Flasher Relay Location
Discussion in 'Gen 4 Prius Accessories and Modifications' started by fobby, Apr 16, 2018.
  1. fobby
    fobby New Member
    America
    Searching the forums, I see people talk about needing to replace the flasher relay with an LED compatible one in order to avoid hyper-blinking. This seems to mean that it is removable, however no one ever mentions where it is located. I don't want to pay the $15 needed to access the repair manual in hopes of getting this one question answered. So if someone has information on where the flasher relay is located it would be greatly appreciated.
    Thanks
  2. bobthejedi
    bobthejedi Active Member
    137
    153
    SF Bay Area
  3. fobby
    fobby New Member
    America
    Right, the relay for the turn signals. Granted, this is a gen 3 post, but I just want to know if such a thing like this exists in the gen 4 models and where it would be.
    LED Turn Signal Relay/Flasher
    I do know the Prius v doesn't have a replaceable one. Is it the same situation for the regular Prius?
    Where is the flasher relay?
    #3 fobby, Apr 17, 2018
  4. Elektroingenieur
    2,515
    3,259
    Three Touring
    On the fourth-generation Prius, the turn signal flasher circuit is part of the meter circuit plate in the combination meter assembly. I don’t know if the circuit uses a relay—the Repair Manual and Electrical Wiring Diagram don’t say—but if so, it’s probably soldered to the board. It’s definitely not sold separately as a service part.
    I also don’t know whether the flasher circuit needs a minimum current draw to flash at the correct rate, but at least one person found that the LED modules sold in the PriusChat Shop didn’t work:
    Anyone changed the front and rear turn signal to LED? | PriusChat
