PriiDash easy install on Windows 7 ?
Discussion in 'PriiDash (TM)' started by johnhlong, Sep 8, 2013.
  1. johnhlong
    johnhlong Junior Member
    89
    29
    East Carbon, Utah, USA
    Is there an easy step by step way to install PriiDash on a Windows 7 netbook?
    John
  2. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    510
    63
    Please take a look at the instruction here:
    PriiDash(TM) - Enhanced Instrument Panel and Data Logger for the Prius and more
    The most complicated part is to set the baud rate of your OBD-USB device, which is described here:
    FAQs | Troubleshoot - Need help? Ask questions here. | PriusChat
    Once the baud rate is set you can unzip the downloaded file and double click "priidash3_mingw.exe" to run the program.
    For your gen 3 Prius the two files "command.txt" and "formula.txt" need to be edited. I don't have much time to do it nor do I have a car to test. If you are interested I can show you the process to translate the custom PIDs collected by usbseawolf2000 and posted here:
    GenIII Prius Custom PIDs for Torque app | PriusChat
