Electric power from a hybrid, connecting inverter to the high-voltage system
Discussion in 'Knowledge Base Articles Discussion' started by ChapmanF, Mar 28, 2021.
  1. Primefan
    Primefan Junior Member
    42
    Virginia
  2. hill
    8,790
    FYI, plug out power says no dice for their appliances as hopes of using the RAV4 Prime.
  3. ChapmanF
    18,062
    What's the sticking point? Voltage too high?
  4. C Wagner
    C Wagner Member
    183
    60
    Boston
    Maybe make a wiki in that section about this?
  5. hill
    8,790
    The box. The way it's terminals are configured & sealed up like no body's business they say.
  6. ChapmanF
    18,062
  7. Randy B
    Randy B Member
    104
    30
    NH
    For those who happen to have a Toyota or Lexus hybrid, the PlugOut would be good to look at.
    Randy Bryan
  8. ChapmanF
    18,062
    For the newest readers, Randy's introduced back in the first post.
  9. ChapmanF
    18,062
  10. douglasjre
    douglasjre Senior Member
    2,162
    714
    Null, NL
    I'm finding the most I can draw off a turd gen 12v system is 2KW before V drops near 11VDC. Def gonna want to hook up to the 208-230VDC battery. Sent msg to the solar guys. Any other leads?
  11. ChapmanF
    18,062
    And if you even manage to draw that much, you've shown the converter's published specs to be conservative, as they're 120 amps, or around 1.7KW, of which the car has to use at least 0.4KW, and you're also above the rating of both the 125 amp fuse in the front fuse box and the 140 amp in the battery clamp (if you're on the battery side of that).
    So yes, for those levels of power, the kinds of solutions linked in this thread will be the ones of interest.
    douglasjre likes this.
  12. Randy B
    Randy B Member
    104
    30
    NH
    Haven't followed the entries closely, but what is the intended use? What loads are wanted?
  13. douglasjre
    2,162
    714
    Null, NL
    1.21 gigawatts of course! Just want to get more than two kilowatts without taxing the system
  14. Randy B
    Randy B Member
    104
    30
    NH
    Prius can provide up to 3.6kw reliably.
  15. georgefrank
    georgefrank Junior Member
    83
    earth
    I’ll give you $50 electronically if you can somehow find me a solution for this problem with the inverter
    220 volt dc to pvi6000 inverter to house panel (240 vac)
    One idea I have is to come off of the 12 V system with a small non-powerful inverter, run 240 V alternating current to the inverter, and give power to make the inverter think that the grid is active, then that would let the inverter take power from the high-voltage system of the Prius and feed it into the house panel
    $50 reward for someone to give solution
  16. rjparker
    rjparker Tu Humilde Sirviente
    10,074
    6,239
    Texas Hill Country
    For somebody who limits any knowledge about himself your request may be a hard sell.
    But the fundamental problem is a grid tied inverter is looking for a perfect non-deviating grid waveform that will sink a small to large current. Without that the grid tied inverter shuts down in less than 100ms. Even a powerful 24kw Generac generator can't match the specs needed much less some 12v to 240v inverter full of waveform distortions and frequency shifts.
    Much better to buy the $6,500 Generac for whole house or a $1,500 version with 8.5 kw and a mechanical interlock, both of which far surpass the Prius power backup capability. Leave the Prius for driving unless a 1200 watt 12v to 120v direct to the Prius is enough.
    #36 rjparker, Mar 2, 2023
  17. georgefrank
    83
    earth
    "or a $1,500 version with 8.5 kw and a mechanical interlock" - I dont know what you mean but i am very interested in this idea. Explain and elaborate if possible, it would be appreciated
  18. ChapmanF
    18,062
    This question is a crosspost from this existing thread here, where it's already been asked and other members like Leadfoot have already offered good answers:
    200 VDC - 240 VAC INSTALL PLEASE HELP, I will pay you if you get me lead for an inverter | PriusChat
    Would it be possible to keep the further discussion of that particular issue over on that thread?
    That way, this one stays kind of uncluttered as an overview thread for high-voltage inverter solutions.
  19. nolik
    nolik New Member
    29
    Dobczyce
    2001 Prius
    I
  20. hill
    8,790
    & now? ... sad to report they're outa business.
    too bad. i suppose it was to be expected - as the field of plug-in battery storage is in a Perpetual state of improvement in keeping up with those Electronics was a huge task.
    The other thing that's too bad about pulling house current in any real quantity off of a pure EV is that once the battery gets low, you are once again - S.O.L.
    That's why we are anxiously awaiting this bad boy .... not only does it have a eeeeuge battery, it has a eeeeuge gas tank as well. No Generac required.
    Ramcharger pickup uses onboard generator to charge batteries for extended range
    #40 hill, Apr 11, 2024
