What's this thing?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by bmparent, May 24, 2019.
  1. bmparent
    bmparent Member
    159
    65
    barre ma
    I ripped my trunk panels off this afternoon, in preparation for swapping out the battery, most likely. That was quite satisfying! IMG_2745.JPG I've also been trying to find a source of a leak. There is a block of foam or something inside the panel that has been absorbing a lot of the water that's leaked in, just covered in mold. The waters been running past/around this white thing and I'm wondering how it's connected to the electrical (hybrid) system if at all, and how vulnerable it might be to water damage. The top surface looks to have some staining, maybe mold. I'm thinking it's the ground?
  2. egg_salad
    egg_salad Active Member
    545
    426
    Las Vegas, NV
    I can make out a frequency number, which tells me it's an RF device. Which pretty much limits it to smart key or key fob-related.
    bmparent likes this.
  3. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,099
    Columbia, SC
    The source of your leak is two likely/common places.
    1. At the upper corner of the hatch area, where water drains at the sides of the hatch, there are body seams. They tend to develop cracks.
    2. On each side of the hatch, where the lift cylinders mount, debris tends to gather and acts like a dam. Water builds up behind the dam and can leak in where the cylinder is mounted.
    Both of these result in water leaking down the inside of the trunk trim panels, into the 12v battery well, into the storage cubby, into the spare tire storage area, etc. I even had about a cup of water pour out of the HV battery fan duct work one time when swapping out a customers battery.
  4. bmparent
    bmparent Member
    159
    65
    barre ma
    Yeah I've found water in most of those places, except for the hv battery fan duct (as far as I know). I've put silicone sealant on most of the joints around the hatchback, but haven't gotten rid of it yet. I haven't put any around the lift cylinders yet, but maybe I'll do that next. The water is coming from above and running down the black protrusion, I can see the streaks on it but it's hard to see up into the trim panel above that. If I knew that the water wasn't going to damage anything, I might move on if I can't seal it up soon, but the moisture in the car and the mold smell sure is annoying. I now realize too that this is why my back window was always fogging up, and why the insides of the windows often frost over in the winter. I've pulled out the rubber stoppers in the bottom of the spare tire wheel well and battery well as a temp. fix.
  5. TMR-JWAP
    6,404
    6,099
    Columbia, SC
    I've only had very minor leakage/puddling under the driver side storage cubby so far. I drilled one 1/8th inch hole in each side area, at what looked like the lowest spot, to prevent any buildup. So far, so good.
  6. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    The part in question has a Toyota part number in it. If you type the number into a Toyota parts site it will tell you what it is. I can’t read the numbers well enough to run it down but it’s the first line on the sticker.
  7. TMR-JWAP
    6,404
    6,099
    Columbia, SC
  8. edthefox5
    edthefox5 Senior Member
    10,096
    4,840
    Clearwater, Florida
    Check the 12 volt battery hole its probably full of water. If you garage the car you can remove the rubber drain plug at the bottom of that battery well. You can also remove the rubber drain plug under the spare tire but only if you garage the car. If not I would be leery of removing those plugs as mice love to inhabit a G2. If the car lives outside I would check the air cabin filter behind the glove box for signs of mice.
    Very common for mice in a G2 they love the taste of the wiring and will do alot of damage mice inhabitation seem to go hand in hand with cabin leaks.
    I believe that white box your referring to is the SKS antenna amplifier. There's a few of those in the car.
  9. bmparent
    bmparent Member
    159
    65
    barre ma
    I've definitely had a lot of water in the battery compartment in the past, but I removed the drain plugs, and I think just maybe I've found the source of the leaks. I still need another good rain or two to know for sure thought. Yeah I've had lots of mouse indicators in my glove box, I change that stupid filter about every 6 months.Hopefully they haven't chewed any wires...
    edthefox5 likes this.
  10. jessiejosco
    jessiejosco Member
    62
    42
    If you have not already, you should pull up the plastic black strips in the channels on the roof. The seam that leaks runs the length of the roof and the cracks on mine went up about an inch under those strips. Once I did that and sealed the cracks, I have had a totally dry hatch.
  11. bmparent
    bmparent Member
    159
    65
    barre ma
    If there's a chance I can find the leak, I'll it. But how are the rubber seals attached? Are they glued in or fixed in anyway, and will they re-attach easily? One of the rubber seals around the rear drivers side door is a little loose so at least those ones are glued.
  12. edthefox5
    10,096
    4,840
    Clearwater, Florida
    Jessie is right. Those black strips pop right off just pull them up and off. They snap right back on. It may help to then wash the car clean out that valley real good and give it a good look maybe use a magnifier and if really unlucky you will see a crack running up that valley. Mine is only cracked at the pass side hatch corner.
    I suspect its cracking there from slamming the trunk closed alot which is hard not to slam the trunk really. Or maybe its just a high body flex area but cracks there on a G2 are very very common. Mine drips down on the 12 volt battery side but mine is garaged so no big deal for me.
  13. exstudent
    exstudent Senior Member
    2,214
    906
    Torrance, CA
    Three areas for water entry into trunk, that can and has spilled into other areas of the car.
    1) Most common source of leaks: just under the black decorative strip near the hatch glass
    2) Less common source of leaks: failed weather seals
    Buy the rubberized door weather stripping tape seal from Lowe's/Home Depot/Ace Hardware/etc; DO NOT BUY THE GREY FOAM, it will become compressed quickly. You may have to get both b/c 1/8in difference in thickness is small, but sometimes, it can be enough from pushing/screwing the part back on.
    3/8in thick * 3/4in wide * 10ft long self adhesive roll, $6
    1/4in (2/8in) thick * 3/4in wide * 10ft long self adhesive roll, $5
    3) Bad bady work.
