losing inverter coolant
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Spooled, Nov 30, 2014.
  1. Spooled
    Spooled Member
    142
    26
    Concord, CA
    i topped it off about a month ago i have had this car about 3 momth and it was low when i got it , its no inbetween full and low
    52,849
    that's the perfect level.
  3. Spooled
    Spooled Member
    142
    26
    Concord, CA
    fine but its going down...
    52,849
    any leakage around the pump?
  5. Spooled
    Spooled Member
    142
    26
    Concord, CA
    no visible leaking
  6. IMkenNY
    IMkenNY Im just being nosy
    477
    303
    Tropical Buffalo NY
    Four Touring
    Inverter radiator damaged by a stone?
    I believe it is visible through upper grill openings.
  7. Devon_C
    Devon_C New Member
    I
    I am actually experiencing the same problem. Last week my "Check Hybrid System" light came on, on my way home from work. I was able to drive the 55 miles home on the gas engine only (noticeable loss of power). Upon inspection I found the inverter coolant reservoir was almost empty. I hadn't noticed any leaks or pools of pink liquid while parked. When I topped up the reservoir the location of the leak seemed to be from the upper right quadrant of the radiator (as facing the vehicle). The reservoir drains quickly and will empty again (below outtake hoses) in a matter of a few minutes. So I'm fairly reluctant to drive the vehicle. This vehicle only has 51,000 miles on it so I'm pretty unhappy to discover such a major leak at this point.
    I can't seem to find a hose that is leaking, so I am wondering if the radiator somehow was cracked. My engine coolant isn't leaking at all. I didn't take out the inverter or the radiator cover to thoroughly check all hoses/gaskets. I'm taking it the dealer this week.
    I'd appreciate any thoughts on the potential leak source/cause and if others have experienced this at such low mileage.
    Thanks
    Devon
  8. bisco
    52,849
    any liquid on the ground?
  9. IMkenNY
    477
    303
    Tropical Buffalo NY
    Four Touring
    The inverter radiator is a completely separate unit from the engine radiator, they both happen to be at the front of the car.
    Perhaps someone can verify location but I was of the understanding that the inverter radiator is upper front prone to stone/ road debris damage through the upper grill openings.
    Link to a thread of someone with a similar problem: Inverter radiator leaking/replacement | PriusChat
  10. Yakoma
    Yakoma Active Member
    470
    125
    sss
    Should be easy for a tech to find this...gotta put fluid in it and get it up on the rack. If it's as bad as you say, it will be immediately evident. I wouldn't drive it until this is resolved. Get it towed to the dealer...should still be under warranty, right?
  11. Devon_C
    Devon_C New Member
    I
    Yup, as I feared this was a damaged inverter radiator cause by a rock. Since I've only had the vehicle 7 months, I'm not especially excited about forking out $900 for a new radiator. Now I'm looking at aftermarket grill to install, for around $250 (not including my time to install it). I may go back to Subarus. I can't deal with a $900 radiator replacement every time a rock hits the car.
  12. Yakoma
    470
    125
    sss
    Think how much money you save in fuel costs though to fund those radiator replacements. But seriously, given the many posts about blocking radiators to improve fuel efficiency, I think you're spot-on with looking at an aftermarket grill. I think I'll look into this for mine. I've got a Tacoma that is prone to radiator rock damage. I plan to replace the stock grill with a mesh one.
    EDIT: I just remembered that on TacomaWorld, someone posted about using honeycomb ABS mesh from Lowes (gutter guard material) to protect his radiator. Not as elegant as a $250 billet mesh replacement grill, but apparently effective.
    #12 Yakoma, Dec 4, 2014
  13. kc410
    kc410 Active Member
    263
    255
    2010 Prius IV
