DIY 12V Battery Replacement Add'nl Info
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Elektroingenieur, Mar 17, 2018.
  1. tomnmeg
    tomnmeg Junior Member
    24
    Peoria, AZ
    Four Touring
    Just to activate. I got close to the wall in the garage and it activated at the exact same spot it always does. Then I pulled put of the garage on an angle getting close to the garage wall and that tone activated. Do you think I may need further calibration??
  2. jerrymildred
    jerrymildred Senior Member
    11,517
    14,167
    Tampa, FL
    OBDII scanner and memory saver have nothing to do with each other except that you plug them into the same port. Two totally different devices. See @Mendel Leisk's link in post #77. That one looks just like my memory saver. They are readily available in auto parts stores.
    Mendel Leisk and tomnmeg like this.
  3. tomnmeg
    24
    Peoria, AZ
    Four Touring
    I see... Thank you for that info. Much appreciated.
    jerrymildred and Mendel Leisk like this.
  4. Mendel Leisk
    42,289
    No clue, but I suspect not.
  5. Prodigyplace
    12,710
    11,848
    Central Virginia
    This question is better asked on a medical forum, not an automotive one.
    Simtronic, pjksr02, krmcg and 3 others like this.
  6. tomnmeg
    24
    Peoria, AZ
    Four Touring
    Very funny, Prodigyplace!! What an excellent line! ROFL
    Prodigyplace likes this.
  7. David E. Edwards
    David E. Edwards Junior Member
    25
    Sugar Land, TX
    Has anyone tried the H4 battery from Pep Boys has on sale for $100 + taxes? The specs are the same as my battery in a 2017.
    Mavi likes this.
  8. JasonB121
    JasonB121 Junior Member
    AZ
    This is an older thread, but I have in my 2017. Plus I didn’t do any of the rituals stated in the OP. On the first start, all my sensors stopped working, which I was happy with, but everything came back after restarting 30 minutes later.
    iPhone ?
  9. Graham Hooke
    Graham Hooke New Member
    Preston UK
    Business Edition
    I found my 12v battery was discharged because of the boot light being left on. Completely flat after little driving during covid, I couldn't open the door with the remote. I've charged countless batteries before so I disconnected the battery for charging to avoid any possibility of damage to electronics. Then reconnected battery, Car started fine and drives OK except none of the heating system controls are functional! A unit on top of the engine is humming all the time. I also have a message: IPA System Check Visit your dealer.
    Trouble is - the dealer is closed for covid - I've left a message and hope they will get back to me soon.
    Any advice on what I can do to fix this myself? I've read all the stuff about fuel caps and driving in a straight line but nothing corresponds to my problem. It seems that the system might need a reset. Just hoping it's nothing expensive. I can't believe that changing a 12v battery can be so complicated!
  10. Prodigyplace
    12,710
    11,848
    Central Virginia
    A weak 12 volt battery can confuse computers and give strange codes. Replace the 12 volt battery first before anything else. They generally do not work well after being run down.
    Elt31987 and krmcg like this.
  11. krmcg
    2,592
    2,393
    Whittier, CA
    A new 12 volt battery is cheap insurance
  12. Elt31987
    Elt31987 Active Member
    205
    155
    Derry, NH
    krmcg likes this.
  13. Prodigyplace
    12,710
    11,848
    Central Virginia
  14. Elt31987
    205
    155
    Derry, NH
    Ahh sorry didn't notice UK. You could try but I doubt it
  15. Lgtripletdad
    Lgtripletdad New Member
    Atlanta
    2018 Prius
    I have a 2018 Prius (standard) that has been giving me fits with the battery. About two weeks ago I drove to a store and then cut the car off. I parked for 20 minutes with the car in aux to listen to music. Pushed the start button and the brake pedal goes all wacky. 12v warning on the dashboard, etc. A buddy jumped me off and it ran fine for a week. One week later it did the same thing. Here I am three weeks into this and after my third jumpstart I need to get this figured out. Advanced Auto tested the battery and said it's fine. Anyone else have experience with a Prius randomly not starting due to low 12v battery? I bought the car used 1 1/2 years ago and it's the original battery. Suggestions?
  16. Elt31987
    205
    155
    Derry, NH
    Always put the car in ready when using electronics so the 12v gets charged. I'd ask another parts store to test it
  17. Elektroingenieur
    2,515
    3,288
    Three Touring
    1. Replace the auxiliary (12-volt) battery. See this posting for specifications; aftermarket ones are now readily available at reasonable prices. In principle, you could do the procedure in the Repair Manual (more info) under Power Source/Network: 2ZR-FXE (Battery/Charging): Charging System: On-Vehicle Inspection to rule out other possible causes, but you’ll need a clamp-on ammeter that can measure DC.
    2. As Toyota recommends (Owner’s Manual (PDF), page 233), “Do not leave the vehicle with the power switch in ACCESSORY or ON mode for long periods of time when the hybrid system is not operating.”
    As @Elt31987 kindly suggests, if you want to use the radio or other electrical equipment while parked, just leave the car in READY, so 12-volt power will come from the HV battery (via the DC-DC converter), and the engine will run as needed to keep the HV battery charged.
  18. Mendel Leisk
    42,289
    Also, if you use the car infrequently, and/or have a lot of short trips, look into smart chargers. And maybe an electronic load tester.
  19. Haji1987
    Haji1987 Junior Member
    24
    17
    Los Angeles
    Three Touring
    Similar thing happened to me over the weekend. I left the radio on with the can on accessories while my girlfriend ran Into the store and got the low 12v message and a crazy light show on my dash before needing a jump start. I was listening to the radio for less than 10 min before that happened. A few days later, and I haven’t gotten the low battery message anymore. Could it be the battery really needs to get replaced or the battery got sufficiently charged now and I just need to drive the car a little more often since I haven’t been driving as much since I work from home now?
  20. Prodigyplace
    12,710
    11,848
    Central Virginia
    The advice here is once the battery gets low enough to need jumping it needs to be replaced before it leaves you stranded somewhere.
    krmcg likes this.
