Long-time intermittent rattle/shaking suddenly became nonstop
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Iketorz, Nov 3, 2025.
  1. Iketorz
    Iketorz Junior Member
    46
    Yours is the best guess so far and explains a lot.
    But just to be clear here you're saying that my car's head gasket has been blown more or less the same amount from 100,000-201,000 miles, only showing up for a few seconds every few months in the exact same way, never better or worse than before, spark plugs at 185,000 miles came out all identical, ran normally all the rest of the time, and then at 201,000 it blew all the way, without losing any more coolant, no steam out the exhaust, no exhaust in coolant, no coolant in oil, and which goes from absolutely horrific shaking to back to running totally normally as soon as I put it in neutral, and that all of this is very common even though I've never seen a single other thread on here that's anything like this.
    Like I've said, I've blown plenty of head gaskets on other cars. I've never had one that acted like nothing was wrong if I put the car in neutral. They kept shaking away no matter what I did.
  2. PriusCamper
    PriusCamper Senior Member
    13,475
    5,441
    Pacific Northwest, USA
    Yeah... My boss has paid for headgaskets in 3 of his Gen3 Prius and he said to me recently, "when it fails, you'll know." As in no need to worry about it until the engine runs rough all the time. And seems like avoiding hot weather and making sure that crappy electric water pump doesn't fail, as well as having clean EGR is what puts it off for as long as possible.
  3. rjparker
    rjparker Tu Humilde Sirviente
    11,144
    6,986
    Texas Hill Country
    You are not going to get it to go away now unless you start dumping sealer in the coolant. Which is a very bad idea since heater cores and radiators often clog and need to be replaced. I suspect your car already had sealer long ago.
    You have not been reading the right threads. Most of my response above was copied from earlier posts of mine. I also have throw down videos on the subject which have been posted tens of times.
  4. Iketorz
    46
    You're saying these threads and videos are about cars that have had once-in-a-blue-moon blown head gasket symptoms for a few seconds each, for 100,000 miles, but otherwise run fine, suddenly blow completely when in gear or in park but run totally normal when the transmission is in neutral.
  5. DirkAshburn
    DirkAshburn Member
    161
    66
    Virginia
    (edit - disregard. I saw it was answered above and I missed it).
    #25 DirkAshburn, Nov 5, 2025
  6. rjparker
    11,144
    6,986
    Texas Hill Country
    If the engine is carboned up and the hv battery is low capacity (worn out), acceleration with low bars can cause pinging. This will be repeatable with the engine cold or hot. It does not cause severe rattling or shaking.
  7. rrg1234
    rrg1234 Junior Member
    New Jersey
    OOoops. Never mind.
    #27 rrg1234, Nov 7, 2025
  8. Iketorz
    46
    Saw this by ChapmanF that explains everything sooo much better:
    CR94 likes this.
  9. Brian1954
    Brian1954 Senior Member
    2,694
    1,077
    South Central PA, USA
    It explains a lot, but it does not explain what is causing the misfires in your car's engine. You or your mechanic needs to diagnose what is causing the misfires. It may be caused by a bad head gasket, bad spark plug, bad injector, bad coil, etc. That is what you need to determine.
    PriusCamper likes this.
  10. ETC(SS)
    7,579
    True dat.
    Just remember, people don't die from a death rattle - they often die 'with' a death rattle.
    Those are two different things.
    I leak-down test or a borescope will confirm the HG leak.
