Error Code P0303 After Oil Change
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Chris Papaya, Sep 23, 2025.
  1. Chris Papaya
    Chris Papaya Member
    78
    34
    Fort Lauderdale
    Well I had a change to go out and look at the engine bay more clearly. Yeah looks like its a head gasket leak. There is almost no coolant left in the tank.
    52,263
    ouch, sorry!
    Chris Papaya likes this.
  3. rjparker
    10,400
    6,515
    That was obvious from your symptoms. Now it's so clear a blind man could see it.
    The question is how long do you want to drive it? Dump the car as is? Quick flip to pass on the hot potato? Low cost replacement JDM with some small risk? Or a top quality rebuilt that will go 150,000 miles?
    Also factor in that hybrid battery.
  4. BiomedO1
    3,999
    2,103
    SacTown, Ca
    Hopefully the previous owner didn't dump a 'stop leak' product into the coolant. If they did a used motor is just the beginning of your repair journey.
  5. Chris Papaya
    Chris Papaya Member
    78
    34
    Fort Lauderdale
    Thank you.
  6. Chris Papaya
    Chris Papaya Member
    78
    34
    Fort Lauderdale
    Ok, so in an interesting turn of developments, on Saturday when I snapped that picture of the coolant tank while inspecting it, it made a loud hissing sound when I opened the cap and a lot of air came out. It was under pressure. It gave me a little bit of a scare.
    However, now that I let out that pressure, it seems like the gasket leak problem has gone away. I started it up right after I opened the tank and the engine did not rattle at all. This morning before going to work, same thing, no rattle. And then leaving work, again, started up perfectly fine.
    Does the engine put the coolant tank under pressure? Is it ok to drive it after I released that pressure? Because it was driving fine. I'm considering clearing out the P0303 fault code and continuing driving it to see if it comes back, but it feels like its back to normal.
    Now with that said, do you think I should still go ahead and tackle the head gasket replacement? I called a place and was quoted $2,500 to fix it.
    However, after studying the repair job I am now more confident that I can fix it myself. The only issue is I don't have a garage to fix it, and I have to cleanout/organize my hoarder aunts garage to have a proper place to fix it (rain/weather) and to start buying all the parts, supplies, and tools I am going to need for this job. As of this point I'm kind of looking at this as a blessing in disguise to where I have some extra buffer/lead time so I can tackle it. More so, it will give me an opportunity to change out other items that should probably be replaced while I am in there.
  7. rjparker
    10,400
    6,515
    Releasing the pressure reduces the amount of coolant pushed into the cylinder as the engine cools off. Reduced loss of coolant means you will drive it with a leaking hg longer and will likely do more damage. Nothing is fixed, the cooling system will allow engine temperatures to rise beyond normal and most people will think everything is great until it seriously overheats and strands you.
    Your engine already blew the gasket once per your seller; it's either still blown because he used stop leak which wore off or it was poorly repaired and blew again.
    #27 rjparker, Sep 29, 2025
    BiomedO1 likes this.
  8. BiomedO1
    3,999
    2,103
    SacTown, Ca
    Your head gasket issue is still there. It's just easier for gases to leak through than coolant right now. Some people remove the sealing o-ring on the coolant bottle to prevent pressurization. When you turn off the motor, the pressurized coolant seeps into the combustion chamber - it can't do that with the motor running - ego the engine stumbles when started then goes away.
    You need to monitor your coolant temperature. Chances are the motor is running hot, just not hot enough to trip the over temp.lamp yet. Normal operating temperature is 190-210F max., over temp lamp goes on around 248F
  9. Chris Papaya
    Chris Papaya Member
    78
    34
    Fort Lauderdale
    Alright 10-4. Well then I am going to start purchasing the tools and parts needed to replace it myself. Thank you.
    @rjparker
    @BiomedO1
    frodoz737 and BiomedO1 like this.
  10. Chris Papaya
    Chris Papaya Member
    78
    34
    Fort Lauderdale
    Hi again. So last week I purchased about $200 worth of tools I'll need for this job. And right now I have most of the replacement parts in my cart from Rock Auto and Toyota Wholesale Direct. I just have a few question about this before I purchase:
    In the video link above, which are the O-rings/part numbers are being shown in the video at:
    • timestamp 23:30 (O-rings embedded on cylinder head underneath timing chain cover)
    • timestamp 32:13 (O-rings embedded on oil filter housing gasket)
    I have been looking on both auto part websites but I can't find them. Is it part of a kit?
    And lastly,
    • Should I replace the PCV valve?
    • Should I apply oil to the threads on the new head bolts before installing them?
    • Should I replace the the timing chain?
  11. Mendel Leisk
    41,809
    The attached TSB has part nos for Toyota engine rebuild gasket kit, and the head bolts as well.
    Note, the kit includes Toyota’s head gasket, which I believe has been revised.
    There’s a popular sentiment that Toyota’s head gasket was “defective”. While it may be partially the case, I suspect the clogged EGR system is the main contributor to head gasket failure, and is tough on ANY head gasket brand.
    Wouldn’t hurt, and only about $10 USD. Attached is a repair manual link for PCV valve replacement. I’ve used a locally available, non-permanent, oil-tolerant thread-lock on the threads (vs the repair manual specd): Permatex Threadlock Blue, surface-intolerant.
    I suspect it’s not strictly necessary to apply anything to the threads, but it does prevent oil-bloom, I found.
    I think too, a new one will have Toyota spec thread sealant pre-applied, so…
    Yes, repair manual (and various YouTube videos) say to oil-soak them.
    repair manual spec for the head bolt “socket” is “10mm double-hex”. A lot of YouTubers advocate a “triple-square”, but that is not optimum. The double hex is readily available. One option: “CTA Tools 9292”.
    Shouldn’t be necessary. Specs are in repair manual.
    the form-in-place gasket that Gasket Masters use (in your linked video, looks a suitable and readily available alternative to Toyota spec, and likely better for DIY, due to much more leisurely cure time.
    the last link in my signature is the full engine section from repair manual. (On a phone turn it landscape to see signatures).
    also linked in my signature, the first EGR related link had repair manual excerpts with info on intake manifold and EGR removal/install, with tips and torque values.
    lastly, indispensable: the @NutzAboutBolts video link thread has numerous related videos, including recently added head gasket replacement. (It’s pinned at top of 3rd gen maintenance forum).
    #31 Mendel Leisk, Oct 9, 2025
  12. Chris Papaya
    Chris Papaya Member
    78
    34
    Fort Lauderdale
    @Mendel Leisk
    Wow thank you Mendel! The 3rd gen engine repair manual is super insightful. This helps a lot.
    Ok so I am going to leave the original timing chain, I will buy the double hex socket & oil soak the bolts, and will replace the PCV valve.
    I was planning on buying this Fel-Pro gasket kit from Rock Auto:
    More Information for FEL-PRO HS26515PT1
    I looked in the documentation you referred, but I could not find anything about the 3 o-rings on the side of the engine, nor the 2 gaskets on the underside of the valve cover. (see picture below for reference)
    Does the Fel-Pro gasket kit I intend to buy come with those? Sorry, I'm just having trouble finding replacements for those.
  13. Mendel Leisk
    41,809
    If I’m ever needing to do this I’ll opt for the Toyota gasket kit, use the (included) Toyota head gasket.
    one thing, the kit’s content while complete and OEM, is not identified, item by item. There is thread here, someone’s gone through it, done a wonderful pictorial index. I’ll try to find, believe I made a pdf of it too.
    addendum: some notes on my phone:
    Latest head gasket part no, gen 3 Prius:
    11115-37062
    From post 49 here:
    2013 Prius Two Head Gasket Set Part Number? | Page 3 | PriusChat
    Engine Overhaul Gasket Kit:
    04111-37325
    Engine Valve Grind Gasket Kit
    04112-37254
    2013 Prius Two Head Gasket Set Part Number? | Page 2 | PriusChat
    CTA Tools 9292 10mm Head Bolt Wrench
    #33 Mendel Leisk, Oct 10, 2025
  14. Mendel Leisk
    41,809
  15. Chris Papaya
    Chris Papaya Member
    78
    34
    Fort Lauderdale
    Just wanted to give you guys an update, so I ordered most of the tools I will need but did not get to ordering the parts due to an uncanny surreal and unbelievable set of circumstances in my life. But throughout this ordeal one silver lining is I have acquired a free car which coincidentally happens to be a 2010 Toyota Prius with 126K miles on it. It has a check engine light which turned out to be a P0037 which is a bad O2 sensor which I'll have to fix later. But now I am less stressed about doing the head gasket as I'll have a backup car for my daily commute in case things go south. Its crazy how life changes moment to moment.
    Will update once I ordered the parts and complete the job.
  16. rjparker
    10,400
    6,515
    Don't let the 2012v sit too long where you lose the hybrid battery. Critters chewing wires is another concern on an idle car.
    A 2010 hatchback should give you better mpg at the expense of ride and carrying capacity. If the v is otherwise nice I would get it running again.
  17. Chris Papaya
    Chris Papaya Member
    78
    34
    Fort Lauderdale
    No I start it up like ever couple of days. Yesterday I drove it around a bit and worked on it. The good news I think I fixed the P0037 O2 sensor code. I went under the care and saw a wire harness dangling so I clipped it back into its socket. I'm almost certain it was the O2 sensor. I cleared the fault code and hoping it doesn't come back.
    However, the bad news is that when I looked under the car I saw the high voltage cable was partially melted. It was damaged from a fire at my fathers house. However it drove back fine from Tampa to Fort Lauderdale. Does this look bad?
  18. rjparker
    10,400
    6,515
    #38 rjparker, Nov 30, 2025
  19. Air_Boss
    Air_Boss Senior Member
    4,218
    1,188
    New Yawk
    Odd. No fire artifacts other than the melted orange HV cable cover.
  20. Chris Papaya
    Chris Papaya Member
    78
    34
    Fort Lauderdale
