[ANSWERED] Has anyone added LED turn signals behind their mirrors?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by DavidSpivey, Sep 13, 2015.
  1. DavidSpivey
    DavidSpivey Junior Member
    38
    United States
    In this video, there are turn signals that shine through the mirror.
    Is this something that requires replacement of the mirror glass, or is it something that can be done just by purchasing and installing the LEDs?
  2. xliderider
    xliderider Senior Member
    8,140
    3,274
    Honolulu, HI
    Someone else did it, I believe it works with the original mirror.
  3. rrg
    rrg Active Member
    458
    120
    East coast - NJ
    I have seen the ones you add the leds to the back of the mirror, they are cheaper of course.
    When I added the mirror housing turn signals, There is a heating element that is directly in the middle of the mirror that has a plastic backing that mounts to the swivel ball socket like mount.
    Remove the mirror from the black plastic. Then you will probably need to peel it back carefully and not tear the heating element (flat wire) away from the glass because it's not transparent.
    or if it's expensive ones you know you get a new glass with the mount and you loose some heating in the area that the LEDs sit.
    You can youtube and see the basic process.
    With my winters it's not an option.
    my2cents.
    #3 rrg, Sep 14, 2015
  4. E Risch
    E Risch Junior Member
    49
    Nashville
    some times some silvering needs to be removed to get them to be bright enough, others have said that you can see more then the lights (circut board) I have some, wasnt worth messing up my aspherical mirrors though
  5. DavidSpivey
    38
    United States
