Hybrid Automotive Prolong Apology
Discussion in 'Generation 1 Prius Discussion' started by Brian in Tucson, Jan 11, 2018.
  1. Brian in Tucson
    Brian in Tucson Active Member
    981
    453
    Tucson AZ
    2003 Prius
    I don't know and haven't had the battery opened up to look. It would be nice if they had used whatever was current when the replacement battery was built. Mine was late 2013, so probably Gen 3. But even using Gen 1 modules would extend the lifespan of an 02. You still have to stay on top of other wear items like the inverter coolant pump, but the Gen 1 cars are very sturdy--especially ones in the desert South West where corrosion is practically unknown.
    Maybe Ericbecky or Chap know.
    ##### In other developments, I took the 03 out yesterday and it threw the code again--Battery Voltages vary too widely. Techstream says that they are all above 18v, so that's good. But differences are large enough to set a code. After I calmed down and stopped looking at modules on Ebay and Amazon, I thought it out and decided to put it through three more Prolong cycles--taking a day for each cycle. I'll report the outcomes on Tuesday.
    #21 Brian in Tucson, Jan 14, 2018
    WHCSC, Raytheeagle and Prodigyplace like this.
  2. WHCSC
    WHCSC Member
    277
    63
    Omaha, NE
    2003 Prius
    How can I get the date my oem was built?
  3. Prodigyplace
    12,569
    11,782
    Central Virginia
    Here is a quote I found my searching.
    The date coding goes by the 4th digit of the battery serial number beginning with the letter "A" which signifies the year 1999.
    It appears most assembly line cars came with packs built close to the year the car was produced. The exception has been the 2001 year model, which has date codes reaching back to 1999.
    So far, we have not seen any date codes newer than 2008, even though we have had 2 packs that we have examined that were bought in 2010.
    From Is there a way to find the date that a Prius Hybrid battery was manufactured? | Page 2 | PriusChat
  4. WHCSC
    WHCSC Member
    277
    63
    Omaha, NE
    2003 Prius
    So "B" would be 2000 and so on?
    Raytheeagle likes this.
  5. Brian in Tucson
    981
    453
    Tucson AZ
    2003 Prius
    Date of manufacture tells me nothing about what Generation spec. the modules were built to.
    WHCSC likes this.
  6. Prodigyplace
    12,569
    11,782
    Central Virginia
    I was responding to @WHCSC
    I do not know how to definitively identify module generation @ericbecky may know.
    WHCSC likes this.
  7. Dxta
    Dxta Senior Member
    1,942
    769
    Lagos
    Ray! Pls are the chargers/dischargers you guys sell, only applicable to Prius? Trying to inquire if there are available, the ones that can be used for Highlanders, and Camry hybrids.
  8. Prodigyplace
    12,569
    11,782
    Central Virginia
    Ray does not sell them except as an enthusiastic customer as far as I know.
    Head over to hybridautomotive.com to see the lineup. I know they are not restricted to Toyotas and now have a professional line too.
    Raytheeagle and jerrymildred like this.
  9. jerrymildred
    jerrymildred Senior Member
    11,517
    14,152
    Tampa, FL
  10. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    I’m just a guy who has used the equipment successfully and helps others :).
    So non-compensated testimonials ;).
    I do need to circle back to @jeff652 at some point though when he’s not traveling as much(y).
    #30 Raytheeagle, Aug 3, 2019
  11. Prodigyplace
    12,569
    11,782
    Central Virginia
    Looking for freebies? :whistle:
  12. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    Nope;).
    Other forms of discussions :).
    And general catch up(y).
  13. WilDavis
    WilDavis Senior Member
    2,493
    2,155
    49
    …it's always good to know friends who will help you out, especially when you have a Prius and particularly if you use Hybrid Automotive's Prolong Grid System! ;)
  14. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    Agreed;).
    Jeff is a good guy. While I no longer have a Prius his equipment could be used for, staying in touch is something I find to be a good thing:).
    But he beats the streets a lot, so those opportunities for both of us are limited:cool:.
    One of these days though(y).
    jerrymildred and WilDavis like this.
  15. WilDavis
    2,493
    2,155
    49
    Wot! No Prius! (loud jarring chord!) Please Miss, please Miss! @Raytheeagle has snuck in here, and he's just admitted to us that he is in fact Prius-less! (aside) So Ray, tell us all what happened? ;)
    jerrymildred and Raytheeagle like this.
  16. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    Oh I’m not Prius-less;).
    I was Prime for an upgrade:
    The Garage just got Crowded
    So I’m onto Lithium technology. Something Jeff doesn’t have any technology for;).
    But that doesn’t mean I’m not supportive :).
    I have experience with his product, and that won’t change(y).
    SFO, jerrymildred and WilDavis like this.
  17. jerrymildred
    11,517
    14,152
    Tampa, FL
    Yeah, he's stuck with one of those lame Primes that can't use the Prolong system. :LOL::LOL::LOL:
    I, on the other hand, have five more fingers. Errr, I mean I have a Prime AND a Gen 2 that I'll probably use the Prolong on later in the fall if it ever cools down outside. :)
    WilDavis and Raytheeagle like this.
  18. WilDavis
    2,493
    2,155
    49
    yet! ;)
  19. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    I’m not sure the Lithium technology has the same concerns;).
    Hence the reason for the discussion:).
    He’s a smart guy, if there’s something he can do, he’ll figure out a way(y).
    WilDavis and jerrymildred like this.
  20. Prodigyplace
    12,569
    11,782
    Central Virginia
    Actually I thought you were trying to group meet at Jeff’s place.
