12v Battery Is Discharging, Re-Charge Now !
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by Rob43, Apr 18, 2020.
  1. Halcykon
    Halcykon Junior Member
    35
    Sugarland
    2018 Prius
    Testing:
    4/24: 12.46V @5:30pm. Outside weather: 91F
    4/25: 12.58V @4pm Outside weather: 77F (I'm really not sure how my voltage went up 0.12V. My car was left untouched. I triple-checked all measurements. Maybe my multimeter is too cheap)
    4/26: 12.53V @10pmOutside weather: 66F
    bisco and Rob43 like this.
  2. Rob43
    Rob43 Senior Member
    1,373
    1,050
    VA, BMW Race Car, BMW R1200R, BMW 330Ci, Ford F350
    2013 Prius v wagon
    I'm personally not worried about the Very High 11 volt range, which it might be at in the morning for me. But I would be concerned for anyone below ~11.5 volts, there of course is an exact Low Voltage tipping point, hopefully as a community we'll find it soon.
    Rob43
    Hicksite likes this.
    52,841
    but the tipping point is under load, and may not correspond to an exact static value.
    52,841
    this seems very good so far, albeit a bit low for a newer battery
    Halcykon likes this.
  5. Rob43
    Rob43 Senior Member
    1,373
    1,050
    2013 Prius v wagon
    OK, this morning right before my Prime was started up, it dropped from 12.08 to 12.02 volts.
    Rob43
  6. Hicksite
    Hicksite Member
    176
    2020 Prius Prime
    Weirdly mine was up from 12.31 to 12.32 from yesterday to today. Probably measurement error by my cheap tester. Anyway, took a 40 minute drive and it went up to 12.55.
  7. Salamander_King
    Salamander_King Senior Member
    11,024
    8,978
    New England
    So at my first 12v test, I was getting a quite wide range of reading depending on what device I used.
    12v battery health observation | Page 2 | PriusChat
    I wanted a very accurate voltmeter, but the $395 price tag on a top of a line Fluke 87V multimeter with +/- 0.05% accuracy was totally out of my reach. After searching for a net, I found this video. Apparently, even el cheapo china made $6 multimeter can be very accurate.
    I looked for the same multimeter, but most are shipping from China. Didn't want to wait for it, so I ended up buying a different el cheapo china made $6 multimeter model.
    Well, using this multimeter on our other car's 12v battery today.
    B-951 cheap multimeter $5.99: 12.67v
    Craftsman model 82141 digital multimeter $20: 12.47v
    Oh well, I still have no idea which device is giving me the most accurate reading.:cry::cry::cry:
    #147 Salamander_King, Apr 28, 2020
  8. Bill Norton
    Bill Norton Senior Member
    2,242
    753
    MONW, Ks.
    2019 Prius
    L Eco
    I work with lot's of test equipment that gets Cal'd yearly with traceability back to the National Standards.
    Here's what I would do if I had a bunch of cheapO meters.
    Bring a dozen quality donuts to your favorite auto shop or electronics repair shop, if you know of one.
    Compare your meters to what their Flukes (hopefully). Be ready to write down the results.
    Since your only dealing with 12 VDC systems, you only need to connect to one battery and start comparing.
    If you want to test the Ohm meter functions bring a light bulb or fuses, but don't wear out your donut welcome.
    Salamander_King likes this.
  9. Salamander_King
    11,024
    8,978
    New England
    Thanks for the pointer. Well, that's an idea, but won't work while I am under lock-down. I was thinking buying something like this. http://www.amazon.com/Comparator-Automotive-Modification-Industrial-Application/dp/B07HGY9G5Q/ref=sr_1_5?dchild=1&keywords=12v+voltage+reference&qid=1588172148&sr=8-5
    Although, I have no idea how such reference module works. Any thought?
    By the way, are those cheapO meters if calibrated, would stay calibrated for a long time? Or do they deviate very quickly. How about those expensive meters??? Do they stay accurate forever??? I think not but I don't know enough about those gadgets.
    #149 Salamander_King, Apr 29, 2020
  10. Mendel Leisk
    42,342
    While my Milwaukee meter was on the fritz*, I picked up an inexpensive analogue (needle style) meter, to tide me over. It's somewhat analogous to CD's vs records: it doesn't have n'th degree accuracy, but it's a lot less fiddly. I get the feeling they'll be hard to come by, in future?
    * What toasted my Milwaukee meter: it has all this heavy-duty sealing, and then inside, the batteries (two AA's IIRC) reside in a semi-open cradle, directly over the circuit board, if you place the meter with the display facing down. The batteries are a pain to access too, screws to remove, lids to pry off. Batteries barfed all over the circuit board, bye-bye Milwaukee. Luckily this happened before the warranty ran out.
  11. Salamander_King
    11,024
    8,978
    New England
    I have couple of those in my drawer somewhere. They are old, but they were more expensive than the $6 digital multi-meter I just bought. They were probably not made in China. In a pinch, it maybe better than digital ones for there is no need to place a battery inside. Searching through YouTube, I just learned that low battery in a digital multi meter can cause inaccuracy in reading, as much as 15-20% off.
    #151 Salamander_King, Apr 29, 2020
  12. T. Williams
    T. Williams New Member
    Bozeman, Mt.
    2019 Prius
  13. Hicksite
    Hicksite Member
    176
    2020 Prius Prime
    Hooked up the new charger (Batter Tender 4 amp) last evening. Disconnected this morning, turned high beams on for 30 seconds and off, and then tested battery. 12.62 volts. Checked battery 4 hours later, 12.92 volts.
  14. bisco
    52,841
    looking good!(y)
  15. Hicksite
    Hicksite Member
    176
    2020 Prius Prime
    Thanks, yeah not sure why the voltage came up after 4 hours.
  16. bisco
    52,841
    maybe 30 seconds of headlights brought it down too far, then it stabilized
  17. Salamander_King
    11,024
    8,978
    New England
    I think that's normal behavior right after you finish charging. Did you open the driver's side door open in order to turn on and off the headlight? If you did, that would have caused enough loads to pull the SOC down from fully charged 12v battery to temporarily show lower SOC of 12.62v which later stabilized to the full charge SOC of 12.92v.
  18. Hicksite
    Hicksite Member
    176
    2020 Prius Prime
    Maybe, but I thought 12.6 was normal for a full charge. Maybe it still wasn’t stabilized after the 4 hours. Does the voltage bounce up and down during the stabilization process?
  19. Hicksite
    Hicksite Member
    176
    2020 Prius Prime
  20. Salamander_King
    11,024
    8,978
    New England
    Look at my chart on 12v Battery Is Discharging, Re-Charge Now ! | PriusChat. The voltage was 13.06v right after the charger was removed. and the voltage stayed well above 12.6v for a long time. I did not open the door or turned on the light during that time. If I did, I am sure the voltage would have come down temporarily, but most likely bounced back to the 12.9v level.
