Brakes issue: code C1252 and C1256
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Professorman, May 28, 2023.
  1. Professorman
    Professorman Junior Member
    Hampton, VA
    I have a new to me 2010 Prius w/240k miles.
    I have a constant beeping, brake light on, and codes C1252 & C1256.
    My brake light came on and no longer working properly. Sometimes it works, sometimes it’s hard to press like manual braking, and sometimes it grabs when I’m pressing it hard. My regen is working.
    What can I start as my troubleshooting diagnostics?
    52,762
  3. Professorman
    Hampton, VA
    Thank you. The diagnostics is very helpful. I am now pretty sure I need the brake master. I am testing if I need the pump as well.
    What are the pros and cons to buying used vs new?
    What other things do I need other than the parts? Do I need other gaskets?
    How much brake fluid do I need for the brake bleed process?
    52,762
    unfortunately, idk any more than you do, but i'm good at searching and learning.
    watch
    watch
    search
    many here have gone with salvage units. the difficulty is not being able to know if they are working, and tbh, they all have this problem, so at some point they are going to fail.
    hopefully, a new unit would be upgraded, so you have to decide which is best for you.
    there are tons of threads here with good advice:
    gen-3-known-brake-problem-outside-of-the-zjb-program-terms.235256
    Professorman likes this.
  5. Mr. F
    Mr. F Active Member
    389
    264
    Washington
    The possibility of introducing contaminants into the brake fluid.
