My Prime's first transmission fluid change :D
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by thatoneraccoon, Feb 9, 2017.
  1. White 17
    White 17 Junior Member
    59
    17
    Nor Cal
    Racoon
    When you lowered the underside cowlings did the have any trouble with the push in plugs that hold it in place getting damaged? Were you able to reuse them?
    thatoneraccoon likes this.
  2. Mendel Leisk
    42,369
    To deal with the push-in fasteners I use all 3 of these, as needed:
    The one at the top is a paint can opener. Basically a flat blade screwdriver with a 90 deg hook at the tip. It's the main tool I use, just hook under the centre pin's edge and gently lever up. Still, the other tools come in handy, especially if the fastener is stubborn, may break from applying too much force. The simple flat blade screwdriver is sometimes more effective, at least to get the removal started. And if it's NOT coming out, even with the centre pin raised: the bottom tool, slipped under the whole fastener head and collar, will get it out, in one piece.
    Whenever you have the fasteners out, if you wash the grit out with warm, soapy water before reinstall, they will last. I've done 11~12 oil changes where I remove the whole undercover, and if I recall correctly, have yet to break one fastener. I recently noticed with maybe a couple of replacement fasteners in the glove box, so maybe I did break one and got a couple of spares. But really, it's been enough years that I can't recall. :)
  3. White 17
    59
    17
    Nor Cal
    Thanks, I guess it can be done.
  4. Mendel Leisk
    42,369
    4th gen is likely a bit different, but probably still a lot of those fasteners. I believe there's a separate small piece of panel just at the oil pan: it comes off completely, and is secured by metal screws? That's an improvement!
    Third gen has a flap in that area, that theoretically you can remove a few push-in pins and bend it down. But the plastic is kinda thin/brittle, and can end up cracking at the bend point. Which is why I take the whole panel off. It affords a better view of the whole engine bay, CV joints, and transaxle fill/drain bolts, so there's some plusses to that approach.
  5. farmecologist
    farmecologist Senior Member
    1,960
    1,801
    Southern MN
    I also remove the entire undercover when I do an oil change on our 2010. Yes, the fasteners will last if you are patient and use the proper tools. Unfortunately, I do not have the proper tools nor am I all that patient. I should try that slotted tool of yours though...it looks like it would work great.
    I ended up buying a BIG bag of both types of fasteners 'the auction site'. They were cheap and I have enough to last me nearly 'forever'. :)
  6. thatoneraccoon
    thatoneraccoon Active Member
    201
    146
    Ohio
    I did not have any problems, I just used 2 standard screw drivers to pop the tabs and then they pop back in. I was able to reuse them all. I was actually expecting more problems and it was easy and pretty quick too.
    Awesome! I like your tool list, thanks for showing us, I'm gunna have too get these
    #106 thatoneraccoon, Mar 3, 2017
  7. ajpn
    ajpn Junior Member
    30
    16
    So, my Prime is about to go in for its first service. While I was making the appointment I inquired about changing the transmission fluid. They told me it is not recommended, but they were willing to do it... for three hundred dollars!
  8. bwilson4web
    16,550
    They quoted the wrong procedure, a transmission oil flush. You have to tell them NOT A FLUSH! I want you to drain the oil and replace it with fresh oil.
    Toyota4Life and HPrimeAdvanced like this.
  9. ajpn
    ajpn Junior Member
    30
    16
    Well, it's possible they gave me a quote for that, but I'd have to wonder. Since I specifically asked to "have the transmission fluid changed", when they asked me if I wanted anything else done during the service. The mechanic said it wasn't necessary or recommended. But that if I really wanted it done they'd do it for $300. Then he wanted to know why I thought it needed to be done.
    In any case, I will do it myself. I was just thinking I would be lazy!
    #109 ajpn, Mar 28, 2017
    bwilson4web likes this.
  10. EV-ish
    EV-ish Active Member
    602
    278
    SW US
    Do you know people who performed routine maintenance and ended up scrapping their cars before e.g. 250k due to major component break-down ? How do you decide which group to ignore ?
  11. bwilson4web
    16,550
    Source on instructions: Prius Prime Plus in my hands | Page 10 | PriusChat
    Oil results: Prius Prime Plus in my hands | Page 15 | PriusChat
    There are several answers for 'why':
    • REAL - We have seen other Prius Prime owners find the transaxle oil shows signs of early wear including left over manufacturing debris (have hard copies of my reports and the photo from: My Prime's first transmission fluid change :D | PriusChat). Take a dry, water bottle with cap and tell them,"I want a sample of the used oil to send for analysis."
    • SUPPORTING - People who sell their Prius want to have a record showing the early changes which improved the used car price. That along with the oil analysis.
    • COMPETENCE - Here is a copy of a service order that did exactly what I wanted.
    Toyota4Life likes this.
  12. Trollbait
    12,832
    My dealer quoted $80 to just put the car on the lift and look underneath it.
    ajpn likes this.
  13. Mendel Leisk
    42,369
    I'd be disinclined to tell them anything. If they're that in the dark. Check with other dealership, or consider DIY.
    Yeah, there yeah go: DIY. (y)
    Just bear in mind, raise and level the car. That'll ensure the fluid level is right when it starts coming back out.
  14. Trollbait
    12,832
    I would have tried another dealer just upon hearing that price. An actual transmission flush around here goes for half that.
  15. Samprocat
    Samprocat Active Member
    491
    297
    Lincoln, NE
    You come over to my place...i will do free....I work on a lot of my project car's
    ajpn likes this.
  16. ajpn
    ajpn Junior Member
    30
    16
    Are you in Northern California? =)
  17. Duddy03
    Duddy03 Junior Member
    22
    Crossville, TN
    2018 Prius Prime
    Hi. I have a 2018 Prime with 8K miles to accompany my '04 Prius (221,000 miles). I am set on installing the strongest magnetic oil drain plug (Dimple Products) on the CVT drain port but I need to confirm the bolt size in order to buy the correct plug. (I think it may be M18 X 1.5.) As you know, a person can't make a mistake by unscrewing the wrong plugs! Do you have any suggestions for doing the work? I am going to install Amsoil Signature Series Fuel-Efficient Synthetic Automatic Transmission Fluid (ATLQT-EA) instead of the Toyota ATF WS fluid. Did the trans take 3.8 - 3.9 quarts? It is surprising how dark the CVT fluid was in your car. Good show to be pro-active!
  18. Salamander_King
    Salamander_King Senior Member
    11,024
    8,980
    New England
    As I did with my Gen3, I plan to do the transmission fluid drain and fill on my PRIME at 30K service. My dealer did it for ~$80 on my Gen3 but don't know what they will charge on PRIME. I still have 7K more to go.
  19. Mendel Leisk
    42,369
    Good plan. Still, there's nothing special about 30K miles. I did a drain on ours at 15K kms, around the one year mark, and the fluid was markedly darker. Subsequent drains, at much longer intervals, the fluid looks almost like new.
    Are you DIY'ing oil changes? The transaxle fluid is about on par.
  20. Salamander_King
    11,024
    8,980
    New England
    Not yet. I still have FREE Toyota Care maintenance. That expires at 25K, so starting 30K, I am planning to DIY weather permitting, for I have to do it on my driveway.;)
