2011 Prius Head Gasket Failure
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by The Critic, Feb 28, 2019.
  1. mjoo
    mjoo Senior Member
    1,163
    1,334
    Michigan
    Yes it does. Clogged external EGR raises engine temps. An internal EGR cannot clog.
    Pixel XL ?
  2. Caballo Prieto Azabache
    Caballo Prieto Azabache Junior Member
    Good to know. Thank you!
  3. Caballo Prieto Azabache
    Wow, super clean engine Critic! I can't believe these are the "before" pictures. I hope my engine looks half as good as yours after I'm done with the repair. I removed the cylinder head cover and there is milkshake-like sludge everywhere.
    Raytheeagle and The Critic like this.
  4. jack black
    jack black Active Member
    225
    142
    I
    The Critic,
    did you see this HG failure analysis below?
    2010-2012 Head Gasket failure analysis | PriusChat
  5. jack black
    225
    142
    I
    didn't he say corollas fail too? i guess not as often?
    The Critic likes this.
  6. jack black
    225
    142
    I
  7. The Critic
    The Critic Resident Critic
    3,193
    2,333
    CA
    I did a search over on ToyotaNation and this is what I was able to find:
    random missfires? - Toyota Nation Forum : Toyota Car and Truck Forums
    '09 Corolla 1.8L Rough Idle - With a New Twist - Page 2 - Toyota Nation Forum : Toyota Car and Truck Forums
    2009 Corolla with engine misfiring (Codes P0300, P0301, P0302) - Toyota Nation Forum : Toyota Car and Truck Forums
    2009 Corolla Antifreeze Leaking into Cylinder - Toyota Nation Forum : Toyota Car and Truck Forums
    Head Issues - Toyota Nation Forum : Toyota Car and Truck Forums
    2009 Toyota Corolla Rough idle in gear problem - Toyota Nation Forum : Toyota Car and Truck Forums
    Lost my compression - Toyota Nation Forum : Toyota Car and Truck Forums
    Need help after replacing the Head Gasket - Toyota Nation Forum : Toyota Car and Truck Forums
    The common themes are:
    - Misfire, often cyl 1 and 2. Sometimes cyl 4.
    - The issue often develops between 125K-150K.
    There have been failures on the 2014 and 2015 models as well. There are fewer of them at this point due to the age, but it does not appear that the later model years are immune.
    No, stop leak products (unless OEM approved ones, such as the Subaru formula) will clog the heater core and the coolant passages. I would avoid.
    #87 The Critic, Apr 16, 2019
    jack black, SFO, mjoo and 1 other person like this.
  8. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,530
    Bay Area, California
    2019 Prius Prime
    You should see what he does when he details:
    EGR Evangelist’s car receives a light clean-up and Optimum Gloss-Coat
    A bit OCD, but looks fantastic (y).
  9. The Critic
    3,193
    2,333
    CA
    Raytheeagle likes this.
  10. Raytheeagle
    11,269
    15,530
    2019 Prius Prime
    Rainy yesterday ;).
    The Prime had some beading but the 2010 was garaged so nothing there:).
    I’ve booted it out for now and the Prime is in its new spot in the garage(y).
  11. SFO
    SFO Senior Member
    5,302
    4,252
    Northern California
    Now I'm curious how we can explain @The Critic 's head gasket failure given his meticulous preventative maintenance, including the EGR circuit service well before the problem surfaced. It seems there was no way he could've avoided such.
    CR94, Merkey, Raytheeagle and 2 others like this.
  12. The Critic
    3,193
    2,333
    CA
    And the Corolla’s without EGR still experienced head gasket failure...
  13. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    Bad head gasket design?
  14. mjoo
    mjoo Senior Member
    1,163
    1,334
    Michigan
    Preemptive headgasket replacement? At least that way you won't have to machine the block... :D
    m.wynn and Raytheeagle like this.
  15. mjoo
    mjoo Senior Member
    1,163
    1,334
    Michigan
    As I recall, Critic's EGR cooler was first cleaned at 180k miles.
    Unfortunately we can't weed out percentages of HG failures cause by EGR cooler vs poor headgasket design vs poor water pump design without a real ($$$) scientific study...
    #95 mjoo, Apr 17, 2019
  16. Mendel Leisk
    42,364
    Maybe a good interval for EGR cleaning would be the same as engine coolant change: 100K miles and 50K miles thereafter. Or if you want to be really safe, just every 50K miles.
    It's often mentioned that it's a good idea to sync EGR cleaning with engine coolant change, since coolant lines need to be disconnected in the course of EGR cooler cleaning.
    I've found though, just draining a couple of quarts from the radiator (into clean container) drops the coolant level below the whole EGR system. When everything is back together pour the coolant back into the reservoir.
    Bottom line, don't think you have to stall till coolant change time.
  17. jack black
    225
    142
    I
    good point. i wonder if the subaru's juice is compatible with Toyota's pink coolant.
    i mentioned that link to a specific product because a 2010 prius owner used that (it came up on google search).
    edit, just found it on BITOG:
    "You would be lucky if anything will work.
    Go to a Subaru dealer, and buy the Subaru coolant conditioner. Last bottle I bought cost about $4. It's made by Holts. Not sure which Holts formulation it is though.
    Subaru SOA635071 OEM Coolant System Conditioner
    Its a Ginger root formula, the same thing as GM or Bars Leak tabs. Holts/Subaru just added the water and mixed it up for you."
    Toyota 1GR-FE V6 head gasket stop leak additive - Bob Is The Oil Guy
    #97 jack black, Apr 17, 2019
    mjoo likes this.
  18. jack black
    225
    142
    I
    update: i did searches on Bar's Leaks tabs and reviews are great with no problems. some people swear that GM puts 2 of them in the factories in every new car.
    here is my plan: when i do my 100,000 miles coolant/spark plug/EGR/brake fluid change, those tablets go in to prevent small HG leaks. who knows, maybe Toyota will follow Subaru on those?
  19. The Critic
    3,193
    2,333
    CA
    True, the EGR cooler was first cleaned at 180K miles. However, the cooler was not blocked and the flow was not significantly impeded.
  20. The Critic
    3,193
    2,333
    CA
    UPDATE:
    It has been almost 4K miles since the head gasket repair. So far there have been no issues with misfires, coolant loss, rattling or unusual oil consumption.
    I plan to do an oil analysis at the 190K oil change to check for any coolant in the oil.
