Some observations after doing my own oil change on the Prime
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by Pdog808, Jul 18, 2017.
  1. Skapruisprime
    Skapruisprime Member
    122
    49
    MA
    A Greener Oil Filter
    California Department of Resources Recycling and Recovery reported if all of the spin-on filters sold annually in California were recycled, there’d be enough steel to build three large sports stadiums.
    “California alone generates 67 million used automotive filters per year,” said Bill McKnight training team leader for MAHLE. “That’s a substantial amount of waste.”
    To get the most from used oil filters, some propose a better way to dispose of them is to separate the steel from the rubber and paper components before grinding them up instead of crushing the entire filter. This would reduce the amount of waste going into landfills. Quick lubes and other automotive service facilities could benefit from recycling the entire filter not just the used oil.
    “Vehicle manufacturers and original equipment manufacturers (OEMs) know this. We’ve collaborated and created a filter application containing no steel called the Eco-Filter,” McKnight said. “An oil filter without metal, only paper, plastic and rubber can be crushed just like conventional spin-on filters, but instead of going to a landfill after, they can be incinerated and used as a fuel source in commercial generators.
  2. Mendel Leisk
    41,463
    I really doubt it. Third gen with cartridge style were able to convert to spin-on, but it required an adaptor kit.
    Drivers door jamb placard.
    I take this as a backward step, too bad. The cartridge reduces junk in the recycle stream.
  3. Weasle543
    Weasle543 Member
    55
    38
    Ohio
    Here's the door jam and under hood emissions placards.
    Yes, it's a 2ZR-FXE engine.
    Mark57 likes this.
  4. Weasle543
    Weasle543 Member
    55
    38
    Ohio
    I'm not big for regulating everything however I would not be opposed to requiring all manufactures to end the use of spin on filters. What a waste of steel.
    Mark57 and Mendel Leisk like this.
  5. Mark57
    2,945
    2,740
    OK
    Thanks, that eliminates one variable.
    Now if we can get others to discover which filter type they have and their build dates.
    So far it "appears" that early 2017 Prime builds use cartridge and your November 2017 build has a screw on.
  6. Mark57
    2,945
    2,740
    OK
    Just for fun, I called the local dealer parts department and asked what oil filter they show listed for the 2017 Prius Prime. He said 04152-YZZA6 cartridge. I explained the situation here and he said he could look it up by VIN. I gave him mine and yours from above and still the same result. I then gave him the Denso screw on Toyota P/N 90915-10003 and he said it is an alternate? What the heck? He said it's not a problem for them as they just use whatever they discover on the vehicle at the time of the oil change. He acknowledged it could be a big issue for the DIY customer.
    I'm tempted to contact Toyota customer care and see what they say. Could take years and cost thousands of lives.:rolleyes:
    Instead of calling, I went to My Toyota and then to parts. Both filers are listed for the 2017 Prime.
    Prius Prime Parts like oil filter
    Toyota Prius Prime Filter s/a, oil. Gen, gcc, usa - 90915YZZF2 - Genuine Toyota Part
    #106 Mark57, Feb 28, 2018
  7. Mendel Leisk
    41,463
    If you're a DIY'r it's a good idea to do a dry run. My understanding with the 4 th gen, I'd assume Prime included, a small plastic underpanel at the oil pan vicinity can be removed completely by taking out a few screws. Have a preliminary look, see what you've got.
    Trollbait and Mark57 like this.
  8. Mendel Leisk
    41,463
    It's a good way to check your lift points, where to to put safety stands too. Or ramps, whatever you're doing.
    Mark57 likes this.
  9. Mark57
    2,945
    2,740
    OK
    @huskers just had his 10K oil change and verified he has the 04152-YZZA6 cartridge. His was built before August.
    So far it "appears" that early 2017 Prime builds use cartridge and November 2017 build has a screw on.
  10. Pdog808
    Pdog808 Active Member
    431
    287
    Los Angeles
    2018 Prius Prime
    Verified this at the Toyota dealer last week. The service guy pulled up two different oil change schematics on his system and verified that there are two versions of the 2017 Prime filter: cartridge and spin-on.
    Also, he seemed to be very surprised at finding out this information himself.
    Mark57 likes this.
  11. Mendel Leisk
    41,463
    I wonder if this is applicable to newer fourth gen Prius as well?
  12. Mark57
    2,945
    2,740
    OK
    When I called the parts department, he was also surprised but indicated it was not a biggie for them since they just put back on what kind they take off. I told him good luck trying to tell customers which filter their 2017 Prime takes if they call to buy one.
    So is there a 2017.5 version of the Prime to account for this?
  13. padroo
    padroo Senior Member
    2,763
    2,252
    The last time I went to Ford to buy part the first thing they asked me was the VIN number.
    Sounds like Toyota is the same. This kind of thing could make it a nightmare for aftermarket parts suppliers.
  14. Mark57
    2,945
    2,740
    OK
    That's what I tried to impress on them, of course the point was lost on the parts guy.
    I'm hoping with enough feedback here we can at least determine when the change was made to help forum members. So far, it appears to be sometime between August and November build dates.
  15. Mark57
    2,945
    2,740
    OK
    All I've see so far is 2017 Primes.
  16. randomwalk101
    randomwalk101 DYI'er
    532
    271
    texas
  17. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    I knew of a former mechanic, retired, in Germany
    that did this in his home garage. Picks up some extra change.
  18. randomwalk101
    532
    271
    texas
    This means that we can buy parts to convert the cartridge to the spin on oil filter since the engine is the same...we can probably do this with the regular Prius as well...
  19. Mark57
    2,945
    2,740
    OK
    I just verified today that my August 2017 built Prime uses the 04152-YZZA6 cartridge type. I was fairly sure it was the cartridge per other's build date info here, but wanted to see for myself. Verified @ 9,989 miles.
    Salamander_King likes this.
  20. stuyguy
    stuyguy Active Member
    170
    134
    Lakewood, CO
    2024 Prius Prime
    XSE
    Same cartridge as well for my March 2017 built Prime
    Mark57 likes this.
