Prius Plug In Update
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by -1-, Jun 8, 2013.
  1. -1-
    -1- Don
    1,254
    439
    Chester, Virginia
    2024 Prius Prime
    For those interested, provide information on your PIP. Who has the highest mileage PIP? Best fuel average? Highest EV ratio? Anything else of interest?
    Year & model : 2012 Advance
    Color: Winter gray metallic
    Purchase date: January 2013
    Current mileage: 2400
    EV ratio since new: 70%
    Average MPG since new: ?
    Information date: 060813
    Any issues: None
    52,348
    2012 base
    clearwater blue
    april '12
    9,623
    ev ratio 58%
    lifetime hsi mpg 175T :cool:
    06/08/13
    issues: zero(y)
  3. stanwagon
    stanwagon Junior Member
    64
    2013 Prius Plug-in
    2013 base
    clearwater blue (lovely color)
    bought: may 2013
    1000 miles so far
    ev ratio (but I am skeptical as to the true meaning/value of this) 33%
    mileage on first and only full tank: 722 miles, 8.6 galls, 83 mpg.
    I forget if high altitude (always above 9000 ft) has an effect on an auto's mpg. It does in the sense that it is always a little cooler up here.
    issues: just the fact that the engine warms up unnecessarily on trips of less than 5 miles.
    52,348
    my ice never comes on in ev, is it due to extreme cold up there, or long initial decents? ev ratio is based on miles in ev, what's not to trust?
  5. john1701a
    john1701a Prius Guru
    12,820
    5,305
    58
    Only if you accelerate hard or turn on the heater.
    On my morning commute taking the river route, I routinely drive the entire capacity in EV with a cold engine. That includes a variety of starts & stops, a bit of hill climbing, and some cruising at 55 mph.
  6. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    2012 base
    Clearwater Blue
    October 2012
    16000 miles
    28% EV
    88 mpg by HSI (72 mpg including MPGe of electricity)
    060813
    Got a "Shift to P" and orange triangle message 3 times. Apparently door was ajar. Could've just said that instead of the scary engine problem that a orange triangle alludes to.
    JMD likes this.
  7. IEAS
    IEAS Junior Member
    30
    Only trim in the UK which seems to be in the middle of your base and advance.
    Pearlescent white.
    Purchased - Jan 13.
    Current mileage - 10537
    Overall mpg since new - 83
    18% EV, total 1991 miles (399kwh)
    82% HV, total 8546 miles (used 126 gallons)
    No problems
    Info date 8/6/13.
  8. DadofHedgehog
    DadofHedgehog Active Member
    681
    282
    northern Virginia
    Color: Pearl Sea Foam Green
    Purchase date: 23 (?) April 2012
    Current mileage: 26,000
    EV ratio since new: 20% - but this includes multiple long-distance trips, like Wash DC - Michigan Upper Peninsula - Kansas City - Wash DC.
    Average MPG since new: 55.6
    Any issues: None
    Any wishes: that the traction EV battery could last 20 miles.
    Best mods, in terms of impact on driveability and liveability:
    1). EVSE Upgrade mod to the brick, so as to charge @ 240V with the standard utility rate (house) during the day, mostly weekend, while charging @240V in the lowest EV tier rate (dedicated 2d meter for EV - a Virginia special) during the night.
    2). Both of Mike500s underbody braces - the center brace and the front brace, coupled with the TRD rear anti-sway bar and the Cusco front strut tower brace. This car is now a stealth Super-Prius ;) he hee...
    3). Stage 10 button gear shifter - makes finger play between ECO and POWER buttons intuitive - see above line.
    4). FIAMM Highway Blaster horn duo - the High and Low frequency combo set.
    5). Brigade back-up White Noise reverse alarm.
    6). WeatherTech front floor pans.
    7). Weathertech window wind deflectors for all four windows.
  9. bisco
    52,348
    wow dad! what the heck is numero five o?
  10. Jetsurgn
    Jetsurgn Junior Member
    50
    San Pedro, CA
    White base model
    Purchased - May 2012
    Current mileage - 21295
    Overall mpg since new - 81.5
    30% EV, (1430kwh) 261 gallons
    1 occurrence: Check Hybrid System ,Stop the vehicle in a safe place
  11. CaliforniaBear
    CaliforniaBear Clearwater Blue Metallic
    1,180
    289
    Northern California
    From the Prius Plug-in FAQ
    • Why is ICE turning on when there's still battery left?
      There are any number of factors that can cause this. The manual outlines them on page 40:
      ●The heater etc. is in use.
      ●The temperature of the hybrid system is high: The vehicle has been left in the sun, driven on a hill, driven at high speeds, etc.
      ●The temperature of the hybrid system is low: The vehicle has been left in temperatures lower than about 32°F (0°C) for a long period of time etc.
      ●Power is needed temporarily, for example when accelerating suddenly.
      ●Vehicle speed is more than approximately 62 mph (100 km/h).
      ●The accelerator pedal is depressed firmly or the vehicle is on a hill etc.
      ●The outside temperature is low (less than 14°F [-10°C])
      Bullet points 4 & 6 refer to accelerating so hard that the HSI progress bar reaches into the PWR zone.
      In addition, it will also turn on when
      ●You have driven in EV mode with no ICE usage for 200 km (~124 miles)
      ●When using the front windshield defogger and coolant temperature is too low (more on that below)
      ●When you are braking/"coasting" and the traction battery is full (see question regarding the B drive mode below)
      Relevant threads: ICE in EV Mode … Again, ICE in EV Mode, why is my ICE starting???, confused about when ICE should run?, ICE Engine ON Indicator, EV mode and my ICE kicked in., Fully charge but ICE still running?, Is there any pattern for when ICE comes on?, Is the ICE kicking on in EV mode?
  12. ggood
    ggood Senior Member
    2,436
    517
    Houston, TX
    I agree with those who say the engine comes on way too easily.
  13. john1701a
    12,820
    5,305
    58
    Tradeoffs are part of engineering. You want to increase the tolerance on something, that means something else must be decreased. How much of what would you want changed?
    Look at what Ford did for comparison. Cargo space and engine efficiency was traded for the sake of increased range & power.
  14. CaliforniaBear
    1,180
    289
    Northern California
    Under what conditions does that happen for you? This happens for me only when going downhill with a full charge and using the brake. I can generally avoid that situation.
  15. retired4999
    2,652
    627
    Eau Claire, Wi.
    2012 Base Sea Glass Pearl
    Numbers from last fill 04/05/13
    See Signature
  16. RBooker
    RBooker Member
    154
    56
    Purchase date: October 2013
    Current mileage: 2652.5
    EV ratio since new: 76%
    Average MPG since new: 164
    Any issues: None
  17. mmmodem
    2,732
    1,703
    Bay Area, CA
    I can generally avoid it as well but it would be much nicer if I didn't have to. There should be a button labeled: "I don't want ICE. Really, I don't need more power when I accidently step on the pedal too hard."
  18. bisco
    52,348
    jd, straight up.:p
    retired4999 likes this.
  19. ggood
    ggood Senior Member
    2,436
    517
    Houston, TX
    Sometimes its my fault - stepping on the gas too hard to get across an intersection, don't turn the auto temp down far enough to keep the heat from running, etc. Other times it just seems to be spontaneous, or to be reacting to what I consider normal acceleration. I have a 3.5 mile flat commute with a lot of lights (I know, rough, right?!). For whatever reason, I seem to be able to avoid it in the morning but coming back in the evening it often kicks on for no apparent reason, sometimes even after just coming out of the parking garage. Yes I know it has to run every so often, but this seems more often than need be. As mmmodem suggested, I'd prefer not to have to baby it so much. Seems like it could be a little less aggressive about coming on for heating and acceleration.
  20. CaliforniaBear
    1,180
    289
    Northern California
    You just need to look at the HSI display that shows how the car is responding to the gas pedal. Keep it out of the PWR area and there should be no problem. Also if you use the ECO mode the gas pedal is less responsive to the amount you depress it making it easier to stay out of the PWR range.
    DadofHedgehog likes this.
