How would you pair modules into blocks when rebuilding a Prius battery?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by CatNinja, Mar 22, 2023.
  1. CatNinja
    CatNinja Member
    59
    35
    Hawaii
    2023 Prius Prime
    XSE Premium
    I finally bit the bullet and took my battery apart to rebuild it. As expected, the middle blocks have failed (< 1Ah) weaker (2-3Ah) modules, and the outer blocks have the strongest (3Ah+) moudles. Note that these absolute numbers are low because I'm only testing from 8 to 6.5V, the real capacity from 8.4 to 6V is about 50% higher.
    I see several options for putting the battery back together:
    1. Just replace the bad modules. These is the fastest way, as you don't have to measure the capacity of each module, just the voltage. The bad modules usually have a much lower voltage than the others. Problem is that the weaker modules are still in the middle, and will probably fail soon.
    2. Pair the strongest/weakest modules. Idea is to even out the average capacity in each block, minimizing the voltage difference between the blocks. You have 2 ways of rebuilding the battery. First is to put the strongest/weakest pairs on the outside, and the average pairs in the middle. This is gentlest on the weakest modules, and should make them last the longest. Problem is that you are not wearing out the modules evenly, as the strongest would remain strong as they are on the outside, and the average ones in the middle would get weaker.
    3. Second way is to put the strongest/weakest pair in the middle, and the average pairs on the outside. The strongest modules would gradually wear down, and the weakest would fail. The idea being that you would get the most use out of each module as they wear down towards average, and you keep replacing the weakest module.
    4. Put the strongest modules in the middle, and the weakest on the outside. The idea being that the weakest moules on the outside would last longer, while the strongest modules in the middle wears the fastest, and you would gradually have the capacity even out between all the modules. Problem is that the capacity difference between the inside/outside modules could cause enought of a voltage difference to throw a code.
    5. Divide the modules into 2 sets, with the strongest in one set, and the weakest in the other. You pair the modules, one from each set, strongest to weakest. i.e. if the modules were numbered strongest to weakest, you would pair 1/15, 2/16, 3/17... 14/28. Idea is similar to (4), with the strongest pair in the middle, but with much less capacity difference between the pairs.
    I'm way over thinking this, and will probably end up replacing the entire battery with a new Lithium one instead of playing wack-a-mole once more modules fail.
    But I thought this would make an interesting taught excercise and discussion. How would you put the modules back together if you had to rebuild the battery?
  2. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,799
    2017 Prius c
    While some might find this discussion "interesting", I find it just a waste of everybody's time.
    The only proper way to "rebuild" a battery like this is with all new cells.
    It has been discussed before, probably several times.
    But maybe not in the detail that you propose.
    Tombukt2 likes this.
  3. alftoy
    alftoy Senior Member
    1,132
    514
    Saskatchewan, Canada
    By the way how many have you rebuilt @sam spade 2
    @TMR-JWAP would beg to differ considering the amount of batteries that he has rebuilt as opposed to how many you have rebuilt.
    Just Another HV Battery Thread and Experiments | PriusChat
    Battery Module Info-OEM 2007 disassembly &amp; cycling | PriusChat
    Results from almost total discharge of a Gen 2 module | PriusChat
    Order modules from a reputable supplier that @PriusCamper uses.
    https://2ndlifebattery.com/product-category/toyota/
    Or this 2015 Prius part out
    Toyota Prius 2015 - auto parts - by owner - vehicle automotive sale
    Or Gen 4 modules into Gen2/3
    Gen 4 cells in a Gen 2 | PriusChat
    #3 alftoy, Mar 22, 2023
  4. sam spade 2
    7,035
    2,799
    2017 Prius c
    Exactly......none.
    And that total won't be going up either because for ME it just isn't worth the cost and trouble.
    Especially doing a half-assed partial job that you have to do over and over.
    But if taking chances and playing whack-a-mole is appealing to you......then go for it.
  5. CatNinja
    CatNinja Member
    59
    35
    Hawaii
    2023 Prius Prime
    XSE Premium
    @sam spade 2 @alftoy If you don’t mind, I’d rather not turn this discussion into whether to rebuild with new vs reconditioned modules. There are a lot of other threads about this which people could read to help them make a decision.
    What I really want learn about is what is the prevailing thought about the order to put the modules back together again. I’ve read that I should “match” the modules in each pair, and that it’s important to replace the failed modules with ones in similar condition to the other modules in my battery. But no details on exactly what this means.
    Also @alftoy, thanks for the links, especially the one to 2ndlifebattey. I bought my 5 modules from eBay, and the results were mixed. 1 leaked (and was promptly replaced by the seller), 3 were in average condition (3Ah from 8 to 6.5V at 3A), and 2 were below average (2Ah) which I probably won’t use since it’s worst than the weakest non-failing module in my pack. I should have asked here first for a reputable seller. I will definitely use them if I end up needing just a few more modules. More than that, I’ll probably take @sam spade 2 ‘s advice and get a new battery.
  6. CatNinja
    CatNinja Member
    59
    35
    Hawaii
    2023 Prius Prime
    XSE Premium
    Just an update. I've decided to match the modules using method 2 (strongest/weakest from outside in), since this is the first time I'm rebuilding a pack, and this seems like the most straightforward way. Attached are the spreadsheets of the initial and rebuilt pack. As you can see, even thought the capacity of the modules varied quite a bit (2.6950 to 3.8024Ah, 1.1074 diff), method 2 evened out each block pair (6.4974 to 6.7201Ah, 0.2227 diff). 3 of the modules were clearly outliers, and those were replaced by the strongest eBay modules.
    I equalized the module voltages by shorting them together before reassembly, but from reading the other rebuild threads, it looks like this doesn't really do anything, and I should really balance/recondition them by doing several cycles using my grid charger. I will do it this weekend and post an update if it changes anything.
    Also, I have the 3 bad modules I replaced, as well as the 2 iffy ones from eBay that I decided not to use, on my bench right now. Is there anything you want me to test? I'm thinking on "reconditioning" them by cycling them from 8.4 to 0.6V (at 0.05C) several times, to see if this method from the insight forums really works.
    One other weird thing I noticed about my particular battery is that the serial numbers are all over the place, even though I'm the original owner and bought the 2010 new from the dealership. Usually, this indicates a rebuilt pack. Does anyone else ever see this in their original battery?
    Went around town for about 50 miles this weekend, and the pack seems to be working fine. I did not get a hybrid error (I previously always got it after 10 miles or so), idle delta voltage is about 0.07V, though it did peak at about 0.3V briefly under hard acceleration/braking. Block 14 (with the strongest/weakest modules) was the outlier, with consistently higher voltage than the other blocks, so putting it on the outside seems to be the right choice.
  7. rogerdpack
    rogerdpack Junior Member
    62
    Enoch, UT
    I wonder if you should put the weakest batteries closest to the fan (Block 1+?)
  8. MAX2
    MAX2 Senior Member
    1,436
    483
    101
    Third planet from the Sun
    What do you mean by the term "weak battery"?
    Some parameters, age? Something else?
  9. MAX2
    MAX2 Senior Member
    1,436
    483
    101
    Important note. The capacity values of individual modules in a pair of modules are not summed up.
    In a series connection of modules, the capacity of a pair of modules will be close to the value of the smallest capacity in the pair.
    If the capacity of the first module is 3.5 Ah, and the second module is 3 Ah, then the capacity of the pair of these modules will not be equal to 6.5 Ah.
    Think for yourself, if you start adding up the capacity of the old 28 modules with a capacity of 3 Ah, then the total capacity of the battery will not become 28 * 3 = 84 Ah.
    The capacity of such a battery of 28 modules will remain equal to 3 Ah.
