Do you need underbody rust protection on new Prime?
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by Salamander_King, Nov 7, 2017.
  1. m8547
    m8547 Senior Member
    951
    631
    Colorado
    2018 Prius Prime
    Sell it on Craigslist?
    Salamander_King likes this.
  2. Salamander_King
    Salamander_King Senior Member
    11,024
    8,980
    New England
    Yeah, I've been thinking of getting rid of those hazardous materials for sometime now. I have a case each of Toyota OEM and Honda OEM transmission fluids, a bunch of old motor oils that I can no longer use on the hybrid, a few bottles of coolant, cans of paint thinner, many cans of oil based paints and stains, and other various chemicals I no longer use or no longer usable. Most of them are old and in open container that no one wants, but I can't just throw away in trash. I seem to always miss annual municipal hazardous waste drop off opportunity. But some of them are still in unopened bottles that someone can use. I would be glad to just give them away.
  3. m8547
    m8547 Senior Member
    951
    631
    Colorado
    2018 Prius Prime
    The motor oils and transmission fluids can go in oil recycling. Any store that sells oil is supposed to accept used oil. Auto parts stores seem to just have a tank in that back that they let you dump it in. Recycling new oil is a bit of a waste, but that's what the hazardous waste collection will do with it anyway.
    My town has a hazardous waste recycling center that's open 4 days a week. They take almost anything. The best part is they have shelves full of free stuff like paint and cleaning supplies that you can take. I don't know what they do with everything they can't give away (besides oil which they send for recycling).
  4. EfficientAF
    EfficientAF New Member
    Technology
    Okay guys. 2021 Corolla Hybrid. I have an appointment for rustproofing in 3 hours. Oil-based (Krown). My only concern is that this coating can cause electrical issues within the car. Is this concern valid? I searched all manuals that are related to my car and there's not one mention of using rust-proofing and voiding the warranty.
  5. Salamander_King
    11,024
    8,980
    New England
    Are they going to remove under-body plastic covers? I don't know how extensive the underside of 2021 Corolla Hybrid is covered by such plastic, but for Prius Prime, it basically covers entire underside except exhaust elements. On Prius Prime and I think same for Gen4 Prius, without taking those covers off, there is not much to spray. If your Corolla Hybrid is the same, and the shop is not going to remove the cover to spray, you maybe wasting money.
    Now, as for the electrical problem, I don't think any of rustproofing material cause problem, but if your car develops electrical problem after rustproofing and the cause of the electrical problem is suspected to be the rust proofing, then yeah, I can see Toyota might try to void the warranty if it needs to be repaired. For your information, I had my Gen3 Prius and Nissan Pathfinder Hybrid undersides treated with FluidFilm and WoolWax respectively. Both are lanolin based material. I no longer have the Gen3, but for both cars I did not encounter any electrical problem within a year after application. However, the material were sprayed without removing the plastic covers, so no direct application of the material to any of electrical wires that may be hidden by such covers.
  6. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,576
    2,605
    Taylors, SC
    I've never used WoolWax or FluidFilm. My father, my grandfather and I have used petroleum based rustproofing for over 50 years with no electrical issues even in the engine compartment. The coating of petroleum based rustproofing actually deters rodents as an additional plus as rodents find the material distasteful. Petroleum based rustproof is a dielectric and actually helps prevent corrosion of electrical contacts.
    I would highly recommend that plastic undercovers be removed before and replaced after applying rustproofing.
    edthefox5 likes this.
  7. edthefox5
    edthefox5 Senior Member
    10,096
    4,840
    Clearwater, Florida
    Like Georgina said not necessary to apply rust proofing just spray some heavy viscosity lubrications on all the suspension parts. Then if you need to work on that area just hose it off with carb cleaner.
    None of my cars have any rust.
    Use CSP SPRAY. It is designed for this. It’s heavier viscosity and exactly like G said it’s also an excellent dialectic.every time I disconnect a plug on my cars it gets its contacts sprayed keeps it from corroding and repels moisture.
    CSP is a PB BLASTER family product. It does not smell its excellent lubricant and stays where you spray it.
    Haven’t used stinky WD40 in 15 years don’t own a can of that crap.
    CSP can be found at Home Depot.
    Georgina Rudkus likes this.
  8. farmecologist
    farmecologist Senior Member
    1,960
    1,801
    Southern MN
    Resurrecting this thread. Any consensus as to that to use? We picked up a Prius C that has some suspension component rust. Any ideas on what to use to slow it down? I'm planning on FluidFilm for now. I was reading about linseed oil...but if it attracts rodents...then that's an automatic no for me. (y)
    "None of my cars have any rust". If your profile is correct...your car is in Florida....of course it doesn't have any rust. :whistle: The guy from Minnesota got a hearty laugh out of that.
  9. Georgina Rudkus
    3,576
    2,605
    Taylors, SC
    First, pressure wash the underbody and all the crevices, bolts, hydraulic fittings and seams. and let it dry for a week. After a week, spray these areas with a rust converter.
    Wait a week and spray the crevices with an aerosol can of penetrating oil like Liquid Wrench. A week later, spray everything with a petroleum based rustproofing.
    farmecologist likes this.
  10. Salamander_King
    11,024
    8,980
    New England
    Sorry, no consensus. You ask 10 people, you are likely to get 10 different answers. I never did the entire underbody coating on my PP other than spraying some FluidFilm and/or WoolWax around suspension when the tires were off. But sold both PP less than 3 years old, so I don't know the effectiveness. OTOH, our then 5 years old used Pathfinder got underbody WoolWax applied at a shop right after we bought it two years ago. It seems to have protected the progression of the rust that was already well advanced when we got the car. It has seen two winters, I will need to re-apply it before next winter. However, since it was not applied around the exhaust, I had lost one of the heat shields probably due to rusting. Also, not the underbody parts, but a bracket that connects to a strut for the power rear gate was rusted and seized and ended up broken on this vehicle recently. It is a 2014 model, so 7 years old rust is going to continue to be a major problem on this car from now on. I would be very surprised if I don't have more major rust-related repairs on this vehicle during the next few years and beyond.
    Here is the photo of the strut and broken stud of the bracket on our 2014 PahHy. I did not take it to a dealer, but I have read in the Pathfinder forum that the repair cost can be $1K and up. I was able to drill the seized broken ball part of the stud off from the strut and able to replace the bracket DIY, saving bundle.
    #130 Salamander_King, Jun 28, 2021
  11. farmecologist
    1,960
    1,801
    Southern MN
    @Salamander_King Haha yeah...this discussion sounds a lot like how oil discussions go. :whistle:
    I like the idea of hitting it with a wire brush and then spraying with a rust converter....and then using FluidFilm or similar after that. Seems like an easy thing to try anyways... (y)
  12. Mendel Leisk
    42,369
    I just brushed off loose rust, brushed on linseed oil. Tenacious, and seals it, and seems to have arrested the rust, certainly looks near new.
  13. farmecologist
    1,960
    1,801
    Southern MN
    Well I skimmed thru the entire thread...Yikes...there are LOTS of options. (y)
    I ended up ordering some 'VHT SP229 Rust Converter' to try as a spray can solution :
    http://www.amazon.com/gp/product/B002NUABUO/
    I think I'll try boiled linseed oil and/or FluidFilm after I try the rust converter.
  14. Mendel Leisk
    42,369
    I was digging through my jpegs, not very organized, to no avail, then with what you mentioned, the light bulb went on:
    Do you need underbody rust protection on new Prime? | Page 3 | PriusChat
    ^ There's a pic of the right-rear, bottom-of-shock bolt, after a few years on the car, then a second pic, a year or more after application of boiled linseed oil. No rust-arrestor product, or aggressive brushing (if any), just brushed-on boiled linseed. The rust bloom on the shock weld is nowhere to be seen too.
  15. Georgina Rudkus
    3,576
    2,605
    Taylors, SC
    Surface rust is not as insidious as rust in seams, cracks and contact areas between similar metals, dissimilar metals, metals and plastics.
    The key is cleaning out these spaces of debris containing "hydroscopic" biologic or inorganic material, converting any rust that remains and treating these areas in exclude the reintroduction of debris that promotes galvanic corrosion.
  16. farmecologist
    1,960
    1,801
    Southern MN
    Yeah...surface rust isn't necessarily bad at all for solid cast components like steering knuckles and such. However, the control arms on the Prius C look pretty thin to begin with. *Probably* ok...but mine do look a little bit more rusty than I would like. (y)
  17. brenthon
    brenthon Junior Member
    GA
    I used FluidFilm on my truck and I can say that this product is effective. I'm planning to use it on my Prius also.
  18. JosephG
    JosephG Active Member
    115
    102
    2018 Prius
    This is one of those urban legends that's maybe half true at best.
    It's true large Japanese cities generally do not salt the roads because of advanced snow control infrastructure, but rural areas most certainly do and have for a long time. I know this for a fact because my family's business had to take their turn plowing and salting if they wanted any chance at government contracts. My grandfather fell from the pillow and injured himself quite badly many years ago.
    I believe calcium chloride is most commonly used rather than table salt. Because it's exothermic when dissolving it quickly penetrates Japanese snow, which is wet and often very thick. (In fact, the Wikipedia page for calcium chloride has a picture of Japanese road salt). Magnesium chloride and table salt are used though, just like in the rust belt.
    My best guess is people came up with this myth to explain why Japanese imports are so clean. I think the truth is Japanese use public transit and until recently kei vehicles for industrial applications. Vehicles that are imported like sports cars are luxuries that were babied and never allowed to rust.
    #138 JosephG, Jul 1, 2021
  19. farmecologist
    1,960
    1,801
    Southern MN
    Sounds like a reasonable explanation!
    All I know is the S&*T they use here in MN isn't good for the 'ol undercarriage. (y)
    With that said, ALL manufacturers have become better over the years, especially with *body* rust. However, Mazda has been the exception to the rule for us...ALL Mazdas we have had over the years have had body rust 'from the inside out'. Mazda lost a customer for life because of that. Part of the reason we went to Toyota and Hyundai. NO problems whatsoever with both. And I dare say the undercarriage issues are slightly worse on our Toyotas...but not by much. I suspect everyone has a different opinion on this though. :whistle:
  20. Trollbait
    12,832
    The first pick up Toyota imported to the US, had the bed rust out. They didn't make it by a single stamp of the sheet metal. It was a partial stamp, with welding to finish off the seams. The rusting started at the weld points. Were the trucks as prone to rusting back in Japan?
