Some observations after doing my own oil change on the Prime
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by Pdog808, Jul 18, 2017.
  1. Tha_Ape
    Tha_Ape Active Member
    271
    162
    Washington, DC
    I have a 2017 advanced and it has a spin on filter. Next time you do an oil change buy one as well as the canister and see if you can spin it on. If not, take it back and use the canister. If so use it and take the canister back
  2. jerrymildred
    jerrymildred Senior Member
    11,517
    14,152
    Tampa, FL
    They made that change in mid 2017. My earlier model has the canister filter. I don't find the canister any harder than the spin-on, and sometimes the spin-on can be harder.
    Salamander_King likes this.
  3. Tha_Ape
    271
    162
    Washington, DC
    My 2010 is a canister. They both have their ups and downs. I personally prefer the canister because it seems to be less messy, but then again, we only need to change oil about once a year so it's not a huge deal.
    Thanks for the clarification on the change. I guess mines 2017.5
    jerrymildred likes this.
  4. Salamander_King
    Salamander_King Senior Member
    11,019
    8,954
    New England
    One thing good about canister is that you know the oil filter wrench you have used before works, since it is the same canister for the life of the car. With spin-on, I had compatible aftermarket oil filters not fitting to the oil filter wrench for OEM filter I owned.
  5. Mendel Leisk
    41,463
    I'm pretty sure you can't use a spin-on, on a car that came with cannister, without, changing parts. More info:
    Oil Filter Conversion | PriusChat
    jerrymildred and Salamander_King like this.
  6. jerrymildred
    11,517
    14,152
    Tampa, FL
    That's correct. It's pretty simple to convert and not very expensive. But I like the positive feel of the wrench on the canister cap and not having to fiddle with getting a grip on the spin-on.
  7. Mendel Leisk
    41,463
    I'd guess the spin-on is the same size?
    The same 12 face 64mm is used by Honda*, and: our son's CX-5 factory filter was slightly bigger (maybe 67mm?), but when I went to dealership and bought replacement, it too was 64 mm.
    * Honda used to use a significantly larger oil filter, and the 64mm was for motorcycles. I had one of each, and now use the motorcycle socket for any and all.
    Andyprius1 likes this.
  8. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    Logical.
  9. Michael Wood
    Michael Wood Active Member
    181
    118
    Boston, MA
    2020 Prius Prime
    I bought a cheap pair of Walmart Rhino ramps - they're strong ramps, but the angle is too steep to accommodate the Prius. The air dam wants to push the ramps forward.
    So I built a little lift to give me a lower angle of attack. It only takes a couple inches to make them work. If you have some extra lumber and screws you can quickly make a couple lifts. I used a couple pressure treated fence pickets on a 2 x 4, with some bracing to mate the lifts to the Rhinos. Works really well.
    pghyndman and AldoON like this.
  10. Michael Wood
    181
    118
    Boston, MA
    2020 Prius Prime
    Everything is so competitive these days. Most people would be shocked to learn that the painter they hired to apply that expensive Sherwin Williams "Duration" paint, had the right cans but the wrong paint. It's amazing how often the wrong materials end up in the right packaging. The automotive business is notorious for that, but rarely at the corporate level. It usually happens at the end-user, or one step up. Anything we can do to protect ourselves is worth doing.
    #170 Michael Wood, Oct 10, 2020
