Need help! Gas engine overheating. Cannot resolve.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Sergey K, Apr 1, 2019.
  1. LexCT200H
    LexCT200H Junior Member
    51
    Houston
    Thanks @rjparker ! I had to use engine body as ground as the battery is in the trunk. The positive connection from battery is accessible from engine compartment, but not negative. Tomorrow I will try to remove battery from a different car and test it with both positive and negative from that battery, this way I will not have to use engine body as ground. I hope it works that way, don't even want to think about replacing the fan. Just so that I am clear, in my earlier test I had disconnected fan connector from original wire coming from the car battery.
  2. rjparker
    rjparker Tu Humilde Sirviente
    11,096
    6,961
    Texas Hill Country
    If you have properly applied 12v directly to the fan connector it almost can not work from the normal circuit. Meaning the passenger side motor is bad.
    However the back probing method for feeding power does leave a little uncertainty about the connection you made since we are not measuring separately on the downstream wires.
    In a similar manner back probing the normal circuit for voltage while connected leaves significant uncertainty if you supply a separate ground.
    The normal connected circuit for that motor is always grounded.
    #302 rjparker, Jun 28, 2025
    LexCT200H likes this.
  3. LexCT200H
    51
    Houston
    Thanks @rjparker ! I believe at least the passenger side fan motor is bad. This morning I did two test - connected battery from another car into back-probed 2013 Lexus CT200H radiator fan connector, the fan did not come on. Did the same connection to check 2005 Toyota Sienna XLE radiator fan and the fan worked! Below is the video of it working on 2005 Sienna and a picture of same connection on Lexus CT200H. I will try to test the other fan same way once I figure out how to back-probe or disconnect the bottom connector for driver side fan.
    https://youtube.com/shorts/sX1yc7Ed_sA
  4. LexCT200H
    51
    Houston
    Also, I am frustrated with gas coming out of fuel rail. Tried replacing Fuel Injectors with OEM Fuel Injectors, and now Fuel is coming out from Fuel rail. Tried re-seating fuel injectors multiple times and still the same. What did I do wrong and how can I correct this? Thanks! Below is a video clip.
    https://youtube.com/shorts/pHmrf0IpoOw?feature=share
  5. ChapmanF
    19,019
    You will probably need a supply of new o-rings, and then to take a deep breath and look at this post, and then even this later one in that same thread.
    (I do note that second post talks about using axle grease on the o-rings, which isn't any of the things Toyota suggests. Toyota suggests "spindle oil" (an obscure substance that seems hard to find in less than giant buckets), or just plain gasoline (easier to get). But then, gasoline is not famous for its slipperiness, which means being even more careful with insertion.)
    #305 ChapmanF, Jun 29, 2025
  6. LexCT200H
    51
    Houston
    Thank you @ChapmanF ! I definitely did not turn these left and right while installing. I am surprised that when I installed the ones from Amazon few weeks ago, that time these did not leak ... I installed those the same way. I will buy new O rings and follow your steps. Thanks again!
    At one point I was thinking that the best and full-proof way to install these would be by removing the fuel rail.
  7. rjparker
    11,096
    6,961
    Texas Hill Country
    If you have one bad fan motor it's likely both are bad. The assembly comes with both.
    This aftermarket unit works well.
    Four pages of thread, 6 months of your work including head gasket and a major parts cannon that would make Ukraine proud and all we are have to show is one bad water pump and one bad radiator fan. Makes that 2005 Sienna look better day by day.
    #307 rjparker, Jun 29, 2025
  8. LexCT200H
    51
    Houston
    Thanks @rjparker . I think so too! Now I just need to find a good video instruction to remove and install fan. Found below two, need to watch repeatedly ...
  9. LexCT200H
    51
    Houston
    @ChapmanF : I tried again and I was very hopeful. I found spare o rings, removed all four, installed new o rings, lubed, and followed instructions you gave me. When I started the car, fuel came gushing out of fourth one on driver side. When I installed these, I felt the fourth one was slightly loose compared to others. I'm beginning to believe that the fourth hole opening somehow has gotten bigger and hence the reason. Getting tired of this, now it looks like I may need to replace the fuel line. Or maybe the best idea is to replace the engine, radiator fans, and hope for the best! Thanks again!
  10. rjparker
    11,096
    6,961
    Texas Hill Country
    The link Chapman provided on the injectors has some specific instructions for the #4 injector which is known to be difficult.
    Fuel Injectors...replacement steps.... | PriusChat
    Grasshopper was a name given to a trainee in the tv show Kung Fu.
    Concerning the coolant fan replacement, the Prius c video was closest, eg you take out the radiator and fans as one piece and then remove the fan assembly.
    But because things are more complicated in later gens, the repair manual method takes off the front bumper cover along with parts of the air intake to get the radiator fan assembly out.
    I don't believe the radiator fans will make the engine run correctly. In fact if you drive the car without ac, the radiator fans are not absolutely needed as vehicle speed pushes air through.
    However if you are bound and determined to make this car right, go for it. See attached pdf.
    Note on fan removal pdf: The section has an "inspection" page for the reservoir pressure cap and includes steps to remove radar sensors, both likely irrelevant to your problems.
    The process is described for a gen3 Prius, not your Lexus equivalent so there could be slight differences. If you pay for a two day subscription to the Toyota TIS system (or is there a Lexus TIS system?) you can access and download specific sections of the repair manual. There is no official single doc or pdf other than some huge files individuals have pasted together. Mendel has a link to a gen3 Prius version many have. It is a mere 7595 pages that many computers can't search without crashing but some can.
  11. rjparker
    11,096
    6,961
    Texas Hill Country
    Here is a guy who was changing his gen3 radiator but you will see him pull out the radiator and fan.
    I linked the video at 36:00 for the big moment. It's not out until it's out. Wait for it.
    This guy does it without taking off the bumper cover or under engine plastic. He absolutely abuses the ac condenser which would cost plenty if damaged. I would do it by the book.
  12. LexCT200H
    51
    Houston
    Thanks @rjparker ! I don't think I have a choice. Either do it right or give it away. Since, like you said, 6 months of effort and all I have to show is one bad water pump and one bad radiator fan, and now fuel rail gushing fuel out ... that's sad, lol! But I got to fix the radiator fan, and after that I will look into replacing the engine and then I will hope for the best! I did couple of tests this morning, and does not look like there is coolant in any of cylinders. As @Eddie25 had suggested, I also did Q-tip test on all four cylinders, Q-tip came dry from all four ... there was a bit of dirt. Additionally I also did paper test on top of all four cylinders (covered all four cylinder holes with printer paper, had another person push gas while car was in ready mode). The paper was dry after the test from all four cylinders. Hence there does not seem to be any liquid in any of the cylinders. This car has been a nightmare for a novice like myself, and wife keeps getting upset that I've been spending too much time on garage lol ... we'll see! Thanks again!
  13. LexCT200H
    51
    Houston
    You're right. Don't want to damage condensor trying to fix one part.
  14. LexCT200H
    51
    Houston
    Found it, looks like entire day or two days of work for me!
  15. LexCT200H
    51
    Houston
    @rjparker :
    I got a bit of news: I started the car today, firstly in maint mode, then later in regular mode and drove around for few miles. Surprisingly car engine sounds much better (below is link to youtube video) when hybrid battery is not charging, but when hybrid battery is charging it sounds pretty bad ... rattling knocking. I'm beginning to think if this could be because engine mount needs to be torqued or if timing is off? I am convinced now that the only way to be done with this is to replace the engine. Any suggestions? These are things that I did recently: Replaced radiator & radiator fan, replacing water pump, replaced fuel rail and fuel injectors.
    AC is cold, radiator fan is operating, fuel is not gushing out from fuel injectors, coolant temperature is under control ... max I noticed was 190 deg F. There is no OBD trouble codes. It's been interesting and learned a lot. Thanks to you and other members for intelligent suggestions. The only bad thing is it's not fixed 100% yet lol. Below are few pictures.
    https://youtube.com/shorts/9rvxtYHH1Ek
    Resized_IMG_1210.jpg Resized_IMG_1211.jpg Resized_IMG_1212.jpg Resized_IMG_1215.jpg Resized_IMG_1216.jpg
    #315 LexCT200H, Jul 19, 2025
  16. rjparker
    11,096
    6,961
    Texas Hill Country
    Perhaps my first suggestion with the cooling system somewhat under control (water pump and both cooling fans!) is to start fresh, this time focusing on the severe rattling continuing long after a head gasket job.
    Along the way since post 229
    Is it still blowing smoke out the exhaust?
    Has a borescope cylinder inspection with the cooling system pressurized been done?
    Have you reinstalled the oem coils and plugs?
    If your new head-gasket was not blown at the start of this drama, it's hard to imagine how it survived with the engine seriously overheating for long test periods.
    I would start a new thread with an appropriate title for the current situation. Ideally with a clear and concise backstory so others get the picture quickly.
    Borescope Videos with Pressurized Cooling Systems
    Car Care Nut HG Borescope at 660s
    South Main Auto
    Excellent Borescope Footage at 6:50
    #316 rjparker, Jul 19, 2025
  17. LexCT200H
    51
    Houston
    @rjparker Thanks again for your suggestions! Below are my answers:
    1) Is it still blowing smoke out the exhaust? => Yesterday I did not notice it
    2) Has a borescope cylinder inspection with the cooling system pressurized been done? => No, but I did printer paper test and Q-tip test on all four cylinders and there was no sign of coolant. I will think about buying borescope, but not sure ...
    3) Have you reinstalled the oem coils and plugs? => Yes
    Interestingly, chatgpt is saying the most likely cause for the rattling/knocking sound during idle and while hybrid battery charges, but not when you accelerate could be rear engine mount. I uploaded a video, and below is what chatgpt analyzed. Do you think there could be any truth to this?
    2013 lexus ct200h rattling/knocking noise when hybrid battery is charging and while idle. When accelerating sound is normal
    Thanks for uploading the video. I’ve reviewed it, and here’s my analysis based on what I see and hear:
    Noise Diagnosis – Video Analysis (2013 Lexus CT200h)
    Sound Characteristics:
    • A repetitive knocking or rattling sound is clearly audible.
    • It happens at low RPM, while the vehicle is idling and the engine is running (likely due to hybrid battery charging).
    • The sound appears rhythmic and corresponds with engine vibration, not random flapping or metallic scraping.
    Most Likely Cause: Engine Mount (Especially Rear Mount)
    • This kind of knock synchronized with engine movement at idle is classic for a worn or collapsed engine mount.
    • When the engine turns on to charge the hybrid battery, it shakes under load. A bad mount allows excessive movement, which hits or vibrates against subframe components or body metal.
    • The fact that the noise goes away when accelerating confirms that it's load- and vibration-dependent—a strong clue pointing to mounts.
    Recommended Next Steps
    1. Inspect Engine and Transmission Mounts
    Check especially:
    • Rear engine mount (under the engine, near the firewall)
    • Passenger side engine mount (upper right of engine bay)
    • Look for:
      • Cracked or sagging rubber
      • Excessive engine rock when revved
      • Mount touching subframe or crossmember
    2. Check for Contact Points
    Sometimes the engine can knock against:
    • Subframe
    • Heat shields
    • Exhaust brackets
    Use a pry bar to gently move the engine with the car off—see if it hits anything or moves excessively.
