your turning direction' rule).
    -Chap
  16. aswresm
    aswresm Junior Member
    2002 Prius
    I
    @ChapmanF Do I still have to buy the Hub assembly along with the wheel bearing as one unit or just get the bearings by itself??
  17. ChapmanF
    18,536
    For the front, you buy a "generation 1" type hub bearing (I gave the part number in the post above, 90080-36136, about $38) plus the snap ring, cotter pins, and axle nut listed - did you read the post?
    For the rear, what you're buying is a "generation 3" type hub bearing, which comes in the form of a bolt-on assembly with the ABS sensor, and runs around $250 or so.
    -Chap
    aswresm likes this.
  18. royfrontenac
    royfrontenac Active Member
    247
    100
    Kingston Ontario Canada
    2001 Prius
    Hi Roy from Canada here --- could you give me the information from the equipment you are using to pick up the sound, I would like to make a similar detection scheme should I have a wheel bearing problem.
    I used to work for a company that did vibration analysis on rotating equipment such as large fan assemblies, electric motors pumps etc. I used a instrument called an IRD analyser that gave a readout of vibrations in mils per second. You would pick up the frequency of the rotating body or multiples of that frequency. In the case of bad bearings it would depend on the type of bearing, roller or ball or sleeve. In a roller or ball bearing there are a number of balls or rollers that are turning, if one or more roller or ball is broken or chipped - as it rolls around it creates random frequencies depending on the number of defective balls or rollers as well as a multiple of the rotating speed. Also to confuse things, the chipped or broken balls change position as they rotate creating multiple vibrations at very high frequency signals. Loading or unloading the pump/motor/fan would also affect the readings taken on the bearing housings. Your readings from front to back bearings reflects(I think) the number of balls or rollers in the bearings,
    As you have found out the level of sound is the best indicator and not the actual sounds frequency, so the microphone is the best way to determine which wheel is causing the problem.
    The best way is to heat the bearing in an oil bath, the expansion of the bearings inner race will allow a few thousands clearance to allow it to be slipped on by hand using oven mitts. Cooling the shaft journal with a co2 fire extinguisher could also be done but is not as effective as the oil bath. Heat to 500/600 degrees F and slip it on quickly - be ready with a pipe that matches the inner race to pound it on if it seems a little tight. I have not changed any bearings in my 3 prius cars yet, my experience came from changing large bearings in electric motors and generators and pumps in an electric motor repair shop. We also used a device called a Reco induction heater where the bearing was heated electro magnetically ( not somthing the average person would have at home), it was very quick - could install a 6 inch bearing in 5 minutes - oil heating takes longer.
    #38 royfrontenac, Jan 3, 2015
  19. ChapmanF
    18,536
    In this case, it's the bearing outer race that presses into the knuckle. The drive shaft through the inner races is not an interference fit. Toyota's instructions are to go ahead and use a shop press without any special attention to heating first. The real wild card in how nicely it comes out will be corrosion of the bore and snap ring.
    The really best way for many people will be to drop off the knuckle, new hub bearing, and new snap ring at your local auto machine shop and say "let me know when I can pick it up." :) BTW, the ball joint doesn't really get in the way of press access to the bearing - at least, my local machine shop had no trouble doing the press work with the ball joint in place, so that doesn't need to be removed unless it seems worn and you want to change it.
    -Chap
  20. Patrick Wong
    18,210
    6,513
    I'd much rather pay the shop $20 or whatever is the going price rather than trying to heat an oil bath up to 500 degrees F which does not sound like a really safe activity in a home environment.
