Some observations after doing my own oil change on the Prime
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by Pdog808, Jul 18, 2017.
  1. Salamander_King
    Salamander_King Senior Member
    11,019
    8,954
    New England
    I just finished 30K mile oil change after first two oil changes by Toyota Care. I used Toyota OEM 0W-20 oil this time.
    Has anyone try using 0W-16 now available under Mobile 1 brand name? If so, do you see any difference in mpg?
    #141 Salamander_King, Aug 23, 2019
  2. JGC61
    JGC61 Active Member
    216
    104
    Long Island
    What is required to convert to A SPIN on oil filter on my 17 prime Advanced.
    Thanks
  3. jb in NE
    jb in NE Senior Member
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    I would look at the Toyota parts explodo and see which parts are different. I recall it's just the adapter/bracket at the engine block.
  4. Salamander_King
    11,019
    8,954
    New England
    There was a thread with parts list and step by step conversion photo. Let me see if I can find it.
    Edit: not for PRIME or Gen 4, but here is one thread SPIN ON, SPIN OFF!! | PriusChat
    #144 Salamander_King, Aug 23, 2019
  5. Mendel Leisk
    41,463
    Here's the go-to thread:
    Oil Filter Conversion | PriusChat
    FWIW, I've changed the oil filter on our 2010 maybe 17~18 times now, no problems. Cool thing you can do if it's just the paper element being changed: cut one pleat then uncurl and compress it, like a closed accordion bellows. Then put it between the jaws of a vice, and compress it. I've read you can pretty much wring ALL the oil out of it, and are left with near-dry paper.
    You'd want some strategy for avoiding the oil going all over your vice; maybe mount it with the jaws vertical?
    I might give this a try next time, lol.
    #145 Mendel Leisk, Aug 23, 2019
    Raytheeagle likes this.
  6. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    That vice looks seasoned:).
    Definitely not it’s first rodeo (y).
  7. ChapmanF
    18,213
    A little oil doesn't detract from my vice at all.
    Maybe I'll go get a vise and squeeze some out of something.
  8. Pdog808
    Pdog808 Active Member
    431
    287
    Los Angeles
    2018 Prius Prime
    I went the other way and put Mobil 1 Adv. Fuel Economy 0W-30 into my Prime. I don't think you want to reduce the upper number from "20" as it could theoretically increase your engine wear when the vehicle is at operating temp.
    By the way, there was no apparent mileage hit by going from 0W-20 to 0W-30. I changed my oil out at 2k miles and have been using 0W-30 for the past 8k miles.
    jerrymildred and Salamander_King like this.
  9. Pdog808
    431
    287
    Los Angeles
    2018 Prius Prime
    For those conspiracy theorists out there - my Prime clicked over to 10k miles on Thursday morning and about 3 hours later I received a call from my Toyota dealership reminding me about my 10k maintenance visit.
    :eek:
    jb in NE likes this.
  10. Salamander_King
    11,019
    8,954
    New England
    Interesting. I am not sure about US PRIME model, but there has been a rumor that Japanese Gen4 Prius are factory filled with 0W-16 and current Gen4 actually recommends the use of 0W-16. It was not widely available until recently, and ones on the market were very expensive. Mobile 1 0W-16 now available at Walmart changed that. It is the same price as 0W-20 and cheaper than the Toyota OEM. I am not sure of the use of thinner oil on the longevity of the engine, but if it is good enough for regular Prius, it should be even better on PRIME with less engine use. I just wanted to see if anyone has tried it yet.
    Pdog808 likes this.
  11. Pdog808
    431
    287
    Los Angeles
    2018 Prius Prime
    Well now is definitely the time to try out different Mobil 1 full synthetics:
    Mobil 1 Rebate (Good until 30 September 2019)
    FYI - Walmart isn't listed but Mobil 1 still honors purchases from them. I've purchased 2x 5 quart jugs and gotten both of my $12 rebates over the past 2 years.
    Purchasing the 5 quart Mobil 1 jugs at Walmart runs about $24-25 with tax, free shipping if you pick it up at a local Walmart. Minus the $12 rebate means you get 5 quarts of full synthetic for about $12-$13. Can't beat that with a stick!
    Salamander_King likes this.
  12. Salamander_King
    11,019
    8,954
    New England
    Well, I just finished my 30K change. I won't need to change oil for at least 8 mo.
  13. m8547
    m8547 Senior Member
    946
    626
    Colorado
    2018 Prius Prime
    Most wear happens when the engine is cold and the oil is too viscous. Once the engine is warmed up, oil is continuously pumped, and lower viscosity oil is easier to pump. But when it's cold, oil is much more viscous (no matter what grade), so oil is not able to be pumped to places that need it as quickly.
    Also, the specs on the Mobil 1 0W30 are kind of weird. The viscosity at 40C is actually slightly higher than their 5W30, and the viscosity index is lower. I see no reason to use it instead of 5W30 (but I could be persuaded otherwise if anyone has a good reason). I normally use 5W30 in my 4runner.
  14. jb in NE
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    Use what the manufacturer specified. They build the car and tested it with that oil specification.
  15. Salamander_King
    11,019
    8,954
    New England
    The thing is PRIME in the US has 0W-20 as manufacturer specified oil. The same car Prius PHV in Japan has 0W-16 as manufacturer specified oil. The reason I heard was that at the time 0W-16 oil was not widely available in the US, but it is now.
    Andyprius1 likes this.
  16. Mendel Leisk
    41,463
    And the Australian Owner's Manual recommends one oil (0W20 I think), but also displays a wide gamut of different weights, in a temperature range chart.
  17. jb in NE
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    Use what the manual specifies, at least until the warranty is expired. Easy out for any manufacturer to deny a warranty claim because you used an oil not specified for that vehicle in your application.
  18. Salamander_King
    11,019
    8,954
    New England
    Yap, I will be out of warranty for my next oil change at 40K. I used genuine Toyota 0W-20 oil and genuine Toyota ATF-WS at 30K.
  19. Pdog808
    431
    287
    Los Angeles
    2018 Prius Prime
    As a matter of interest, how many quarts of ATF-WS to change out the CVT fluid?
  20. Salamander_King
    11,019
    8,954
    New England
    3.5 qts used. Buy 4 qts, you will be good to go.
    Pdog808 and jb in NE like this.
