2011 Gen 3 Prius Model 3: FOB Startup vs Physical Key Security
Discussion in 'Gen 3 Prius Technical Discussion' started by StephenFromCT, Jul 17, 2019.
  1. StephenFromCT
    StephenFromCT Junior Member
    Connecticut
    Several weeks ago I purchased a used 2011 Gen 3 Prius Model 3. A very impressive piece of engineering.
    I have been reading different threads on this site, and appreciate all the advice which is being shared.
    This is my first post. If I am unclear, please ask for clarification. I am looking forward to your good suggestions. Thank you for your time.
    I have decided to accept some inconvenience regarding unlocking the door and system startup, if it means I will have better security.
    1) I plan to use the interior button on the driver's door to lock all the doors and to use only the physical key to unlock the car. I plan to turn off the FOB's ability to unlock the door (currently, the door is unlocked by both FOB proximity or if I press the unlock button; I plan to inactivate both functions).
    2) For system startup, I will hold the FOB close to the Power button when I press the Power button.
    I spoke to an auto locksmith (not the dealer) who said it is possible to have the physical key copied (using a laser cutter) and that the key will fit on a regular keychain. This is okay with me, since the greater torque, provided by the larger key "handle", will make the key easier to turn after it is inserted in the door lock cylinder.
    I have already confirmed that the FOB RFID works as expected. If I remove the CR1632 battery from the FOB the car still starts up, but only when I press the brake and have the FOB near the Power button when I press the Power button. (I did not confirm that I could drive the car, but the display said "Ready". The 12 volt battery seems to be fine, but I have not confirmed the resting voltage.)
    I have not decided if I will ask the dealer to turn off the wireless door locking/unlocking feature, or if I will do it myself. I found a thread which describes the procedure. I will update this question after I locate the link.
    So in summary, I have one FOB which works well (wireless entry and proximity hybrid system startup). I think the above plan will work well to achieve my goal of security, but unfortunately the second FOB which the seller gave me does not work.
    The second FOB, which has the same FCC ID imprinted on the plastic case. The seller said the CR1632 battery needed to be replaced, but that did not fix the problem. I swapped the two batteries between the working FOB and the second FOB. The working FOB works with both batteries, but using both batteries the second FOB neither unlocks the door, nor does it start the car.
    The red LED works on the second FOB, so at least some of the circuitry is working. I do not know if the second FOB was immersed during a laundry cycle.
    Using the second FOB I cannot unlock the door (neither by proximity nor by pressing the unlock button). The second FOB does not activate the hybrid system.
    It is as is the second FOB is no longer "recognized" by the car. I do not know if there is a specific word to describe this process? Is it possible for a car to lose a FOB registration?
    So the question is how do I get a second working FOB? My understanding is that since the FOB has been used it is not a "virgin" FOB, so there is no easy way to ask the car to register the second FOB.
    However, after reading different threads, my understanding is that the second "non-virgin" may be used if the ECU is reseeded. It is not clear if a auto locksmith the proper credentials can do this.
    I believe there is a limit to the number of FOBS which can be registered by each ECU. I do not know if additional FOBS were registered by the first owner, or if only the two original FOBS were used.
    I have not been to the dealer, but I am guessing the cost of a new FOB will be high.
    I am reluctant to drive the car until I have two functioning FOBs. It is clear that without a functioning FOB the cost to reprogram the car is very high.
    Please help, and again, thanks!
    #1 StephenFromCT, Jul 17, 2019
  2. PriusCamper
    PriusCamper Senior Member
    13,450
    5,430
    Pacific Northwest, USA
    Wow... So you don't want to use anything but a mechanical key for "security" but you don't want to drive the car without two functioning FOBs, which you plan to disable as by removing the battery for "security?"
    The lock & unlock system allows several different way for you to use it and this redundancy, much like having two working FOBS, ensures that no matter what circumstances may arrive in the future you're going to have multiple ways to access the vehicle and use it.
    As for the need for improving Security of an already secure system, let's talk facts... Connecticut is ranked 28th out of the 50 US states with a rate of 203 thefts of all vehicles per 100,000: • Motor vehicle theft rate in the U.S. in 2017, by state | Statista Also the top 10 most commonly stolen cars are not Prius: The most-stolen car in every state in 2017 | CarInsurance.com
    Prius statistics are very low ranked in general in terms of theft concerns... So it makes no sense to me why you'd intentionally sabotage your redundancy/ability to safely unlock and drive your car, while at the same time not wanting to drive the car unless you have more than one functional FOB?
    Perhaps the problem is that your car runs so well, you're sitting around thinking about what could happen, rather than just enjoying a safe reliable car with a very low statistical risk of being stolen?
    Perhaps instead you worry about the EGR valve and how it needs cleaning, as well as an oil catch can, to ensure your head gasket doesn't blow out? Not addressing that fatal flaw in in Gen3 Prius is statistically a way, way greater risk then the security concerns related to key FOBs.
  3. ASRDogman
    ASRDogman Senior Member
    8,057
    4,085
    What type of security do you hope to achieve by NOT using the FOB???
    I personally think you are wasting your time, and the convenience of the FOB!
    You could install, or have it installed, a security system. You can also use the "CLUB".
    A device that goes across the steering wheel that pretty much makes it impossible to turn the
    steering wheel very far.
    There are other devices that disable the car until you put in the code or have another FOB.
    If someone wants to steal your car, they will steal your car. Why are you so worried about it?
    If I may ask? Are you in a high crime area?
    If you get TechStream you'll be able to program the 2nd FOB. Unless it is damages. They you'll
    have to purchase another one and program it, again with TechStream. Or a good locksmith or Toyota.
    Certainly the locksmith will cost less.
    How do you plan to "turn off" the key FOB functions of locking/unlocking? TechStream??
    PriusCamper likes this.
  4. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    Why disable the FOB functions? It is one of the most practical parts of the car. Simply walk up to the driver door and grab the handle. Get in the car and push the button. There is no need to even get the fob out of your pocket.
    Please give us some insight as to what your reasoning is.
  5. StephenFromCT
    Connecticut
    Hello PriusCamper, ASRDogman, and cnc97 (and future readers).
    I am sorry I did not find a way to make the original post shorter. I should have been more clear with my questions, regarding a used 3rd Generation 2011 Prius which I purchased a few weeks ago from the first owner which has one working FOB and one non-working FOB. The seller knew the FOB was not working, but his explanation is that it simply needed a replacement CR1632 battery. (Yes, I trusted him, and did not think of testing the battery from the working FOB in the nonworking FOB.) The trivial explanation is that there was a mixup and that the seller gave me a FOB which was never registered/recognized by the car, but for now I am assuming I have the two original FOBS which came with the car:
    My two questions:
    1) The RFID system for starting up does not require the FOB to have a working battery (which I confirmed by removing the battery from the working FOB). I am wondering if it is possible for a Gen 3 Prius to forget a previously registered/recognized FOB?
    2) The nonworking FOB is not a new virgin FOB. I have one functioning FOB, but want a second one. If there is a sequence of steps which can be used to register the non-working FOB with the car? Is there a way for me to do this, hopefully without Techstream, or do I need to pay an auto locksmith or the dealer?
    So the fundamental question is how to get my second FOB working without spending a lot of money?
    For me the "coolness factor" of owning a Prius are the motors, the engine, and the traction battery. (The 12 volt battery seems to be a weakness). I bought the used Prius for its hybrid technology, gas mileage, and hopefully lowest "total cost of ownership", not for the car's wireless entry or ability to start without turning a key. I care more about the condition of the car (that is never be vandalized). I care a lot less about the convenience of the door being unlocked as I approach the car, because the car can detect the FOB in my pocket. Other forum members have described their feelings that the wireless system causes more problems than it fixes. For example, in a family with several drivers, it can get very expensive to buy FOBs for each person.
    Today, my concerns about security are less important (because for now, the car is safe) and hopefully should not affect your answers to my questions about getting the second FOB to function.
    @PriusCamper, please do not concern yourself about why I am worried about vandalism or theft. I simply do not want MY Prius to be vandalized or stolen. Low crime statistics do not make the crime victim feel better.
    @ASRDogman, for now I would like to assume the second FOB is not damaged.
    To all, I welcome any suggestions for how to get the second FOB to work, is possible, without buying a replacement FOB.
    @ASRDogman, you ended your response by asking how I was planning to "turn off" the key FOB functions of locking/unlocking (the doors). Obviously, there is nothing which can be done to the FOB (except to remove the battery), so the question is how to turn off the scanning function of the car.
    However, in the following post (by user vincent1449p):
    Turn off Smart Key System | PriusChat
    he says "The GenIII Repair Manual has instructions to disable SKS without Techstream, I've just tried it and it also works on our C."
    @cnc97, I wrote most of this response before I saw your comment. Thanks!
    I hope I was more clear about they help I need (getting the second FOB to work). Thanks again, and to all a good night!
  6. bisco
    52,825
    welcome!
    i have never done this, but from what i understand, you can buy a new virgin fob on eBay for $120. or so, and program it yourself or with a locksmith.
    all the best!(y)
  7. ASRDogman
    8,057
    4,085
    Seems to me you are taking away from the car. It's like removing the electric window and installing manual ones.
    But it's YOUR car. :)
    According to that post you included, seems that is when the car will be stored for a period of time.
    Then the system won't be scanning for a signal from the key fob. Which uses the 12v battery, which could drain it.
    I don't believe the 12v battery is a weakness. The only difference in the hybrid is it does not start the car.
    In a non hybrid, the 12v battery needs to have enough amps to drive the starter motor enough to rotate the
    motor fast enough and long enough for the engine to start. After the engine is running, the alternator powers the
    electronics. In both, after you shut the car off, the 12v battery supplies power to the electronic.
    Similar to a house UPS. When the AC power goes out, the UPS DC battery supplies power to the converter to
    supply AC power to the device.
    Since only 1 person at a time can drive the car, how many fob's do you really need? Most manufacturers supply 2.
    I guess they figure there will be 2 main drivers. WHY would your kid need his/her own fob for YOUR car? They could
    use yours.
    I bought my Prius for fuel mileage. I drive 5-600 miles per week. I averaged 20mpg in my van. I average 47mpg in
    the Prius. More than double! So it cut my fuel cost 55-60%. I sacrificed space, which at times I really miss! But am
    happily surprised at just how much the Prius does have.
    Before I got the van, I had manual windows, door locks, no cruise control. I did not miss these items. Now that I've had
    them for a while, I do NOT want to do without them!!! I would be okay without the power windows and door locks.
    But I cannot do without the cruise!
    I have no use for power seats. 99% of the time my drivers seat does not move. It only move it when I vacuum.
    I like the power windows and door locks. I like NOT having to use the key to open the drivers door. I wish they had it
    for the passenger side also.
    To me, the Prius is a GREAT car! I love all the extras! It is an EASY car to work on! And has been very reliable.
    But each person has the right to do whatever they want to their vehicle.
    I don't think there is a cheap way to program a key fob unless you have your own copy of techstream. Which is not
    that expensive. $1,2,3,4,5,600 to program a key is just crazy!!!! But you can't start or drive the car without the fob! :)
    #7 ASRDogman, Jul 18, 2019
  8. PriusCamper
    13,450
    5,430
    There used to be a service on Ebay that if you'd mail them your FOB and $20 they'd wipe it back to brand new and then you can reprogram it to match up with your vehicle, but haven't seen that service in a while. That's what you will need to get the second FOB working...
  9. StephenFromCT
    Connecticut
    This thread is getting long, so for future readers I should say I am the original poster.
    @PriusCamper, thank you for sharing the possibility of using an eBay service to reset my FOB. I prefer try to find a local business which provides the same service, because I do not want to take the risk that the FOB gets lost in the mail. If the business is in a neighboring state I will have a reason for a road trip. The best strategy may be to buy a virgin FOB, and after that is working, then to solve the problem of the non-working one.
    @ASRDogman, thank you for sharing how you use your Prius, and for describing which features you enjoy the most. I agree that for you having the proximity door unlock feature on the passenger side would be useful. I wonder if that is an option which can be activated. Does anyone know? If I am able to accomplish what I am hoping to try then to open the passenger door I will need to walk around the car to use the key to open the driver's side door.
    One of my biggest questions when comparing the Prius to a Honda Fit was automatic vs manual transmission. I enjoy driving a car with a manual transmission, because shifting keeps me more connected to the car. The extra cargo capacity of the 2nd generation Honda Fit almost pushed me in that direction.
    Yes, the link I provided to Vincent's SKS non-Techstream inactivation procedure is most useful to owners who will not be using their cars for several weeks, or said a different way, most useful to owners who will not be using wireless SKS to open the car doors for several weeks. One reason I am hesitant to try it myself is that I have not found a similar series of steps to reactivate the SKS door unlocking feature. By inactivating SKS I may extend the life of my 12V battery, a clear benefit, but that is not my primary reason.
    I have downloaded several PDFs from the 2010 Gen 2 Prius Service Manual, but it is unclear what I am missing. I think it is worth the $20 for two days of access the Toyota Prius Tech Info site. With some luck, if I download all the PDFs then I will find the procedure for reactivating SKS. I will also keep my eyes open for an option to activate passenger side door unlocking.
    @ASRDogman, you are correct, only one FOB is needed because only one person can drive at any moment. However, I have read posts from users who suggest having at least three working FOBs. One for regular use, one for backup use (when the primary FOB is temporarily misplaced), and one emergency FOB. Three FOBs may be excessive, as well as expensive, but I think having at least two is necessary. I want to avoid having to pay a lot of money to the Toyota dealer when the ECU needs to be replaced and the two FOBs need to be replaced.
    Remember, at the moment I have only one working FOB, and it is still unclear if the second FOB is not working because it was accidentally switched by the seller or if the car's ECU (?) somehow forgot the second FOB. Still searching for similar experiences by other owners.
    And finally, the reason I said I thought the 12V "deep-cycle" battery is a weakness is that some owners seem to be reporting the need to replace the batteries more often than I think regular "high current" 12V are replaced. For some fun, I may try to open the hatchback from the interior, something which will be needed if I drain the 12V battery.
    It is clear to me that the condition of the 12V Prius battery affects fuel efficiency, because if the 12V battery is not charging well, then more energy is used in the attempt to charge it and less energy is used to charge the large hybrid battery. I saw at least one report which suggested that if a car needs a boost (eg. if the 12V battery is drained) that this may reduce the useful life of the 12V battery. However, the reduced lifespan may be related more to the deep drain and not to the boost.
    I need to learn more about emergency 12V booster packs. To optimize 12V battery life is not clear to me if or how climate temperature or driving habits (which affect hybrid battery SOC) affect the 12V Prius battery. Still, so much to learn.
    The prices for 12V deep-cycle batteries seem to vary from $200 to $300, but I hope that a $200 battery should last more than a few years.
  10. ASRDogman
    8,057
    4,085
    You are OVER thinking this. Worrying about things that don't need to be worried about.
    Over the decades, I've had several car batteries. Only 1 or 2 have lasted 5 or more years.
    1.5 years back I bought a new battery for my van, it was over $100, on sale. My other one
    lasted almost 5 years. I have a small battery pack I used when I needed to jump start it.
    It's about 8 inches in length, and doesn't weight much. I've used it several time jumping
    other vehicles.
    If you prefer a manual transmission, the Prius is not the car for you. Manual transmissions are
    getting rare.
    It seems you are concerned about what things cost. Fob failure is rare, it does happen, but rare.
    Unless you purchase TechStream, you are going to have to PAY someone to program your key fob, period.
    WHO does it and WHO you pay, is up to you. I personally would trust Toyota before some 3rd party.
    It would cost more, but they have the correct tool for the job. And hopefully, the knowledge.
    The only thing I wished my Prius had was the JBL radio. Because it would be louder, and has Bluetooth.
    You worry TOO much about little things. Just enjoy the Prius for what it has and is. :)(y)
  11. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    Mine has JBL, but I wish it had a subwoofer. I need a little more bass.
  12. StephenFromCT
    Connecticut
    @fuzzy1, in 2017 you posted a response to a member who was trying to find a way to secure his car against people using scanners to amplify the FOB communication between the car and the FOB.
    Chinese hackers with proximity keys | PriusChat
    Do you think disabling SKS would work, or can you suggest other options, which still add security against the possibility of SKS hacking, but at a lower inconvenience to the owner?
    I am still searching for ways to secure my Prius, because if it is stolen or vandalized then I cannot enjoy it.
    In general, I am NOT asking forum members to question if the underlying concern is true. If the underlying concern is true, then what are your ideas for solutions?
    @ASRDogman, thank you for sharing your opinion that paying the Toyota dealer is the best way to be sure the job is done correctly, even though it will cost more. You are also concerned about the TCO, because you drive a Prius for its fuel economy, you buy 12V batteries for other vehicles when they are on sale, and you do not think it is worth spending the money to add hardware to your front passenger door to get SKS proximity entry to work.
    So yes, in the end, I may choose to pay the Toyota dealer to sell me a working FOB. I want to have two.
    I am interested in driving my 2011 Prius for many years, and I like knowing how things work. If other friends buy Prius cars then it may be worth if for me to buy Techstream (because I can use the software on several Prius cars). However, before I invest in Techstream I plan to buy an ODCII scanner.
  13. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    Given that on eBay you can get Techstream just as cheap, if not cheaper then a “hybrid aware” scanner, you would be dollars ahead to just get Techstream.
    I went the scanner route first, and to get one that could read hybrid system codes was 200 for the one I got. Granted, it can do airbag codes too, but a necessary evil, because you just never know.
  14. bisco
    52,825
    you can open the hatch by connecting a 12v source to the jump point under the hood
    correct, it is the draining, not the charging that causes damage
    if you only drive the car every few days, or very short trips, the battery doesn't recharge enough and slowly deteriorates, because there are constant electronic drains. a battery tender works well in this case
    my 12 volts have lasted 8 years minimum on two prius, and 7 so far on my current. you will do better in ct than someone in a warmer climate
