Featured Bench charge HV battery
Discussion in 'Gen 2 Prius Technical Discussion' started by Freepriusguy, Feb 28, 2022.
  1. Freepriusguy
    Freepriusguy New Member
    Washington
    I
    Hello all.
    I just aquired a 2007 Prius for free. The previous owner stated the car ran when he parked it. He parked it because the HV battery is dead. I am wondering if I can attempt to bench charge the HV to see if the engine will run.
    Any help or comments are welcome!!! Thanks in advance.
  2. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    Welcome to PriusChat!!
    First you might want to pull the stored OBD2 codes by using a toyota hybrid compatible scanner, many use a mini-vci cable and techstream.
    Before charging the HV battery as a whole, use a multimeter or voltmeter to check each of the 28 individual modules for state of health.
    Unless you have a 'grid charger' or a high voltage supply handy, you may find these threads helpful and there could be other threads as well.
    DiY Grid Charger | PriusChat
    Build Hybrid Battery Maintenance Gear For Under $100 | PriusChat
    Can I borrow your battery charger/balancer/reconditioner? | Page 6 | PriusChat
    DIY Grid Reconditioning Charger | PriusChat
    FYI : you're moderated until you've posted 5 times.
    alftoy likes this.
  3. Freepriusguy
    Washington
    I
    Thank you very much for your reply. I will check these threads out!
  4. AndrewL
    AndrewL New Member
    Indianapolis
    so I’m trying to bench charge Prius gen2 modules. Can someone share a link to a charger that will work to buy and connect/charge either 1 module at a time or 2 modules together.
    Intelligent charger for nmhi Prius gen2 batts… please share a link to the prosuct? I’m having a hard time finding one. Thanks!
  5. bisco
    52,821
  6. alftoy
    alftoy Senior Member
    1,132
    519
    Saskatchewan, Canada
