Help please! Red triangle and other lights...
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Prius2006GuitarGuy, May 13, 2025.
  1. Prius2006GuitarGuy
    Prius2006GuitarGuy Junior Member
    Sweden
    Hey!
    Not sure if this has anything to do with it, but I took some 12% vinegar, mixed with RO-DI water and cleaned the glasses, windshields. Then I took the cloth, at this point soaking and smelling of vinegar and threw it in the boot.
    Went to a shop for around an hour and came back to the car, rolled the windows down as the whole car was smelling of vinegar, drove about 500 meters and suddenly the dash lit up like a christmas tree,
    I had a big f'ing red triangle
    an exclamination like this ((!)) in yellow
    VSC in yellow
    I stopped the car in about 100-150 meters as I was in traffic and couldnt immediately pull over.
    Stopped the engine, waiting a while, started up and again got all the lights, I was around 5km from home.
    Went to youtube and one video said to reset the car and see if the warning lights come again, so I followed that tut and disconnected the cable next to the battery, waited a few secs and reconnected it.
    Waited a few mins, started the car and all the lights went off.
    drove around 5km home, parked it, ran diagnostics in Autel (see attached file) and now posting it to you guys here.
    What can the problem be? Is the car kicking the bucket? First thought was maybe the water pump needs changing but am not sure... please advise!
    Edit: found a pic on google, it looks exactly like this: Screen Shot 2025-05-13 at 9.28.29 PM.png
  2. saneesh8
    saneesh8 Member
    201
    52
    Allen, TX
    The pdf file, it says Engine and ECT fault error,but no details. Can you click on that "Fault" and retrieve the codes and post it here?
    When my 2009 got this kind of lights, it was the throttle body errors,. First time was stuck and second time the sensor. It will go so "fail safe" mode and on start again, if good, it works fine. It can show this for any faults. The first one i got was with the inverter pump.
    So scan it by clicking the "Fault" and post it here.
  3. Prius2006GuitarGuy
    Sweden
    I'll run the scan again when I get in the car tomorrow, looking in the "history" tab of the app it says:
    P3000
    System : Hybrid control
    Description: Battery control system
  4. Brian1954
    Brian1954 Senior Member
    2,304
    919
    South Central PA, USA
    The next time the warning lights come on, use your scanner to read the codes before you clear them. When the red triangle (master warning light) comes on, there is a problem with the hybrid drive system.
    saneesh8 likes this.
  5. Prius2006GuitarGuy
    Sweden
  6. Prius2006GuitarGuy
    Sweden
    Looks like it's the damn hybrid battery :(
    496513322_705288691898224_1786205012813733103_n.jpg 495072963_1104860278348602_1225514878015111223_n.jpg 496509742_1286540752905879_5742148768087039349_n.jpg 496512456_1944701849681873_3973368241809312577_n.jpg 496511175_1491170792026209_4466223968254633091_n.jpg 495072521_1231723192288046_4042959873791672729_n.jpg 496509826_665986916423431_922937894324611190_n.jpg 496509044_1049637370423892_6287188370624854991_n.jpg
    Brian1954 likes this.
  7. saneesh8
    saneesh8 Member
    201
    52
    Allen, TX
    2006 model. How many miles on it? Was it driven daily?
    May be you can rebuild the battery.
    Part number for battery is G9510-47033. Local dealer here in TX, it is $1639, but they won't ship. Another one is https://parts.capovalleytoyota.com/oem-parts/toyota-battery-g951047033 . They will ship. Check your local dealer first before going aftermarket route.
    #7 saneesh8, May 15, 2025
  8. pasadena_commut
    pasadena_commut Senior Member
    2,699
    806
    Southern California
    First, you can probably ignore the HVAC error,that is probably the sun sensor which fails if the test is done in the shade.
    12% vinegar? Pretty concentrated. However, you didn't use it like that, you diluted it, to what? Was it a warm day? There is a problem seen frequently on Prius cars that live in humid hot climates where corrosion on the connector to the little computer in the battery breaks the pack. Sweden wouldn't normally be very humid, but if you left a rag saturated with vinegar in the trunk on a warm day it might have resulted in "accelerated aging" of the component which is prone to corrosion. I mean, if I needed to see how fast a piece of metal would corrode in air I would have done something very much like that. So it might not be one or more modules which have failed, it could be that corrosion.
    Or the rag might have nothing to do with it and some modules have gone bad. How old is the pack? If it is original then it was living on borrowed time.
    Note: replacement pack does not have the electronic parts, those are transferred from the existing pack. If the little computer has gone bad you will need to get one of those too.
  9. Brian1954
    2,304
    919
    OP lives in Sweden.
    The OP created a new thread concerning replacing the hybrid battery. https://priuschat.com/index.php?posts/3535963
  10. Prius2006GuitarGuy
    Sweden
    Yup, it was a bit warm, 15C / 59F.
    Diluted to around 5%.
    But it was left in the car just for an hour or two on a soaking rag(after I wiped the windows and windscreens)
    Oh damn!
    Got a pic or instructions on how I can check if this is the problem? Would hate it if I got a new battery thats not needed and this is the problem...
    No idea, we bought the car 9 months back and it's gone through a few owners in the past 19 years.
    Where does this little computer reside, maybe I can ask the seller to send it with that...
    Thanks!
  11. pasadena_commut
    2,699
    806
    Southern California
    Here is one thread about that
    Corrosion/burn on Wire Frame No 2 Plug/Ecu | PriusChat
    The object being held in the hand in the pictures is the guts of the ECU (little computer) which lives in the electronics section of the battery. I believe the 4 screws holding that ECU together are JIS standard, even though they look like Phillips head. I tried to open mine using Phillips head bits and couldn't do it without risking stripping the screw heads. However, there was enough of a gap in the case to see that the connector pins on the inside were not corroded.
    There is a date code on the pack, you could see when yours was made (but maybe not the age of the modules if some or all have been swapped)
    HV Battery Date Code | PriusChat
  12. Prius2006GuitarGuy
    Sweden
    Damn, sounds like I won't know if thats a problem till I open the battery pack... yes?
  13. pasadena_commut
    2,699
    806
    Southern California
    I believe there are some indications of that corrosion problem from some of the voltage readings one can get with Techstream or, I assume, the AP200. P0A80 means the pack is seeing some out of range voltages. That can happen if the module is bad or the sensing wires for the module are bad - anywhere along their length, but usually at either the module end or the end that plugs into the ECU. For a diagram see the 4th post in this thread:
    Hybrid battery No. 2 Frame wire voltage sensor HACK | PriusChat
    When modules are failing usually it will be off by just a little, like .5 volts different from another module, whereas if the sense wires are busted it may read 0 volts or some crazy voltage.
  14. Prius2006GuitarGuy
    Sweden
    Thanks! Will check it out!
  15. saneesh8
    saneesh8 Member
    201
    52
    Allen, TX
    Detailed steps..
  16. Prius2006GuitarGuy
    Sweden
    Thanks!!
  17. Carall
    Carall Active Member
    314
    104
    Harrisonburg, VA
    You can drain the battery down to 40% and see if any of the modules do not differ much in voltage in the torque pro app. By doing this test, it will be clear whether the code P0A80 occurred due to several weak modules in the pack or not. The code P0A80 usually appears when there are several weak modules in the battery pack.
