2005 with Rebuilt Pack, now Codes C1241 and C1310
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by sub3marathonman, Oct 9, 2017.
  1. sub3marathonman
    sub3marathonman Active Member
    557
    75
    I'm hoping one or more of the experts can help with my mom's Prius problems.
    At 98K (on the Prius, she's 89), she fell, broke her wrist, and didn't drive for two months. After the car was put back in use, the hybrid battery was dying. I kept the Prius limping along for the hot two months of summer, and then it finally wouldn't back up, but I just managed to get it going and got it home.
    I found a set of 2010 modules, 89K miles on them, from Bernie at eLearnAid. Bernie is a spectacular guy, completely honest, and very helpful. The modules arrived, perfect condition with meticulous packing. I pulled the pack, replaced the modules, put the pack back together and installed it.
    I promptly had all the problems with the safety plug, even though I was careful. I took it out and reinstalled it several times, and it finally seemed to be fine. I was celebrating like it was 2010!!!
    Until I drove it for about 25 miles. The red triangle came on, the little (!) light and the VSC, so I got it home. Turned it off, but trying to restart it wouldn't go into READY mode. Disconnected the 12V, and drove it again. This time it didn't make it out of the driveway. I repeated the procedure, and got it to Advanced Auto, where they pulled the codes. It indicated ABS. I once again cleared the codes, and tested to see if it happened when i was stepping on the brake pedal. I found out it could happen whether or not the brake pedal was being pushed.
    I got the 12V tested, and it checked fine. I had heard one somewhat unusual story where they had similar codes, emptied the tank, and it was fine. I've got half a tank left, and would be patient enough to drive it to empty and refill it, but for the NEW problem.
    Today, the dashboard went completely dark. I'm not sure if this is somehow related or not, or if a fuse has blown during the 12V reconnection, but this still seems like a secondary problem.
    So, is it also somewhat just a coincidence that the C1241 and C1310 showed up after reinstalling the battery pack? Or is it more the time factor of the Prius not being driven, bringing on all the problems?
    I'd hate to start replacing parts blindly. I've looked into the Torque app, but don't know if that should be the next step to help with the diagnosis.
    52,807
    you probably need tech stream for the correct codes.
  3. 05PreeUs
    05PreeUs Senior Member
    1,097
    565
    MSP
    A quick search on the 'net and Patrick indicates that C1241 indicates a low voltage condition for the 12v battery, specifically for the ABS system. This could be due to something as simple as a connection issue (corrosion etc). As for the C1310, Patrick again points to the skid control (ABS) ECU: "DTC C1310 is logged by the skid control ECU and means the hybrid drivetrain has a problem."
    Link: 2005 Prius generating codes C1241 and c1300 after battery replacement | PriusChat
    Link: Got a C1310 DTC code | PriusChat
    Seems like the DTCs in the skid control did not get cleared??????
    Disconnect the 12v overnight, there are two WHITE connectors to the front side of the battery, simply unplug them both. Plug back in the next morning and if the codes come back again, then more in depth diagnostics will be needed.
  4. sub3marathonman
    557
    75
    I disconnected the 12V overnight, and it did not help with the dark dashboard. However, I did the FOB procedure (Foot on Brake, Lock, Lights On, Lock again, Start) and it now works!!! I'm not sure for how long, but it works.
    So, that turns the attention once again to the C1241 and C1310.
    I've tried to do a bit more experimentation, as I'm thinking about the person who said with new gas the problem went away and has never returned. So I've tried to drive it daily, going a bit easy on the braking. I've gone to 29 miles without the codes, I've gone on several short trips of 6 miles or so, no codes and restarts fine, only to get the code at 26 miles. Finally, it seemed driving in B mode it wouldn't come on, it was only when I forgot and went into D, although that too could be just coincidental.
    So I'm wondering, is the C1241 and C1310 codes enough to cause the Prius to go dead on the road, or into some reduced power mode? Can I burn through the rest of this gas and refill it before I'm absolutely positive I've got to go to the next steps?
    I worry a bit because the other day I stopped to help a dead Prius on the road. She said she was just able to coast into the turning lane, and then it wouldn't restart. I tried with the FOB inserted, and it seemed a bit like the dark dash, as it was just flashing squares where the B,D,N,R would be. I would have tried to disconnect her 12V if it had been pulled off the road, but it was impossible sitting there in the turning lane. If you can believe it, the car not moving, the hazard lights flashing, and people would still pull up behind her, wait and wait, then beep their horn. I was wishing I could have helped her, but even pushing the car to the shoulder wasn't an option across all the lanes of traffic.
  5. sub3marathonman
    557
    75
    I have done more testing and research, and I'm hoping one (or more) of the experts might give their opinion.
    First, I don't really understand why one code C1310 can be related to so many different problem areas. It seems it can range from a bad 12V to bad gas to a loose nut on one of the hybrid battery cells to the ABS ECU to possibly even a failing transaxle that needs replacement.
    So, what is confusing is that the code, along with the C1241, doesn't appear with any consistency. I've driven 29 miles, 26 miles, and now just 2 miles with the code coming on. I've driven in B mode, and the code will come on. It has come on when I've been pressing the brake, and when I'm just driving. It has come on when the car is cold, and after it has been warmed up.
    I've somewhat been trying to use up the remaining gas in the tank and refill it, not that it has a high probability of success, just that it seems a bit easy to do, and in the intervening time I can do more research.
    I've had the 12V tested, and it has tested fine. It is an Optima, just over 14 months old. It was tested while in the car, although the technician who tested it stated he'd have rather had the battery out of the car when he checked it.
    I have rebuilt the pack with replacement 2010 cells, which tested fine. I did not have an easy time putting it back together, as it takes just that bit more strength than I have to push the cells together to get the end plate on. Somehow I finally did manage it, but not until I redid all the cells several times trying to keep them as close together as possible when assembling it.
    Now, according to this thread: 2007 Prius with C1259 and C1310 - any ideas? | PriusChat , it could be a loose nut for a cell sense wire. I was extremely careful. I even purchased an inch-lb torque adapter to be sure. But then I start to wonder. But I wonder more and don't understand why there wouldn't be a code indicating a sense wire wasn't reading properly.
  6. Prodigyplace
    12,711
    11,848
    Central Virginia
    A bad 12 volt battery can cause all sorts of strange codes from a confused computer.
  7. dolj
    dolj Senior Member
    8,635
    4,389
    Wellington, New Zealand
    Perhaps it makes more sense when you understand that the HV Battery ECU did not post these codes. These codes were posted by the ABSVSC/TRAC ECU.
    C1241 means the ABSVSC/TRAC detected low B+ voltage. ––> Check the health of your 12 V battery.
    C1310 means "I am told by the HV Battery ECU that it has problems, therefore I will change my behavior. I posted C1310, so you know why I'm behaving the way I am."
    The C1310 means there is/are HV Battery ECU code(s) set. The fact you don't see it/them means your code reader is not reading the HV battery ECU. Once you have updated your code reader and determined the HV battery codes, you will be in a better position to know where your attention is needed.
    The C1241 indicates that there is an issue with your 12 V battery, regardless of what you think because of the so called "pass" by the technician. Even if the battery is in good condition, it does not stop it being fully discharged, which it is when it is at 12.1 V. Once you have charged or changed your 12 V battery, clear the codes and see which codes come back.
    #7 dolj, Oct 18, 2017
    Prodigyplace likes this.
  8. wa7ly
    wa7ly New Member
    Green Bay
    So I am experiencing the same exact DTC errors of C1241 and C1310 on my 2007 Prius. I have replaced the aux battery with a brand new OEM Toyota battery reset the ECU and wiped the codes but after about 5 mins of driving the error comes back with the same codes. Also I have performed a signal check when in accessory mode and the aux battery shows 12.7 volts and when the car is Ready mode the output voltage is 14.1 volts. At this point I am at a loss and I am kinda wondering if it is the HV ECU dying on me or the hybrid battery. Has anyone found any fixes to this issue or am I stuck with paying out the big bucks to toyota for a full diagnosis? Any and all ideas here would be much appreciated.
  9. Prodigyplace
    12,711
    11,848
    Central Virginia
    Check the aux battery connections and ground connection to the chassis for the C1241.
    For C1310 you need the codes read by the dealer to determine what the HV issue is.
    Is the HV battery fan clean? If not, the battery may be overheating.
  10. wa7ly
    wa7ly New Member
    Green Bay
    I will c
    I will check and report back later.
  11. wa7ly
    wa7ly New Member
    Green Bay
    Acutally come to think about it if I was receiving any type of temp issues from the hybrid battery wouldnt i receive a P0A82 code?
  12. Prodigyplace
    12,711
    11,848
    Central Virginia
    Not sure. I figures it was something HV battery related that was relatively easy & inexpensive to check. A bad 12 Volt battery can trigger all sorts of strange codes if the computers get confused.
  13. wa7ly
    wa7ly New Member
    Green Bay
    I am confident it is not temp issues because I would be receiving that code too at that point and according to Toyota Prius DTC Documentation it states for a C1310 code is detecting this condition:
    The traction control prohibition signal is received for at least 0.07 sec. when IG2 terminal voltage is10.5 V or more for at least 1.5 sec. and communication with hybrid control computer is valid.
  14. mike w
    mike w New Member
    oakland ca
    did you get this figured out?
  15. Prodigyplace
    12,711
    11,848
    Central Virginia
    They have not been here is 38 weeks. Do not expect an answer from this zombie thread.
  16. mike w
    mike w New Member
    oakland ca
    Did you get this figured out? \thanks
  17. mike w
    mike w New Member
    oakland ca
    this is 2018? sometimes i wonder but if i read correctly, the last post was Nov of 2017? 8 months ago? sorry if i am confused
  18. bisco
    52,807
    the member hasn't been seen since then, so probably not following this thread. try pm'ing them, it should send them an email.
    Prodigyplace and mike w like this.
  19. Prodigyplace
    12,711
    11,848
    Central Virginia
  20. mike w
    mike w New Member
    oakland ca
    yeah that is close to 38 weeks, how time flies
