PSA Warning: "Toyota Prius 2ZE head gasket replacement (complete step by step)" on Youtube
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Atari, Jul 9, 2019.
  1. Ragingfit
    Ragingfit Active Member
    189
    249
    Aurora, IL
    There was a recall on the EGR valve itself.
    You're gonna' need a new one.
    Atari likes this.
  2. Atari
    Atari Member
    84
    47
    Sacramento
    Saw that! I'm trying to avoid multiple $250 let-try-this attempts, but I think next step is a used EGR from a dismantler. I cleaned the MAP, reset, and drove again... still popped P0401.
  3. Purebavarian
    Purebavarian New Member
    Charlotte Nc
    I saw your post about an oil leak after a head gasket job if you followed gasket masters video, which is what I did. I can’t tell exactly where the leak is. Any chance you have a minute to talk? My cell is 704-340-5880
    Is anyone able to give more explanation about how to solve the oil leak after doing the job? I got it all put together and it’s leaking oil from what appears to be the back of the head gasket
    Any chance you can elaborate on this specific step that is not in the video on YouTube? I have an oil leak but since I assembled it all together I can’t tell what I missed
    #23 Purebavarian, Nov 23, 2019
  4. Mendel Leisk
    41,479
    Just a guess: there's an timing chain tensioner around the back side, maybe it's the culprit. Gasket Masters have a new video, and they mention to put a replacement gasket on that. Around 18:40 of the video linked in the initial post here:
    New head gasket replacement video from Gasket Masters | PriusChat
    Here's a pic of it's location:
    That bolt is a EGR cooler hold-down bolt, not really relevant. A lot of people just don't bother to reinstall it, since it's such a pain to access, and everything is still very solid.
  5. mikey_t
    mikey_t Active Member
    371
    391
    Los Angeles
    A member who recently did their head gasket had a leak in the timing cover seal. Maybe this thread will help:
    2011 Prius startup noise | Page 10 | PriusChat
