Fuel tank size
Discussion in 'Gen 2 Prius Technical Discussion' started by phoenix101, Jul 6, 2009.
  1. valde3
    valde3 Senior Member
    2,002
    750
    Finland
    That 46.xx l is to first click of fuel pump? Was the tank already almost completely empty? What I’m trying to find is how much gas I can safely use if I put gas till first click of pump. ScanGauge 2 has never been of by more than 0,5l so if I know real size of tank I can safely run it very close to real empty.
    52,763
    it should be in your owners manual under 'capacities'.
  3. dolj
    dolj Senior Member
    8,633
    4,385
    Wellington, New Zealand
    It is. In mine it says 45 litres.
  4. dolj
    dolj Senior Member
    8,633
    4,385
    It was, and no the tank should have had about 2 litres in it. So I was very surprised when I saw 46.xx on the readout. I suspect the pump was overdue for calibration, as that fill spiked my average consumption graph as well. So something was amiss.
  5. dolj
    dolj Senior Member
    8,633
    4,385
    Thanks for fishing out all that info, Fuzzy.
    All I can say is WOW!
    But somehow this feels like cheating. Records should be set on a measured 45 litres to be valid.
  6. fuzzy1
    10,687
    Why not separate records for each category?
  7. valde3
    2,002
    750
    Finland
  8. bisco
    52,763
    perfect, looks like you're ready for some full tank usage!(y)
